[postgis-tickets] [PostGIS] #5062: check_test_enabled is disabled
PostGIS trac at osgeo.org
Thu Jan 20 12:58:46 PST 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"8828402ccb84023294ae0e1e0292d3cb2b0841ca/git" 8828402/git]:
 #!CommitTicketReference repository="git"
 revision="8828402ccb84023294ae0e1e0292d3cb2b0841ca"
 Enable tests found disabled by `make check_test_enabled`
 CI was not catching this because the test was disabled
 in commit 11dc1c60d8dbf5e534d1d32b1731038d92bf2be2
 see #5062
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5062#comment:1>
