[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-333-gd2358992e
Thu Jan 20 12:57:32 PST 2022
the project "PostGIS".
       via  d2358992e0918633adf96875e5731d804638fe9c (commit)
      from  7d4178c6a24d504ef257850f0ac727515f63f039 (commit)
revisions in full, below.
commit d2358992e0918633adf96875e5731d804638fe9c
Author: Regina Obe <regina at arrival3d.com>
Date:   Thu Jan 20 19:29:28 2022 +0000
    Translated using Weblate (Russian)
    Currently translated at 22.9% (20 of 87 strings)
    Translation: postgis/administration.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ru/
diff --git a/doc/po/ru/administration.xml.po b/doc/po/ru/administration.xml.po
index 2987e319c..1c2588fb3 100644
--- a/doc/po/ru/administration.xml.po
+++ b/doc/po/ru/administration.xml.po
@@ -1,13 +1,14 @@
 # Russian translations for PACKAGE package.
 # Automatically generated, 2022.
+# Regina Obe <regina at arrival3d.com>, 2022.
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-01-20 18:53+0000\n"
-"PO-Revision-Date: 2022-01-12 22:41+0000\n"
-"Last-Translator: robe <regina at arrival3d.com>\n"
+"PO-Revision-Date: 2022-01-20 20:57+0000\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/"
 "administrationxml/ru/>\n"
 "Language: ru\n"
@@ -140,7 +141,7 @@ msgstr ""
 #. Tag: para
 #: administration.xml:32
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "On windows, if you are running as a service, you can set via System "
 "variables which for Windows 7 you can get to by right-clicking on Computer-"
@@ -151,11 +152,11 @@ msgid ""
 msgstr ""
 "В Windows, если вы работаете как служба, вы можете установить с помощью "
 "системных переменных, которые для Windows 7 вы можете получить, щелкнув "
-"правой кнопкой мыши «Компьютер-> Свойства» «Дополнительные параметры "
-"системы» или в проводнике, перейдя к <varname> Панель управления\\Все "
-"Элементы панели управления\\Система</varname>. Затем нажмите "
-"<emphasis>Дополнительные параметры системы ->Дополнительно->Переменные "
-"среды</emphasis> и добавьте новые системные переменные."
+"правой кнопкой мыши «Компьютер-> Свойства» «Дополнительные параметры системы»"
+" или в проводнике, перейдя к <varname> Панель управления\\Все Элементы "
+"панели управления\\Система</varname>. Затем нажмите <emphasis>Дополнительные "
+"параметры системы ->Дополнительно->Переменные среды</emphasis> и добавьте "
+"новые системные переменные."
 #. Tag: para
 #: administration.xml:34
Summary of changes:
 doc/po/ru/administration.xml.po | 17 +++++++++--------
 1 file changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
