[postgis-tickets] [SCM] PostGIS branch out-of-tree-builds updated. 3.2.0-317-ge33e1c852
git at osgeo.org
git at osgeo.org
Thu Jan 20 07:14:21 PST 2022
the project "PostGIS".
The branch, out-of-tree-builds has been updated
discards 25faf296a62ba40a79dee476b0257146053be410 (commit)
via e33e1c85207cbd8fb68b0a9070c1f1282c8cfc9c (commit)
This update added new revisions after undoing existing revisions. That is
to say, the old revision is not a strict subset of the new revision. This
situation occurs when you --force push a change and generate a repository
containing something like this:
* -- * -- B -- O -- O -- O (25faf296a62ba40a79dee476b0257146053be410)
N -- N -- N (e33e1c85207cbd8fb68b0a9070c1f1282c8cfc9c)
When this happens we assume that you've already had alert emails for all
of the O revisions, and so we here report only the revisions in the N
branch from the common base, B.
revisions in full, below.
commit e33e1c85207cbd8fb68b0a9070c1f1282c8cfc9c
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 20 16:02:28 2022 +0100
Drop deprecated -{pre,post}.sh files
diff --git a/raster/test/regress/load_outdb-post.sh b/raster/test/regress/load_outdb-post.sh
deleted file mode 100755
index 914c97b30..000000000
--- a/raster/test/regress/load_outdb-post.sh
+++ /dev/null
@@ -1,6 +0,0 @@
-SOURCE="${BASH_SOURCE[0]}"
-while [ -h "$SOURCE" ] ; do SOURCE="$(readlink "$SOURCE")"; done
-DIR="$( cd -P "$( dirname "$SOURCE" )" && pwd )"
-rm -f "$DIR/$TEST-pre.sql"
-#rm -f "$DIR/$TEST-post.sql"
diff --git a/raster/test/regress/load_outdb-pre.sh b/raster/test/regress/load_outdb-pre.sh
index 6b05b9e64..000000000
--- a/raster/test/regress/load_outdb-pre.sh
+++ /dev/null
@@ -1,61 +0,0 @@
-FILERASTER="$DIR/loader/testraster.tif"
-# special handling for msys
-CSYS=`uname -o | tr '[:upper:]' '[:lower:]'`
-if [ "$CSYS" == "msys" ]; then
- FILERASTER=`cmd //c echo "${FILERASTER}"`
-fi
-SQL=" \
-WITH foo AS ( \
- SELECT postgis_raster_lib_version() \
-SELECT NULL FROM foo; \
-SET postgis.gdal_enabled_drivers = 'GTiff'; \
-DROP TABLE IF EXISTS raster_outdb_template; \
-CREATE TABLE raster_outdb_template AS \
-SELECT \
- 1 AS rid, \
- ST_AddBand( -- insert all three bands of out-db raster at index 1 \
- ST_MakeEmptyRaster(90, 50, 0., 0., 1, -1, 0, 0, 0), \
- 1, '$FILERASTER'::text, NULL::int[] \
- ) AS rast \
-UNION ALL \
-SELECT \
- 2 AS rid, \
- ST_AddBand( -- append all three bands of out-db raster \
- '$FILERASTER'::text, NULL::int[] \
- ) AS rast \
-UNION ALL \
-SELECT \
- 3 AS rid, \
- ST_AddBand( -- append out-db band 2 \
- ST_AddBand( \
- 1, '8BUI', 1, 0 \
- '$FILERASTER'::text, ARRAY[2]::int[] \
- ) AS rast \
-UNION ALL \
-SELECT \
- 4 AS rid, \
- ST_AddBand( \
- 1, '8BUI', 1, 0 \
- '$FILERASTER'::text, ARRAY[2]::int[], \
- 1, \
- 255 \
- ) AS rast \
-echo "$SQL" > "$DIR/$TEST-pre.sql"
-# no longer needed as "clean" test takes care of it
-#echo "DROP TABLE IF EXISTS raster_outdb_template;" > "$DIR/$TEST-post.sql"
Summary of changes:
raster/test/regress/load_outdb-post.sh | 6 ------
1 file changed, 6 deletions(-)
delete mode 100755 raster/test/regress/load_outdb-post.sh
hooks/post-receive
