[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-332-g7d4178c6a
Thu Jan 20 12:57:17 PST 2022
the project "PostGIS".
       via  7d4178c6a24d504ef257850f0ac727515f63f039 (commit)
       via  f9ddee5779ce69f7b21845b9c8bed1fdcc95c724 (commit)
       via  426498749af42e378f7db9ea6264e8ca617d0a0b (commit)
      from  91eb4c577b842978e37294871a91952765448749 (commit)
revisions in full, below.
commit 7d4178c6a24d504ef257850f0ac727515f63f039
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jan 20 15:57:12 2022 -0500
    Update pot and pos based on recent changes
diff --git a/doc/po/de/reference_accessor.xml.po b/doc/po/de/reference_accessor.xml.po
index 3dca4305e..202db22f8 100644
--- a/doc/po/de/reference_accessor.xml.po
+++ b/doc/po/de/reference_accessor.xml.po
@@ -5,8 +5,8 @@
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
-"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2021-09-11 01:55+0000\n"
+"Report-Msgid-Bugs-To: http://bugs.kde.org\n"
+"POT-Creation-Date: 2022-01-20 20:56+0000\n"
 "PO-Revision-Date: 2019-03-11 09:12+0000\n"
 "Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language-Team: German (http://www.transifex.com/postgis/postgis/language/"
@@ -2167,7 +2167,7 @@ msgstr ""
 #, fuzzy, no-c-format
 msgid ""
 "To extract all elements of a geometry, <xref linkend=\"ST_Dump\"/> is more "
-"efficient and works for atomoic geometrie."
+"efficient and works for atomic geometries."
 msgstr ""
 "Falls Sie alle Geometrien einer Geometrie entnehmen wollen, so ist ST_Dump "
 "wesentlich leistungsfähiger und es funktioniert auch mit Einzelgeometrien."
@@ -5032,11 +5032,9 @@ msgstr ""
 msgid ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
-#, no-c-format
 #~ msgid "Only works with POLYGON geometry types"
 #~ msgstr "Funktioniert nur mit dem Geometrietyp POLYGON"
-#, no-c-format
 #~ msgid ""
 #~ "Return the 1-based Nth geometry if the geometry is a GEOMETRYCOLLECTION, "
 #~ "(MULTI)POINT, (MULTI)LINESTRING, MULTICURVE or (MULTI)POLYGON, "
@@ -5047,7 +5045,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "MULTICURVE oder (MULTI)POLYGON, POLYHEDRALSURFACE handelt. Anderenfalls "
 #~ "wird NULL zurückgegeben."
-#, fuzzy, no-c-format
+#, fuzzy
 #~ msgid ""
 #~ "Returns the Nth interior linestring ring of the polygon geometry. Returns "
 #~ "NULL if the geometry is not a polygon or the given N is out of range. The "
@@ -5058,7 +5056,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "Polygon handelt, oder sich das angegebene N außerhalb des zulässigen "
 #~ "Bereiches befindet. Der Zeiger beginnt mit der Zahl 1."
-#, no-c-format
 #~ msgid ""
 #~ ", <xref linkend=\"ST_Collect\"/>, <xref linkend=\"ST_Dump\"/>, <xref "
 #~ "linkend=\"ST_NumInteriorRing\"/>,"
diff --git a/doc/po/es/reference_accessor.xml.po b/doc/po/es/reference_accessor.xml.po
index 6eec78fbc..0dbc49385 100644
--- a/doc/po/es/reference_accessor.xml.po
+++ b/doc/po/es/reference_accessor.xml.po
@@ -7,8 +7,8 @@
 msgid ""
 msgstr ""
 "PO-Revision-Date: 2018-07-23 18:00+0000\n"
 "Last-Translator: nramire1 nramire1\n"
 "Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/"
@@ -2151,7 +2151,7 @@ msgstr ""
 msgid ""
 msgstr ""
 "Si quieres extraer todas las geometrías de una geometría, ST_Dump es mas "
 "eficiente y funcionará con geometrías simples."
@@ -4998,7 +4998,7 @@ msgstr ""
+#, fuzzy
 #~ msgid ""
 #~ "Returns the last point of a LINESTRING as a POINT. Returns <varname>NULL</"
 #~ "varname> if the input is not a LINESTRING."
@@ -5007,7 +5007,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "como <varname>POINT</varname> o <varname>NULL</varname> si el parametro "
 #~ "de entrada no es una <varname>LINESTRING</varname>."
-#, no-c-format
 #~ msgid ""
 #~ "postgis=# SELECT ST_AsText(ST_EndPoint('LINESTRING(1 1, 2 2, 3 3)'::"
 #~ "geometry));\n"
@@ -5049,11 +5048,9 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ " POINT(0 0 5)\n"
 #~ "(1 row)"
-#, no-c-format
 #~ msgstr "Solo funciona con geometrias de tipo POLYGON"
-#, no-c-format
 #~ msgid ""
@@ -5063,7 +5060,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "GEOMETRYCOLLECTION, un (MULTI)POINT, una (MULTI)LINESTRING, una "
 #~ "MULTICURVE o un (MULTI)POLYGON, una POLYHEDRALSURFACE si no devuelve NULL."
+#, fuzzy
 #~ msgid ""
@@ -5073,7 +5070,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "NULL si la geometría no es un polígono o el indice N dado esta fuera de "
 #~ "rango. El indice empieza en 1."
-#, no-c-format
 #~ msgid ""
@@ -5081,7 +5077,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
-#, no-c-format
 #~ msgid ""
 #~ "SELECT ST_AsText(ST_StartPoint('LINESTRING(0 1, 0 2)'::geometry));\n"
 #~ " st_astext\n"
diff --git a/doc/po/fr/reference_accessor.xml.po b/doc/po/fr/reference_accessor.xml.po
index 60201d19d..a0dff6b19 100644
--- a/doc/po/fr/reference_accessor.xml.po
+++ b/doc/po/fr/reference_accessor.xml.po
@@ -11,8 +11,8 @@
 msgid ""
 msgstr ""
 "Last-Translator: Vincent Picavet <vincent.ml at oslandia.com>\n"
 "Language-Team: French (http://www.transifex.com/postgis/postgis/language/"
@@ -1939,7 +1939,7 @@ msgstr ""
 msgid ""
 msgstr ""
 "Si toutes les géométries composant une géométrie doivent être extraites, il "
 "faut mieux utiliser la fonction ST_Dump, qui est plus efficace et accepte "
@@ -4502,7 +4502,7 @@ msgstr ""
+#, fuzzy
 #~ msgid ""
@@ -4511,7 +4511,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "forme d'un <varname>POINT</varname>, ou NULL si le paramètre n'est pas "
 #~ "une <varname>LINESTRING</varname>."
-#, no-c-format
 #~ msgid ""
 #~ "geometry));\n"
@@ -4553,11 +4552,9 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "(1 row)"
-#, no-c-format
 #~ msgstr "Ne fonctionne qu'avec des géométries POLYGON"
-#, no-c-format
 #~ msgid ""
@@ -4568,7 +4565,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "(MULTI)LINESTRING, MULTICURVE ou (MULTI)POLYGON, POLYHEDRALSURFACE. "
 #~ "Renvoie NULL dans les autres cas."
+#, fuzzy
 #~ msgid ""
@@ -4578,7 +4575,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "Renvoie NULL si la géométrie n'est pas un polygone ou si l'index ne "
 #~ "correspond pas à un intérieur. L'index démarre à 1."
-#, no-c-format
 #~ msgid ""
diff --git a/doc/po/it_IT/reference_accessor.xml.po b/doc/po/it_IT/reference_accessor.xml.po
index 02c2718e6..d4c7c2898 100644
--- a/doc/po/it_IT/reference_accessor.xml.po
+++ b/doc/po/it_IT/reference_accessor.xml.po
@@ -6,8 +6,8 @@
 msgid ""
 msgstr ""
 "PO-Revision-Date: 2022-01-19 10:14+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
@@ -444,8 +444,8 @@ msgid ""
 "----------\n"
 "MULTIPOINT(-1 1 1,1 1 0.75)"
 msgstr ""
-"SELECT ST_AsText(ST_Boundary(ST_GeomFromText('LINESTRING(1 1,0 0, -1 1)')));"
-"\n"
+"SELECT ST_AsText(ST_Boundary(ST_GeomFromText('LINESTRING(1 1,0 0, -1 "
+"1)')));\n"
 "st_astext\n"
 "-----------\n"
 "MULTIPOINT(1 1,-1 1)\n"
@@ -632,8 +632,8 @@ msgid ""
 "                        --result--\n"
 "                                2"
 msgstr ""
-"SELECT ST_CoordDim('CIRCULARSTRING(1 2 3, 1 3 4, 5 6 7, 8 9 10, 11 12 13)');"
-"\n"
+"SELECT ST_CoordDim('CIRCULARSTRING(1 2 3, 1 3 4, 5 6 7, 8 9 10, 11 12 "
+"13)');\n"
 "                        ---result--\n"
 "                                3\n"
 "\n"
@@ -1900,7 +1900,7 @@ msgstr ""
 msgid ""
 msgstr ""
 "Se volete estrarre tutte le geometria, ST_Dump è più efficiente e funziona "
 "anche nel caso di geometrie singole."
@@ -2284,9 +2284,9 @@ msgid ""
 "SQL-MM defines the result of <function>ST_IsClosed(<varname>NULL</varname>)</"
 "function> to be 0, while PostGIS returns <varname>NULL</varname>."
 msgstr ""
-"SQL-MM definisce il risultato di "
-"<function>ST_IsClosed(<varname>NULL</varname>)</function> come 0, mentre "
-"PostGIS restituisce <varname>NULL</varname>."
+"SQL-MM definisce il risultato di <function>ST_IsClosed(<varname>NULL</"
+"varname>)</function> come 0, mentre PostGIS restituisce <varname>NULL</"
+"varname>."
 #. Tag: title
 #: reference_accessor.xml:997
@@ -2518,8 +2518,8 @@ msgstr ""
 " t\n"
 "(1 row)\n"
 "\n"
-"postgis=# SELECT ST_IsCollection('GEOMETRYCOLLECTION(POINT(0 0))'::geometry);"
-"\n"
+"postgis=# SELECT ST_IsCollection('GEOMETRYCOLLECTION(POINT(0 0))'::"
+"geometry);\n"
 " st_iscollection\n"
 "-------------\n"
 " t\n"
@@ -2638,8 +2638,8 @@ msgstr ""
 " f\n"
 "(1 row)\n"
 "\n"
-" SELECT ST_IsEmpty(ST_GeomFromText('POLYGON((1 2, 3 4, 5 6, 1 2))')) = false;"
-"\n"
+" SELECT ST_IsEmpty(ST_GeomFromText('POLYGON((1 2, 3 4, 5 6, 1 2))')) = "
+"false;\n"
 " ?column?\n"
 "----------\n"
 " t\n"
@@ -2782,10 +2782,10 @@ msgid ""
 "linkend=\"ST_IsSimple\"/> (does not self intersect)."
 msgstr ""
 "Restituisce <varname>TRUE</varname> se questa <varname>LINESTRING</varname> "
-"è sia <xref linkend=\"ST_IsClosed\"/> "
-"(<function>ST_StartPoint(<parameter>g</parameter>)</function> <function>~=</"
-"function> <function>ST_Endpoint(<parameter>g</parameter>)</function>) che "
-"<xref linkend=\"ST_IsSimple\"/> (non interseca se stessa)."
+"è sia <xref linkend=\"ST_IsClosed\"/> (<function>ST_StartPoint(<parameter>g</"
+"parameter>)</function> <function>~=</function> "
+"<function>ST_Endpoint(<parameter>g</parameter>)</function>) che <xref "
+"linkend=\"ST_IsSimple\"/> (non interseca se stessa)."
 #. Tag: para
 #: reference_accessor.xml:1278
@@ -2993,8 +2993,8 @@ msgid ""
 ", <xref linkend=\"ST_X\"/>, <xref linkend=\"ST_Y\"/>, <xref linkend=\"ST_Z\"/"
 msgstr ""
-", <xref linkend=\"ST_X\"/>, <xref linkend=\"ST_Y\"/>, <xref linkend=\"ST_Z\""
+", <xref linkend=\"ST_X\"/>, <xref linkend=\"ST_Y\"/>, <xref linkend=\"ST_Z\"/"
 #. Tag: refname
 #: reference_accessor.xml:1397
@@ -3155,7 +3155,8 @@ msgstr ""
 #: reference_accessor.xml:1470
 #, no-c-format
 msgid ", <xref linkend=\"ST_Dimension\"/>, <xref linkend=\"ST_GeomFromEWKT\"/>"
-msgstr ", <xref linkend=\"ST_Dimension\"/>, <xref linkend=\"ST_GeomFromEWKT\"/>"
+msgstr ""
+", <xref linkend=\"ST_Dimension\"/>, <xref linkend=\"ST_GeomFromEWKT\"/>"
 #. Tag: refname
 #: reference_accessor.xml:1476
@@ -4394,11 +4395,9 @@ msgstr ""
-#, no-c-format
 #~ msgstr "Funziona solamente con le geometrie di tipo POLYGON"
-#, no-c-format
 #~ msgid ""
@@ -4408,7 +4407,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "GEOMETRYCOLLECTION, (MULTI)POINT, (MULTI)LINESTRING, MULTICURVE o "
 #~ "(MULTI)POLYGON, POLYHEDRALSURFACE. Altrimenti restituisce il valore NULL."
-#, no-c-format
 #~ msgid ""
diff --git a/doc/po/ja/administration.xml.po b/doc/po/ja/administration.xml.po
index f97880a44..21ccebcfb 100644
--- a/doc/po/ja/administration.xml.po
+++ b/doc/po/ja/administration.xml.po
@@ -961,14 +961,10 @@ msgstr ""
 "psql -h localhost -p 5432 -U postgres -d newdb -f olddb-without-IGN.sql  2> "
 "errors.txt"
-#. Tag: programlisting
-#: administration.xml:172
-msgid "can't drop ... because postgis extension depends on it"
-msgstr "can't drop ... because postgis extension depends on it"
+#, fuzzy
+#~ msgid "can't drop ... because postgis extension depends on it"
+#~ msgstr "can't drop ... because postgis extension depends on it"
-#: administration.xml:229
-msgid "No migration path defined for ... to &last_release_version;"
-msgstr "No migration path defined for ... to &last_release_version;"
+#, fuzzy
+#~ msgid "No migration path defined for ... to &last_release_version;"
+#~ msgstr "No migration path defined for ... to &last_release_version;"
diff --git a/doc/po/ja/reference_accessor.xml.po b/doc/po/ja/reference_accessor.xml.po
index cef4e081a..c31742c82 100644
--- a/doc/po/ja/reference_accessor.xml.po
+++ b/doc/po/ja/reference_accessor.xml.po
@@ -5,8 +5,8 @@
 msgid ""
 msgstr ""
 "PO-Revision-Date: 2018-07-24 02:44+0000\n"
 "Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/"
@@ -2131,7 +2131,7 @@ msgstr ""
 msgid ""
 msgstr ""
 "一つのジオメトリから全てのジオメトリを抽出したい場合は、ST_Dumpを使う方が効果"
 "的ですし、単一ジオメトリにも対応しています。"
@@ -4934,11 +4934,9 @@ msgstr ""
-#, no-c-format
 #~ msgstr "POLYGONタイプでのみ動作します。"
-#, no-c-format
 #~ msgid ""
@@ -4948,7 +4946,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "(MULTI)POLYGON, POLYHEDRALSURFACEの場合には、1始まりでN番目のジオメトリを"
 #~ "返します。それ以外の場合にはNULLを返します。"
+#, fuzzy
 #~ msgid ""
@@ -4957,7 +4955,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "ポリゴンのN番目の内環となるラインストリングを返します。ジオメトリがポリゴ"
 #~ "ンでないかNが範囲外の場合はNULLを返します。1始まりです。"
-#, no-c-format
 #~ msgid ""
diff --git a/doc/po/ko_KR/reference_accessor.xml.po b/doc/po/ko_KR/reference_accessor.xml.po
index e2e3729ae..8bc85ceb1 100644
--- a/doc/po/ko_KR/reference_accessor.xml.po
+++ b/doc/po/ko_KR/reference_accessor.xml.po
@@ -7,8 +7,8 @@
 msgid ""
 msgstr ""
 "Last-Translator: Regina Obe\n"
 "Language-Team: Korean (Korea) (http://www.transifex.com/postgis/postgis/"
@@ -2129,7 +2129,7 @@ msgstr ""
 msgid ""
 msgstr ""
 "모든 도형들을 추출하고자 한다면 ST_Dump 함수가 더 효율적이며, 단일 도형에 대"
 "해서도 작동할 것입니다."
@@ -4932,11 +4932,9 @@ msgstr ""
-#, no-c-format
 #~ msgstr "오직 <varname>POLYGON</varname> 도형 유형만 입력받습니다."
-#, no-c-format
 #~ msgid ""
@@ -4946,7 +4944,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "(multicurve) 또는 (멀티)폴리곤이나 다면체 표면일 경우 1-기반 N번째 도형을 "
 #~ "반환하며, 그 외의 경우 NULL을 반환합니다."
+#, fuzzy
 #~ msgid ""
@@ -4956,7 +4954,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "니거나 주어진 N이 범위(range)를 벗어난 경우 NULL을 반환합니다. 인덱스는 1"
 #~ "에서 시작합니다."
-#, no-c-format
 #~ msgid ""
diff --git a/doc/po/pl/reference_accessor.xml.po b/doc/po/pl/reference_accessor.xml.po
index 4307bf369..92f7bb282 100644
--- a/doc/po/pl/reference_accessor.xml.po
+++ b/doc/po/pl/reference_accessor.xml.po
@@ -4,8 +4,8 @@
 msgid ""
 msgstr ""
 "Last-Translator: Milena Nowotarska <do.milenki at gmail.com>\n"
 "Language-Team: Polish (http://www.transifex.com/postgis/postgis/language/"
@@ -1744,7 +1744,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/pt_BR/reference_accessor.xml.po b/doc/po/pt_BR/reference_accessor.xml.po
index 95500d756..c02ee1777 100644
--- a/doc/po/pt_BR/reference_accessor.xml.po
+++ b/doc/po/pt_BR/reference_accessor.xml.po
@@ -7,8 +7,8 @@
 msgid ""
 msgstr ""
 "Last-Translator: Poliana Palhares <p.palhares at plamu.com.br>\n"
 "Language-Team: Portuguese (Brazil) (http://www.transifex.com/postgis/postgis/"
@@ -2152,7 +2152,7 @@ msgstr ""
 msgid ""
 msgstr ""
 "Se você quiser extrair todas as geometrias, de uma geometria, ST_Dump é mais "
 "eficiente e também funcionará para geometrias singulares."
@@ -4992,11 +4992,9 @@ msgstr ""
-#, no-c-format
 #~ msgstr "Funciona somente com geometrias tipo POLÍGONO."
-#, no-c-format
 #~ msgid ""
@@ -5006,7 +5004,7 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "GEOMETRYCOLLECTION, (MULTI)POINT, (MULTI)LINESTRING, MULTICURVE ou "
 #~ "(MULTI)POLYGON, POLYHEDRALSURFACE. Senão, retorna NULA. "
+#, fuzzy
 #~ msgid ""
@@ -5016,7 +5014,6 @@ msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 #~ "geometria não for um polígono ou o dado N está fora da extensão. index "
 #~ "começa em 1. "
-#, no-c-format
 #~ msgid ""
diff --git a/doc/po/ru/reference_accessor.xml.po b/doc/po/ru/reference_accessor.xml.po
index 0cf377ae2..4eafc8028 100644
--- a/doc/po/ru/reference_accessor.xml.po
+++ b/doc/po/ru/reference_accessor.xml.po
@@ -4,8 +4,8 @@
 msgid ""
 msgstr ""
 "PO-Revision-Date: 2021-09-11 03:51+0000\n"
 "Language-Team: Russian (http://www.transifex.com/postgis/postgis/language/"
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/templates/reference_accessor.xml.pot b/doc/po/templates/reference_accessor.xml.pot
index 41ec7133b..396f9899c 100644
--- a/doc/po/templates/reference_accessor.xml.pot
+++ b/doc/po/templates/reference_accessor.xml.pot
@@ -5,8 +5,8 @@
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -1740,7 +1740,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
commit f9ddee5779ce69f7b21845b9c8bed1fdcc95c724
Merge: 91eb4c577 426498749
Date:   Thu Jan 20 15:54:03 2022 -0500
    Merge remote-tracking branch 'nertzy/patch-1'
commit 426498749af42e378f7db9ea6264e8ca617d0a0b
Author: Grant Hutchins <github at nertzy.com>
Date:   Wed Jan 19 11:54:15 2022 -0600
    Fix typo in docs
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 4158cfc59..1c01a721d 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -1223,7 +1223,7 @@ LINESTRING(0 0 1,1 1 1,1 2 1,1 1 1,0 0 1)
 		</note>
 		<note>
-		  <para>To extract all elements of a geometry, <xref linkend="ST_Dump" /> is more efficient and works for atomoic geometrie.</para>
+		  <para>To extract all elements of a geometry, <xref linkend="ST_Dump" /> is more efficient and works for atomic geometries.</para>
 		</note>
 		<para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
 		<para>Changed: 2.0.0 Prior versions would return NULL for singular geometries.  This was changed to return the geometry for ST_GeometryN(..,1) case.</para>
Summary of changes:
 doc/po/de/reference_accessor.xml.po         | 11 +++----
 doc/po/es/reference_accessor.xml.po         | 15 ++++------
 doc/po/fr/reference_accessor.xml.po         | 14 ++++-----
 doc/po/it_IT/reference_accessor.xml.po      | 46 ++++++++++++++---------------
 doc/po/ja/administration.xml.po             | 16 ++++------
 doc/po/ja/reference_accessor.xml.po         | 11 +++----
 doc/po/ko_KR/reference_accessor.xml.po      | 11 +++----
 doc/po/pl/reference_accessor.xml.po         |  6 ++--
 doc/po/pt_BR/reference_accessor.xml.po      | 11 +++----
 doc/po/ru/reference_accessor.xml.po         |  6 ++--
 doc/po/templates/reference_accessor.xml.pot |  6 ++--
 doc/reference_accessor.xml                  |  2 +-
 12 files changed, 64 insertions(+), 91 deletions(-)
hooks/post-receive
