[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-335-g8828402cc
git at osgeo.org
git at osgeo.org
Thu Jan 20 12:58:44 PST 2022
the project "PostGIS".
via 8828402ccb84023294ae0e1e0292d3cb2b0841ca (commit)
via 2424b1ed0fc63efcd07b2b98e1499035960e3a9c (commit)
from d2358992e0918633adf96875e5731d804638fe9c (commit)
revisions in full, below.
commit 8828402ccb84023294ae0e1e0292d3cb2b0841ca
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 20 21:36:19 2022 +0100
Enable tests found disabled by `make check_test_enabled`
CI was not catching this because the test was disabled
in commit 11dc1c60d8dbf5e534d1d32b1731038d92bf2be2
see #5062
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 739145cee..31663725d 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -89,6 +89,7 @@ TESTS += \
$(topsrcdir)/regress/core/remove_repeated_points \
$(topsrcdir)/regress/core/removepoint \
$(topsrcdir)/regress/core/reverse \
+ $(topsrcdir)/regress/core/scroll \
$(topsrcdir)/regress/core/setpoint \
$(topsrcdir)/regress/core/simplify \
$(topsrcdir)/regress/core/simplifyvw \
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 8255316c4..c709e81f3 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -23,12 +23,13 @@ TESTS += \
$(topsrcdir)/topology/test/regress/addface.sql \
$(topsrcdir)/topology/test/regress/addnode.sql \
$(topsrcdir)/topology/test/regress/addtopogeometrycolumn.sql \
- $(topsrcdir)/topology/test/regress/copytopology.sql \
$(topsrcdir)/topology/test/regress/cleartopogeom.sql \
+ $(topsrcdir)/topology/test/regress/copytopology.sql \
$(topsrcdir)/topology/test/regress/createtopogeom.sql \
$(topsrcdir)/topology/test/regress/createtopology.sql \
$(topsrcdir)/topology/test/regress/droptopogeometrycolumn.sql \
$(topsrcdir)/topology/test/regress/droptopology.sql \
+ $(topsrcdir)/topology/test/regress/findlayer.sql \
$(topsrcdir)/topology/test/regress/findtopology.sql \
$(topsrcdir)/topology/test/regress/geometry_cast.sql \
$(topsrcdir)/topology/test/regress/getedgebypoint.sql \
@@ -61,6 +62,7 @@ TESTS += \
$(topsrcdir)/topology/test/regress/st_newedgessplit.sql \
$(topsrcdir)/topology/test/regress/st_remedgemodface.sql \
$(topsrcdir)/topology/test/regress/st_remedgenewface.sql \
+ $(topsrcdir)/topology/test/regress/st_removeisoedge.sql \
$(topsrcdir)/topology/test/regress/st_removeisonode.sql \
$(topsrcdir)/topology/test/regress/st_simplify.sql \
$(topsrcdir)/topology/test/regress/topo2.5d.sql \
@@ -69,11 +71,11 @@ TESTS += \
$(topsrcdir)/topology/test/regress/topogeo_addlinestring.sql \
$(topsrcdir)/topology/test/regress/topogeo_addpoint.sql \
$(topsrcdir)/topology/test/regress/topogeo_addpolygon.sql \
- $(topsrcdir)/topology/test/regress/topogeom_edit.sql \
- $(topsrcdir)/topology/test/regress/topogeom_addtopogeom.sql \
+ $(topsrcdir)/topology/test/regress/topogeom_addtopogeom.sql \
+ $(topsrcdir)/topology/test/regress/topogeom_edit.sql \
+ $(topsrcdir)/topology/test/regress/topogeometry_srid.sql \
$(topsrcdir)/topology/test/regress/topogeometry_type.sql \
$(topsrcdir)/topology/test/regress/topojson.sql \
- $(topsrcdir)/topology/test/regress/topologysummary.sql \
+ $(topsrcdir)/topology/test/regress/topologysummary.sql \
$(topsrcdir)/topology/test/regress/totopogeom.sql \
$(topsrcdir)/topology/test/regress/validatetopology.sql
commit 2424b1ed0fc63efcd07b2b98e1499035960e3a9c
Date: Thu Jan 20 21:56:58 2022 +0100
Fix ST_Srid(TopoGeometry) usage against a set of TopoGeometries
References #5063 in master branch (3.3.0dev)
diff --git a/topology/sql/topogeometry/srid.sql.in b/topology/sql/topogeometry/srid.sql.in
index 14f50d553..c937510ed 100644
--- a/topology/sql/topogeometry/srid.sql.in
+++ b/topology/sql/topogeometry/srid.sql.in
@@ -19,8 +19,8 @@ CREATE OR REPLACE FUNCTION topology.ST_Srid(tg topology.TopoGeometry)
AS
SELECT srid FROM topology.topology
- WHERE id = id(tg);
+ WHERE id = topology_id(tg);
-LANGUAGE 'sql' STABLE STRICT;
+LANGUAGE 'sql' VOLATILE STRICT;
diff --git a/topology/test/regress/topogeometry_srid.sql b/topology/test/regress/topogeometry_srid.sql
index 08fe7dafa..e8faca595 100644
--- a/topology/test/regress/topogeometry_srid.sql
+++ b/topology/test/regress/topogeometry_srid.sql
@@ -1,27 +1,27 @@
set client_min_messages to WARNING;
\i :top_builddir/topology/test/load_topology.sql
-\i ../load_features.sql
-\i ../more_features.sql
-\i ../hierarchy.sql
+\i :regdir/../topology/test/load_features.sql
+\i :regdir/../topology/test/more_features.sql
+\i :regdir/../topology/test/hierarchy.sql
SELECT DISTINCT 'ST_Srid(traffic_signs)',
- geometrytype(feature) FROM features.traffic_signs;
+ st_srid(feature) FROM features.traffic_signs;
SELECT DISTINCT 'ST_Srid(city_streets)',
- geometrytype(feature) FROM features.city_streets;
+ st_srid(feature) FROM features.city_streets;
SELECT DISTINCT 'ST_Srid(land_parcels)',
- geometrytype(feature) FROM features.land_parcels;
+ st_srid(feature) FROM features.land_parcels;
SELECT DISTINCT 'ST_Srid(big_signs)',
- geometrytype(feature) FROM features.big_signs;
+ st_srid(feature) FROM features.big_signs;
SELECT DISTINCT 'ST_Srid(big_streets)',
- geometrytype(feature) FROM features.big_streets;
+ st_srid(feature) FROM features.big_streets;
SELECT DISTINCT 'ST_Srid(big_parcels)',
- geometrytype(feature) FROM features.big_parcels;
+ st_srid(feature) FROM features.big_parcels;
SELECT topology.DropTopology('city_data');
DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/topogeometry_srid_expected b/topology/test/regress/topogeometry_srid_expected
index 28ba36ec5..57336f103 100644
--- a/topology/test/regress/topogeometry_srid_expected
+++ b/topology/test/regress/topogeometry_srid_expected
@@ -1,19 +1,7 @@
-t
-9
-22
-26
-1
-2
-3
-4
-features.big_parcels.the_geom SRID:0 TYPE:MULTIPOLYGON DIMS:2
-5
-6
-features.big_signs.the_geom SRID:0 TYPE:MULTIPOINT DIMS:2
-ST_Srid(traffic_signs)|MULTIPOINT
-ST_Srid(city_streets)|MULTILINESTRING
-ST_Srid(land_parcels)|MULTIPOLYGON
-ST_Srid(big_signs)|MULTIPOINT
-ST_Srid(big_streets)|MULTILINESTRING
-ST_Srid(big_parcels)|MULTIPOLYGON
+ST_Srid(traffic_signs)|0
+ST_Srid(city_streets)|0
+ST_Srid(land_parcels)|0
+ST_Srid(big_signs)|0
+ST_Srid(big_streets)|0
+ST_Srid(big_parcels)|0
Topology 'city_data' dropped
Summary of changes:
regress/core/tests.mk.in | 1 +
topology/sql/topogeometry/srid.sql.in | 4 ++--
topology/test/regress/topogeometry_srid.sql | 18 +++++++++---------
topology/test/regress/topogeometry_srid_expected | 24 ++++++------------------
topology/test/tests.mk | 12 +++++++-----
5 files changed, 25 insertions(+), 34 deletions(-)
hooks/post-receive
