[postgis-tickets] [SCM] PostGIS branch out-of-tree-builds updated. 3.2.0-317-g25faf296a
git at osgeo.org
git at osgeo.org
Thu Jan 20 07:04:02 PST 2022
the project "PostGIS".
The branch, out-of-tree-builds has been updated
via 25faf296a62ba40a79dee476b0257146053be410 (commit)
via c35d46d2ec43a1303ab8d95818c9dfc714d295bd (commit)
from ee656108d4515bb857ddef134eae1b4cc7b066e3 (commit)
revisions in full, below.
commit 25faf296a62ba40a79dee476b0257146053be410
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 20 16:02:28 2022 +0100
Drop deprecated -pre.sh file
diff --git a/raster/test/regress/load_outdb-pre.sh b/raster/test/regress/load_outdb-pre.sh
deleted file mode 100755
index 6b05b9e64..000000000
--- a/raster/test/regress/load_outdb-pre.sh
+++ /dev/null
@@ -1,61 +0,0 @@
-SOURCE="${BASH_SOURCE[0]}"
-while [ -h "$SOURCE" ] ; do SOURCE="$(readlink "$SOURCE")"; done
-DIR="$( cd -P "$( dirname "$SOURCE" )" && pwd )"
-FILERASTER="$DIR/loader/testraster.tif"
-# special handling for msys
-CSYS=`uname -o | tr '[:upper:]' '[:lower:]'`
-if [ "$CSYS" == "msys" ]; then
- FILERASTER=`cmd //c echo "${FILERASTER}"`
-fi
-SQL=" \
-WITH foo AS ( \
- SELECT postgis_raster_lib_version() \
-SELECT NULL FROM foo; \
-SET postgis.gdal_enabled_drivers = 'GTiff'; \
-DROP TABLE IF EXISTS raster_outdb_template; \
-CREATE TABLE raster_outdb_template AS \
-SELECT \
- 1 AS rid, \
- ST_AddBand( -- insert all three bands of out-db raster at index 1 \
- ST_MakeEmptyRaster(90, 50, 0., 0., 1, -1, 0, 0, 0), \
- 1, '$FILERASTER'::text, NULL::int[] \
- ) AS rast \
-UNION ALL \
-SELECT \
- 2 AS rid, \
- ST_AddBand( -- append all three bands of out-db raster \
- '$FILERASTER'::text, NULL::int[] \
- ) AS rast \
-UNION ALL \
-SELECT \
- 3 AS rid, \
- ST_AddBand( -- append out-db band 2 \
- ST_AddBand( \
- 1, '8BUI', 1, 0 \
- '$FILERASTER'::text, ARRAY[2]::int[] \
- ) AS rast \
-UNION ALL \
-SELECT \
- 4 AS rid, \
- ST_AddBand( \
- 1, '8BUI', 1, 0 \
- '$FILERASTER'::text, ARRAY[2]::int[], \
- 1, \
- 255 \
- ) AS rast \
-echo "$SQL" > "$DIR/$TEST-pre.sql"
-# no longer needed as "clean" test takes care of it
-#echo "DROP TABLE IF EXISTS raster_outdb_template;" > "$DIR/$TEST-post.sql"
commit c35d46d2ec43a1303ab8d95818c9dfc714d295bd
Date: Thu Jan 20 15:54:05 2022 +0100
Fix REGRESS_INSTALLDIR for out-of-tree raster regress tests
References #5060
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
index a932ab857..6492bb99c 100644
--- a/raster/test/regress/Makefile.in
+++ b/raster/test/regress/Makefile.in
@@ -1,6 +1,6 @@
-# Copyright (c) 2009-2020 Sandro Santilli <strk at kbt.io>
+# Copyright (c) 2009-2022 Sandro Santilli <strk at kbt.io>
# Copyright (c) 2009 Pierre Racine <pierre.racine at sbf.ulaval.ca>
# Copyright (c) 2011 Jorge Arevalo <jorge.arevalo at deimos-space.com>
# Copyright (c) 2011-2013 Regents of the University of California
@@ -26,6 +26,7 @@
top_srcdir = @top_srcdir@
srcdir = @srcdir@
+top_builddir = @top_builddir@
POSTGIS_SRC=../../..
PERL=@PERL@
@@ -37,7 +38,7 @@ PERL=@PERL@
PGSQL_BINDIR=$(shell cd "@PGSQL_BINDIR@" && pwd)
# Where we put our regression installation
-REGRESS_INSTALLDIR=$(POSTGIS_SRC)/regress/00-regress-install
+REGRESS_INSTALLDIR = $(realpath $(top_builddir) )/regress/00-regress-install
# Put path from pg_config into front of search path
Summary of changes:
raster/test/regress/Makefile.in | 5 +--
raster/test/regress/load_outdb-pre.sh | 61 -----------------------------------
2 files changed, 3 insertions(+), 63 deletions(-)
delete mode 100755 raster/test/regress/load_outdb-pre.sh
hooks/post-receive
