[postgis-tickets] [SCM] PostGIS branch out-of-tree-builds updated. 3.2.0-321-gbd233ac14
Thu Jan 20 10:47:40 PST 2022
the project "PostGIS".
The branch, out-of-tree-builds has been updated
       via  bd233ac1489c69678eebd6dd94acca394973c76e (commit)
       via  dde0fce1bd6d8f32b65d719983cb97fa811b83cf (commit)
      from  2b210f4a9a2d9400f90ad37d927bec8a893acf1e (commit)
revisions in full, below.
commit bd233ac1489c69678eebd6dd94acca394973c76e
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 20 19:47:29 2022 +0100
    Fix check-unit under doc/
diff --git a/doc/Makefile.in b/doc/Makefile.in
index f63f08eeb..d15ba8190 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -432,7 +432,7 @@ ifeq ($(XMLLINT),)
 check-unit: requirements_not_met_xmllint
 else
 check-unit: $(XML_INPUTS)
-	$(XMLLINT) --loaddtd --xinclude --valid postgis-out.xml > /dev/null
+	$(XMLLINT) --loaddtd --path $(srcdir) --xinclude --valid postgis-out.xml > /dev/null
 endif
 check-localized:
commit dde0fce1bd6d8f32b65d719983cb97fa811b83cf
Date:   Thu Jan 20 19:43:18 2022 +0100
    Fix build of unit tests of loader
diff --git a/loader/cunit/Makefile.in b/loader/cunit/Makefile.in
index 429fa8521..a6f842a73 100644
--- a/loader/cunit/Makefile.in
+++ b/loader/cunit/Makefile.in
@@ -2,6 +2,8 @@
 # * PostGIS - Spatial Types for PostgreSQL
 # * http://postgis.net
+# * Copyright 2022 Sandro Santilli <strk at kbt.io>
 # * Copyright 2008 Paul Ramsey, Mark Cave-Ayland
 # * This is free software; you can redistribute and/or modify it under
@@ -10,13 +12,22 @@
 top_builddir = @top_builddir@
+srcdir = @srcdir@
+top_srcdir = @top_srcdir@
 CC=@CC@
 CFLAGS=@CFLAGS@
 SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
 CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
-CUNIT_CPPFLAGS=-I.. @CUNIT_CPPFLAGS@ @CPPFLAGS@
+CUNIT_CPPFLAGS = \
+	-I$(srcdir)/.. \
+	-I$(top_builddir)/liblwgeom \
+	-I$(top_srcdir)/liblwgeom \
+	-I.. \
+	@CUNIT_CPPFLAGS@ \
+	@CPPFLAGS@
 # GTK includes and libraries
 GTK_CFLAGS = @GTK_CFLAGS@ @IGE_MAC_CFLAGS@
@@ -28,7 +39,7 @@ PGSQL_FE_CPPFLAGS=@PGSQL_FE_CPPFLAGS@
 PGSQL_FE_LDFLAGS=@PGSQL_FE_LDFLAGS@
 # liblwgeom
-LIBLWGEOM=../../liblwgeom/.libs/liblwgeom.la
+LIBLWGEOM = $(top_builddir)/liblwgeom/.libs/liblwgeom.la
 # iconv flags
 ICONV_LDFLAGS=@ICONV_LDFLAGS@
@@ -48,6 +59,8 @@ CFLAGS += $(GETTEXT_CFLAGS) $(ICONV_CFLAGS) $(PROJ_CFLAGS)
 # Build full linking line
 LDFLAGS = $(GEOS_LDFLAGS) $(GETTEXT_LDFLAGS) $(PGSQL_FE_LDFLAGS) $(ICONV_LDFLAGS) $(CUNIT_LDFLAGS) $(PROJ_LDFLAGS)
+VPATH = $(srcdir)
 # Object files
 OBJS=	\
 	cu_pgsql2shp.o \
Summary of changes:
 doc/Makefile.in          |  2 +-
 loader/cunit/Makefile.in | 17 +++++++++++++++--
 2 files changed, 16 insertions(+), 3 deletions(-)
hooks/post-receive
