[postgis-tickets] [PostGIS] #5062: check_test_enabled is disabled
trac at osgeo.org
Thu Jan 20 13:10:05 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"bc5378234fc8970292639306c6ab40132fcff3cd/git"
bc537823/git]:
#!CommitTicketReference repository="git"
revision="bc5378234fc8970292639306c6ab40132fcff3cd"
Enable tests found disabled by `make check_test_enabled`
CI was not catching this because the test was disabled
in commit 11dc1c60d8dbf5e534d1d32b1731038d92bf2be2
see #5062
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5062#comment:2>
