[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-303-ge442406bf
git at osgeo.org
git at osgeo.org
Wed Jan 19 03:54:57 PST 2022
the project "PostGIS".
via e442406bfafbb909d8129b3d0c4a087d66c01425 (commit)
via 175c59ffd733f1af904f92dee7d3b2ea1e8b299a (commit)
from 5fcc13dde2189d3d671da2ee5668bffcd4066486 (commit)
revisions in full, below.
commit e442406bfafbb909d8129b3d0c4a087d66c01425
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jan 19 11:42:55 2022 +0000
Translated using Weblate (Italian)
Currently translated at 34.3% (191 of 556 strings)
Translation: postgis/extras_topology.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_topologyxml/it/
diff --git a/doc/po/it_IT/extras_topology.xml.po b/doc/po/it_IT/extras_topology.xml.po
index 52c708423..bdf227fcc 100644
--- a/doc/po/it_IT/extras_topology.xml.po
+++ b/doc/po/it_IT/extras_topology.xml.po
@@ -11,7 +11,7 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2021-11-08 06:12+0000\n"
-"PO-Revision-Date: 2022-01-12 23:53+0000\n"
+"PO-Revision-Date: 2022-01-19 11:54+0000\n"
"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
"extras_topologyxml/it/>\n"
@@ -47,6 +47,10 @@ msgid ""
"strk.kbt.io/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf"
"\">Topology with PostGIS 2.0 slide deck</ulink>."
msgstr ""
+"La presentazione di Sandro Santilli alla conferenza PostGIS Day Paris 2011 "
+"fornisce una buona introduzione alla Topologia PostGIS <ulink url=\"http"
+"://strk.kbt.io/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf\""
+">Topology with PostGIS 2.0 slide deck</ulink>."
#. Tag: para
#: extras_topology.xml:6
@@ -58,6 +62,11 @@ msgid ""
"pgconfeu2012_vincent_picavet_postgis_topology.pdf?raw=true\">PostGIS "
"Topology PGConf EU 2012</ulink>."
msgstr ""
+"Vincent Picavet fornisce una buona spiegazione di cosa sia la Topologia, "
+"come viene utilizzata e vari strumenti FOSS4G che la supportano in <ulink "
+"url=\"https://github.com/Oslandia/presentations/blob/master/pgconf_eu_2012/"
+"pgconfeu2012_vincent_picavet_postgis_topology.pdf?raw=true\">PostGIS "
+"Topology PGConf EU 2012</ulink>."
#. Tag: para
#: extras_topology.xml:7
@@ -69,6 +78,11 @@ msgid ""
"database. If you want to experiment with PostGIS topology and need some "
"data, check out <xref linkend=\"Topology_Load_Tiger\"/>."
msgstr ""
+"Un esempio di database GIS topologico è il database del <ulink url=\"https"
+"://www.census.gov/geo/maps-data/data/tiger.html\">US Census Topologically "
+"Integrated Geographic Encoding and Referencing System (TIGER)</ulink>. Se "
+"vuoi sperimentare con la topologia PostGIS ed hai bisogno di dati, vedi "
+"<xref linkend=\"Topology_Load_Tiger\"/>."
#. Tag: para
#: extras_topology.xml:8
@@ -125,6 +139,10 @@ msgid ""
"disabled specifying --without-topology configure option at build time as "
"described in <xref linkend=\"postgis_installation\"/>"
msgstr ""
+"Il supporto topologico è incluso di default a partire da PostGIS 2.0, a può "
+"essere disabilitato passando l'opzione --without-topology all'invocazione "
+"dello script configure al momento della compilazione, come descritto in "
+"<xref linkend=\"postgis_installation\"/>"
#. Tag: para
#: extras_topology.xml:18
@@ -156,6 +174,8 @@ msgstr "getfaceedges_returntype"
#, no-c-format
msgid "A composite type that consists of a sequence number and an edge number."
msgstr ""
+"Un tipo di dato composto che consiste in un numero sequenziale e un "
+"identificativo di edge."
#. Tag: title
#: extras_topology.xml:34 extras_topology.xml:58 extras_topology.xml:107
@@ -192,6 +212,9 @@ msgid ""
"is the return type for <varname>ST_GetFaceEdges</varname> and "
"<varname>GetNodeEdges</varname> functions."
msgstr ""
+"Un tipo di dato composto che consisten in un numero sequenziale ed un "
+"identificativo di edge. Questo è il tipo di dato restituito dalle funzioni "
+"<varname>ST_GetFaceEdges</varname> e <varname>GetNodeEdges</varname>."
#. Tag: para
#: extras_topology.xml:43
@@ -214,13 +237,15 @@ msgstr "<varname>edge</varname> è un intero: l'identificativo di un bordo."
#: extras_topology.xml:54
#, no-c-format
msgid "TopoGeometry"
-msgstr ""
+msgstr "TopoGeometry"
#. Tag: refpurpose
#: extras_topology.xml:55
#, no-c-format
msgid "A composite type representing a topologically defined geometry."
msgstr ""
+"Un tipo di dato composto che rappresenta una geometria definita "
+"topologicamente."
#. Tag: para
#: extras_topology.xml:59
@@ -231,6 +256,10 @@ msgid ""
"TopoGeometry are the properties: topology_id, layer_id, id integer, type "
"integer."
msgstr ""
+"Un tipo di dato composto che si riferisce ad una geometria topologica in uno "
+"specifico layer topologico, avente uno specifico tipo e identificativo. Gli "
+"elementi di una TopoGeometry sono le proprietà: topology_id, layer_id, id "
+"integer, type integer."
#. Tag: para
#: extras_topology.xml:62
@@ -239,6 +268,9 @@ msgid ""
"<varname>topology_id</varname> is an integer: Refers to a topology defined "
"in the topology.topology table which defines the topology schema and srid."
msgstr ""
+"<varname>topology_id</varname> è un numero intero: si riferisce ad una "
+"topologia registrata nella tabella topology.topology, dove sono definiti lo "
+"schema e lo SRID della topologia."
#. Tag: para
#: extras_topology.xml:65
@@ -248,6 +280,9 @@ msgid ""
"that the TopoGeometry belongs to. The combination of topology_id, layer_id "
"provides a unique reference in the topology.layers table."
msgstr ""
+"<varname>layer_id</varname> è un numero intero: il layer_id nella tabella "
+"dei layer a cui la TopoGeometry appartiene. La combinazione di topology_id e "
+"layer_id forniscono un riferimento unico nella tabella topology.layers."
#. Tag: para
#: extras_topology.xml:68
@@ -257,6 +292,9 @@ msgid ""
"number that uniquely defines the topogeometry in the respective topology "
"layer."
msgstr ""
+"<varname>id</varname> è un numero intero: L'identificativo è un numero "
+"sequenziale autogenerato che identifica in maniera univoca una TopoGeometry "
+"nel rispettivo layer topologico."
#. Tag: para
#: extras_topology.xml:71
@@ -265,6 +303,8 @@ msgid ""
"<varname>type</varname> integer between 1 - 4 that defines the geometry "
"type: 1:[multi]point, 2:[multi]line, 3:[multi]poly, 4:collection"
msgstr ""
+"<varname>type</varname> intero tra 1 e 4 che defnisce il tipo di geometria: "
+"1:[multi]point, 2:[multi]line, 3:[multi]poly, 4:collection"
#. Tag: title
#: extras_topology.xml:77
@@ -298,7 +338,7 @@ msgstr "Comportamento"
#: extras_topology.xml:87
#, no-c-format
msgid "geometry"
-msgstr ""
+msgstr "geometry"
#. Tag: entry
#: extras_topology.xml:88
@@ -346,6 +386,9 @@ msgid ""
"location of error. This is the return type for <varname>ValidateTopology</"
"varname>."
msgstr ""
+"Un tipo di dato composto che consiste in un messaggio di errore e due "
+"identificativi (id1 e id2) che denotano la locazione spaziale dell'errore. "
+"Questo è il tipo di dato ritornato da <varname>ValidateTopology</varname>."
#. Tag: para
#: extras_topology.xml:108
@@ -356,12 +399,18 @@ msgid ""
"denote validation errors and the id1 and id2 to denote the ids of the "
"topology objects involved in the error."
msgstr ""
+"Un tipo di dato composto che consiste in un messaggio di errore e due numeri "
+"interi. La funzione <xref linkend=\"ValidateTopology\"/> restituisce un "
+"insieme di valori di questo tipo per indicare errori di validazione "
+"topologica. I due numeri interi id1 e id2 denotano gli identificativi degli "
+"oggetti topologici coinvolti nell'errore."
#. Tag: para
#: extras_topology.xml:111
#, no-c-format
msgid "<varname>error</varname> is varchar: Denotes type of error."
msgstr ""
+"<varname>errore</varname> è di tipo varchar: descrive il tipo di errore."
#. Tag: para
#: extras_topology.xml:112
@@ -371,6 +420,9 @@ msgid ""
"simple, edge end node geometry mis-match, edge start node geometry mismatch, "
"face overlaps face,face within face,"
msgstr ""
+"Gli errori descritti sono: coincident nodes, edge crosses node, edge not "
+"simple, edge end node geometry mis-match, edge start node geometry mismatch, "
+"face overlaps face,face within face,"
#. Tag: para
#: extras_topology.xml:115
@@ -379,6 +431,8 @@ msgid ""
"<varname>id1</varname> is an integer: Denotes identifier of edge / face / "
"nodes in error."
msgstr ""
+"<varname>id1</varname> è un numero intero: Denota l'identificativo di edge / "
+"face / nodes nell'errore."
#. Tag: para
#: extras_topology.xml:118
@@ -387,6 +441,8 @@ msgid ""
"<varname>id2</varname> is an integer: For errors that involve 2 objects "
"denotes the secondary edge / or node"
msgstr ""
+"<varname>id2</varname> è un numero intero: Per errori che coinvolgono 2 "
+"oggetti denota l'identificativo del secondo edge / face / nodes"
#. Tag: para
#: extras_topology.xml:134
@@ -397,18 +453,23 @@ msgid ""
"table columns. The distinction between a domain and a type is that a domain "
"is an existing type with a check constraint bound to it."
msgstr ""
+"Questa sezione contiene una lista dei domini PostgreSQL installati dalla "
+"Topologia PostGIS. I domini possono essere usati come tipo di dato per gli "
+"oggetti ritornati da alcune funzioni o utilizzati come colonne di tabelle. "
+"La distinzione tra un dominio e un tipo è che un dominio è un tipo esistente "
+"con dei vincoli di controllo associati."
#. Tag: title
#: extras_topology.xml:139
#, no-c-format
msgid "Topology Domains"
-msgstr ""
+msgstr "Domini Topologici"
#. Tag: refname
#: extras_topology.xml:143
#, no-c-format
msgid "TopoElement"
-msgstr ""
+msgstr "TopoElement"
#. Tag: refpurpose
#: extras_topology.xml:144
@@ -416,6 +477,8 @@ msgstr ""
msgid ""
"An array of 2 integers generally used to identify a TopoGeometry component."
msgstr ""
+"Una array di due interi generalmente usata per identificare una componente "
+"di una TopoGeometry."
#. Tag: para
#: extras_topology.xml:148
@@ -424,6 +487,8 @@ msgid ""
"An array of 2 integers used to represent one component of a simple or "
"hierarchical <xref linkend=\"topogeometry\"/>."
msgstr ""
+"Una array di due interi usata per rapresentare una componente di una <xref "
+"linkend=\"topogeometry\"/> semplice o gerarchica."
#. Tag: para
#: extras_topology.xml:152
@@ -435,6 +500,12 @@ msgid ""
"TopoGeometry the first element of the array represents the identifier of a "
"child TopoGeometry and the second element represents its layer identifier."
msgstr ""
+"Nel caso di una TopoGeometry semplice il primo elemento dell'array "
+"rappresenta l'identificativo della primitiva topologica ed il secondo "
+"elemento rappresenta il suo tipo (1:node, 2:edge, 3:face). Nel caso di una "
+"TopoGeometry gerarchica il primo elemento dell'array rappresenta "
+"l'identificativo di una TopoGeometry figlia e il secondo elemento "
+"rappresenta l'identificativo del rispettivo layer."
#. Tag: para
#: extras_topology.xml:161
@@ -444,6 +515,9 @@ msgid ""
"come from the same child layer, as specified in the topology.layer record "
"for the layer of the TopoGeometry being defined."
msgstr ""
+"Per ogni TopoGeometry gerarchica tutti gli elementi TopoGeometry figli "
+"verranno dallo stesso layer figlio, come specificato nel record della "
+"tabella topology.layer relativo al layer della TopoGeometry definita."
#. Tag: title
#: extras_topology.xml:170 extras_topology.xml:198 extras_topology.xml:289
@@ -476,6 +550,11 @@ msgid ""
"----+------\n"
" 1 | 2"
msgstr ""
+"SELECT te[1] AS id, te[2] AS type FROM\n"
+"( SELECT ARRAY[1,2]::topology.topoelement AS te ) f;\n"
+" id | type\n"
+"----+------\n"
+" 1 | 2"
#. Tag: programlisting
#: extras_topology.xml:172
@@ -502,6 +581,13 @@ msgid ""
"ERROR: value for domain topology.topoelement violates check constraint "
"\"dimensions\""
msgstr ""
+"-- Esempio di cosa succede se provi a usare un'array di 3 elementi come "
+"topoelement\n"
+"-- NOTA: un topoement deve essere un'array di 2 elementi, quindi il "
+"tentativo fallisce il controllo di dimensionalità\n"
+"SELECT ARRAY[1,2,3]::topology.topoelement;\n"
+"ERROR: value for domain topology.topoelement violates check constraint "
+"\"dimensions\""
#. Tag: para
#: extras_topology.xml:178
@@ -511,6 +597,9 @@ msgid ""
"<xref linkend=\"TopoGeom_addElement\"/>, <xref linkend=\"TopoGeom_remElement"
msgstr ""
+", <xref linkend=\"topoelementarray\"/>, <xref linkend=\"topogeometry\"/>, "
+"<xref linkend=\"TopoGeom_addElement\"/>, <xref linkend=\"TopoGeom_remElement"
#. Tag: refname
#: extras_topology.xml:190
@@ -522,7 +611,7 @@ msgstr "TopoElementArray"
#: extras_topology.xml:191
#, no-c-format
msgid "An array of TopoElement objects."
-msgstr ""
+msgstr "Un'array di oggetti di tipo TopoElement."
#. Tag: para
#: extras_topology.xml:195
@@ -531,6 +620,8 @@ msgid ""
"An array of 1 or more TopoElement objects, generally used to pass around "
"components of TopoGeometry objects."
msgstr ""
+"Un'array di 1 o più oggetti di tipo TopoElement, generalmente usata per "
+"trasferire i componenti di oggetti di tipo TopoGeometry."
#: extras_topology.xml:199
@@ -555,6 +646,24 @@ msgid ""
"--------------------------------------------------------------------------\n"
"{{1,1},{1,2},{1,3},{2,1},{2,2},{2,3},{3,1},{3,2},{3,3},{4,1},{4,2},{4,3}}"
msgstr ""
+"SELECT '{{1,2},{4,3}}'::topology.topoelementarray As tea;\n"
+" tea\n"
+"-------\n"
+"{{1,2},{4,3}}\n"
+"\n"
+"-- equivalente più verbosa --\n"
+"SELECT ARRAY[ARRAY[1,2], ARRAY[4,3]]::topology.topoelementarray As tea;\n"
+"\n"
+" tea\n"
+"-------\n"
+"{{1,2},{4,3}}\n"
+"\n"
+"-- uso della funzione di aggregazione inclusa nella topologia --\n"
+"SELECT topology.TopoElementArray_Agg(ARRAY[e,t]) As tea\n"
+" FROM generate_series(1,4) As e CROSS JOIN generate_series(1,3) As t;\n"
+" tea\n"
+"--------------------------------------------------------------------------\n"
+"{{1,1},{1,2},{1,3},{2,1},{2,2},{2,3},{3,1},{3,2},{3,3},{4,1},{4,2},{4,3}}"
#: extras_topology.xml:200
@@ -585,12 +694,15 @@ msgid ""
"This section lists the Topology functions for building new Topology schemas, "
"validating topologies, and managing TopoGeometry Columns"
msgstr ""
+"Questa sezione fornisce una lista delle funzioni topologiche usate per "
+"costruire nuovi schemi topologici, validare le topologie e gestire le "
+"colonne di tipo TopoGeometry"
#. Tag: title
#: extras_topology.xml:220
#, no-c-format
msgid "Topology and TopoGeometry Management"
-msgstr ""
+msgstr "Gestione di topologie e TopoGeometry"
#. Tag: refname
#: extras_topology.xml:223
@@ -605,6 +717,9 @@ msgid ""
"Adds a topogeometry column to an existing table, registers this new column "
"as a layer in topology.layer and returns the new layer_id."
msgstr ""
+"Aggiunge una colonna di tipo TopoGeometry ad una tabella esistente, registra "
+"la nuova colonna come layer nella tabella topology.layer e restituisce il "
+"nuovo layer_id."
#. Tag: funcsynopsis
#: extras_topology.xml:228
@@ -627,6 +742,22 @@ msgid ""
"<paramdef><type>integer </type> <parameter>child_layer</parameter></"
"paramdef> </funcprototype>"
msgstr ""
+"<funcprototype> <funcdef>integer <function>AddTopoGeometryColumn</function></"
+"funcdef> <paramdef><type>varchar </type> "
+"<parameter>topology_name</parameter></paramdef> <paramdef><type>varchar </"
+"type> <parameter>schema_name</parameter></paramdef> <paramdef><type>varchar "
+"</type> <parameter>table_name</parameter></paramdef> <paramdef><type>varchar "
+"</type> <parameter>column_name</parameter></paramdef> "
+"<paramdef><type>varchar </type> <parameter>feature_type</parameter></"
+"paramdef> </funcprototype> <funcprototype> <funcdef>integer "
+"<function>AddTopoGeometryColumn</function></funcdef> <paramdef><type>varchar "
+"</type> <parameter>topology_name</parameter></paramdef> "
+"<paramdef><type>varchar </type> <parameter>schema_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> <parameter>table_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> "
+"<parameter>column_name</parameter></paramdef> <paramdef><type>varchar </"
+"type> <parameter>feature_type</parameter></paramdef> <paramdef><type>integer "
+"</type> <parameter>child_layer</parameter></paramdef> </funcprototype>"
#. Tag: para
#: extras_topology.xml:273
@@ -638,6 +769,12 @@ msgid ""
"also contain type and hierarchy information. We create a layer using the "
"AddTopoGeometryColumn() function:"
msgstr ""
+"Ogni oggetto di tipo TopoGeometry appartiene ad uno specifico Layer di una "
+"specifica Topologia. Prima di creare un oggetto TopoGeometry devi creare il "
+"suo TopologyLayer. Un layer topologico è una associazione tra una tabella di "
+"features e la topologia che viene usata per rappresentarle. Contiene anche "
+"informazioni di tipo e di gerarchia. Creiamo un layer usando la funzione "
+"AddTopoGeometryColumn():"
#. Tag: para
#: extras_topology.xml:275
@@ -646,6 +783,8 @@ msgid ""
"This function will both add the requested column to the table and add a "
"record to the topology.layer table with all the given info."
msgstr ""
+"Questa funzione aggiunge la colonna richiesta alla tabella e aggiunge un "
+"record nella tabella topology.layer con le informazioni fornite."
#. Tag: para
#: extras_topology.xml:276
@@ -656,6 +795,10 @@ msgid ""
"Otherwise this layer will contain hierarchical TopoGeometries (composed by "
"TopoGeometries from the child_layer)."
msgstr ""
+"Se non specifichi [child_layer] (o lo valorizzi come NULL) questo layer "
+"conterrà delle TopoGeometry semplici (composte da elementi topologici "
+"primitivi). Altrimenti questo layer conterrà TopoGeometry gerarchiche ("
+"composte da TopoGeometry del child_layer)."
#. Tag: para
#: extras_topology.xml:279
@@ -664,6 +807,9 @@ msgid ""
"Once the layer is created (its id is returned by the AddTopoGeometryColumn "
"function) you're ready to construct TopoGeometry objects in it"
msgstr ""
+"Una volte che il layer è creato (il suo identificativo è restituito dalla "
+"funzione AddTopoGeometryColumn) sei pronto a costruire degli oggetti "
+"TopoGeometry appartenenti a tale layer"
#. Tag: para
#: extras_topology.xml:280
@@ -671,6 +817,7 @@ msgstr ""
msgid ""
"Valid <varname>feature_type</varname>s are: POINT, LINE, POLYGON, COLLECTION"
msgstr ""
+"<varname>feature_type</varname> validi sono: POINT, LINE, POLYGON, COLLECTION"
#. Tag: para
#: extras_topology.xml:283 extras_topology.xml:329 extras_topology.xml:371
@@ -681,7 +828,7 @@ msgstr ""
#: extras_topology.xml:3124
#, no-c-format
msgid "Availability: 1.?"
-msgstr ""
+msgstr "Disponibilità: 1.?"
#: extras_topology.xml:290
@@ -696,6 +843,15 @@ msgid ""
"SELECT topology.AddTopoGeometryColumn('ma_topo', 'ma', 'parcels', 'topo', "
"'POLYGON');"
msgstr ""
+"-- Nota che per questo esempio abbiamo creato la nostra nuova tabella nello "
+"schema ma_topo\n"
+"-- sebene lo avremmo potuta creare in uno schema differente, nel qual caso\n"
+"-- topology_name e schema_name sarebbero stati differenti\n"
+"CREATE SCHEMA ma;\n"
+"CREATE TABLE ma.parcels(gid serial, parcel_id varchar(20) PRIMARY KEY, "
+"address text);\n"
+"SELECT topology.AddTopoGeometryColumn('ma_topo', 'ma', 'parcels', 'topo', "
+"'POLYGON');"
#: extras_topology.xml:291
@@ -718,6 +874,8 @@ msgid ""
", <xref linkend=\"toTopoGeom\"/>, <xref linkend=\"CreateTopology\"/>, <xref "
"linkend=\"CreateTopoGeom\"/>"
msgstr ""
+", <xref linkend=\"toTopoGeom\"/>, <xref linkend=\"CreateTopology\"/>, <xref "
+"linkend=\"CreateTopoGeom\"/>"
#. Tag: refname
#: extras_topology.xml:308
@@ -733,6 +891,8 @@ msgid ""
"topology.topology table and references to tables in that schema from the "
"geometry_columns table."
msgstr ""
+"Usare con cautela: cancella uno schema topologico e cancella i riferimenti "
+"ad esso dalla tabella topology.topology e dalla vista geometry_columns."
#. Tag: funcprototype
#: extras_topology.xml:315
@@ -756,6 +916,11 @@ msgid ""
"you care about. If the schema does not exist, it just removes reference "
"entries the named schema."
msgstr ""
+"Cancella uno schema topologico e i riferimenti ad esso dalla tabella "
+"topology.topology e dalla vista geometry_columns. Questa funzione dovrebbe "
+"essere USATA CON CAUTELA perché potrebbe distruggere dati importanti. Se lo "
+"schema non esiste, la funzione rimuoverà solamente i riferimenti dalle "
+"tabelle di metadati."
#. Tag: para
#: extras_topology.xml:335
@@ -764,6 +929,8 @@ msgid ""
"Cascade drops the ma_topo schema and removes all references to it in "
"topology.topology and geometry_columns."
msgstr ""
+"Rimuove a cascata lo schema ma_topo e tutti i riferimenti ad esso da "
+"topology.topology e geometry_columns."
#: extras_topology.xml:336
commit 175c59ffd733f1af904f92dee7d3b2ea1e8b299a
Date: Wed Jan 19 11:05:27 2022 +0000
Currently translated at 18.1% (290 of 1600 strings)
Translation: postgis/reference_raster.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_rasterxml/it/
diff --git a/doc/po/it_IT/reference_raster.xml.po b/doc/po/it_IT/reference_raster.xml.po
index 8b774d7cb..851495333 100644
--- a/doc/po/it_IT/reference_raster.xml.po
+++ b/doc/po/it_IT/reference_raster.xml.po
@@ -7,7 +7,7 @@ msgstr ""
"POT-Creation-Date: 2021-12-11 05:14+0000\n"
-"PO-Revision-Date: 2022-01-13 16:44+0000\n"
"reference_rasterxml/it/>\n"
@@ -527,7 +527,7 @@ msgstr "Comportamento"
#: reference_raster.xml:191
#, no-c-format
msgid "geometry"
-msgstr ""
+msgstr "geometry"
#. Tag: entry
#: reference_raster.xml:192
Summary of changes:
doc/po/it_IT/extras_topology.xml.po | 183 +++++++++++++++++++++++++++++++++--
doc/po/it_IT/reference_raster.xml.po | 4 +-
2 files changed, 177 insertions(+), 10 deletions(-)
hooks/post-receive
