[postgis-tickets] [PostGIS] #5062: check_test_enabled is disabled
trac at osgeo.org
Thu Jan 20 12:31:27 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: master
Keywords: |
Since commit [11dc1c60d8dbf5e534d1d32b1731038d92bf2be2/git] and now that I
run it manually it found problems:
The following tests are available but not enabled in:
- topology/test/tests.mk:
topology/test/regress/topogeometry_srid
topology/test/regress/findlayer
topology/test/regress/st_removeisoedge
Paul: how about filing a ticket for that MacOS issue ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5062>
