[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-20-gbc5378234
Thu Jan 20 13:10:03 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  bc5378234fc8970292639306c6ab40132fcff3cd (commit)
       via  45bdbaf15830ca4123a6be23978c6fccf0a5c73c (commit)
      from  e78c543b5e48a007e9a5ec9d85f399c42c4898e5 (commit)
revisions in full, below.
commit bc5378234fc8970292639306c6ab40132fcff3cd
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 20 21:36:19 2022 +0100
    Enable tests found disabled by `make check_test_enabled`
    CI was not catching this because the test was disabled
    in commit 11dc1c60d8dbf5e534d1d32b1731038d92bf2be2
    see #5062
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 739145cee..31663725d 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -89,6 +89,7 @@ TESTS += \
 	$(topsrcdir)/regress/core/remove_repeated_points \
 	$(topsrcdir)/regress/core/removepoint \
 	$(topsrcdir)/regress/core/reverse \
+	$(topsrcdir)/regress/core/scroll \
 	$(topsrcdir)/regress/core/setpoint \
 	$(topsrcdir)/regress/core/simplify \
 	$(topsrcdir)/regress/core/simplifyvw \
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 8255316c4..c709e81f3 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -23,12 +23,13 @@ TESTS += \
   $(topsrcdir)/topology/test/regress/addface.sql \
 	$(topsrcdir)/topology/test/regress/addnode.sql \
 	$(topsrcdir)/topology/test/regress/addtopogeometrycolumn.sql \
-	$(topsrcdir)/topology/test/regress/copytopology.sql \
 	$(topsrcdir)/topology/test/regress/cleartopogeom.sql \
+	$(topsrcdir)/topology/test/regress/copytopology.sql \
 	$(topsrcdir)/topology/test/regress/createtopogeom.sql \
 	$(topsrcdir)/topology/test/regress/createtopology.sql \
 	$(topsrcdir)/topology/test/regress/droptopogeometrycolumn.sql \
 	$(topsrcdir)/topology/test/regress/droptopology.sql \
+	$(topsrcdir)/topology/test/regress/findlayer.sql \
 	$(topsrcdir)/topology/test/regress/findtopology.sql \
 	$(topsrcdir)/topology/test/regress/geometry_cast.sql \
 	$(topsrcdir)/topology/test/regress/getedgebypoint.sql \
@@ -61,6 +62,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/st_newedgessplit.sql \
 	$(topsrcdir)/topology/test/regress/st_remedgemodface.sql \
 	$(topsrcdir)/topology/test/regress/st_remedgenewface.sql \
+	$(topsrcdir)/topology/test/regress/st_removeisoedge.sql \
 	$(topsrcdir)/topology/test/regress/st_removeisonode.sql \
 	$(topsrcdir)/topology/test/regress/st_simplify.sql \
 	$(topsrcdir)/topology/test/regress/topo2.5d.sql \
@@ -69,11 +71,11 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/topogeo_addlinestring.sql \
 	$(topsrcdir)/topology/test/regress/topogeo_addpoint.sql \
 	$(topsrcdir)/topology/test/regress/topogeo_addpolygon.sql \
-  $(topsrcdir)/topology/test/regress/topogeom_edit.sql \
-  $(topsrcdir)/topology/test/regress/topogeom_addtopogeom.sql \
+	$(topsrcdir)/topology/test/regress/topogeom_addtopogeom.sql \
+	$(topsrcdir)/topology/test/regress/topogeom_edit.sql \
+	$(topsrcdir)/topology/test/regress/topogeometry_srid.sql \
 	$(topsrcdir)/topology/test/regress/topogeometry_type.sql \
 	$(topsrcdir)/topology/test/regress/topojson.sql \
-  $(topsrcdir)/topology/test/regress/topologysummary.sql \
+	$(topsrcdir)/topology/test/regress/topologysummary.sql \
 	$(topsrcdir)/topology/test/regress/totopogeom.sql \
 	$(topsrcdir)/topology/test/regress/validatetopology.sql
commit 45bdbaf15830ca4123a6be23978c6fccf0a5c73c
Date:   Thu Jan 20 21:56:58 2022 +0100
    Fix ST_Srid(TopoGeometry) usage against a set of TopoGeometries
    References #5063 in 3.2 branch (3.2.1dev)
    Includes NEWS item
diff --git a/NEWS b/NEWS
index a11f163fa..2956eb0f0 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ YYYY/MM/DD
   - #5033, #5035, allow upgrades in presence of views using deprecated
            functions (Sandro Santilli)
   - #5046, Fix upgrades in absence of old library (Sandro Santilli)
+  - #5063, Fix ST_Srid(TopoGeometry) against a set (Sandro Santilli)
 PostGIS 3.2.0 (Olivier Courtin Edition)
 2021/12/17
diff --git a/topology/sql/topogeometry/srid.sql.in b/topology/sql/topogeometry/srid.sql.in
index 14f50d553..c937510ed 100644
--- a/topology/sql/topogeometry/srid.sql.in
+++ b/topology/sql/topogeometry/srid.sql.in
@@ -19,8 +19,8 @@ CREATE OR REPLACE FUNCTION topology.ST_Srid(tg topology.TopoGeometry)
 AS
 	SELECT srid FROM topology.topology
-  WHERE id = id(tg);
+  WHERE id = topology_id(tg);
-LANGUAGE 'sql' STABLE STRICT;
+LANGUAGE 'sql' VOLATILE STRICT;
diff --git a/topology/test/regress/topogeometry_srid.sql b/topology/test/regress/topogeometry_srid.sql
index af455d4f5..5cc577b5b 100644
--- a/topology/test/regress/topogeometry_srid.sql
+++ b/topology/test/regress/topogeometry_srid.sql
@@ -1,27 +1,27 @@
 set client_min_messages to WARNING;
 \i ../load_topology.sql
-\i ../load_features.sql
-\i ../more_features.sql
-\i ../hierarchy.sql
+\i :regdir/../topology/test/load_features.sql
+\i :regdir/../topology/test/more_features.sql
+\i :regdir/../topology/test/hierarchy.sql
 SELECT DISTINCT 'ST_Srid(traffic_signs)',
-	geometrytype(feature) FROM features.traffic_signs;
+	st_srid(feature) FROM features.traffic_signs;
 SELECT DISTINCT 'ST_Srid(city_streets)',
-	geometrytype(feature) FROM features.city_streets;
+	st_srid(feature) FROM features.city_streets;
 SELECT DISTINCT 'ST_Srid(land_parcels)',
-	geometrytype(feature) FROM features.land_parcels;
+	st_srid(feature) FROM features.land_parcels;
 SELECT DISTINCT 'ST_Srid(big_signs)',
-	geometrytype(feature) FROM features.big_signs;
+	st_srid(feature) FROM features.big_signs;
 SELECT DISTINCT 'ST_Srid(big_streets)',
-	geometrytype(feature) FROM features.big_streets;
+	st_srid(feature) FROM features.big_streets;
 SELECT DISTINCT 'ST_Srid(big_parcels)',
-	geometrytype(feature) FROM features.big_parcels;
+	st_srid(feature) FROM features.big_parcels;
 SELECT topology.DropTopology('city_data');
 DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/topogeometry_srid_expected b/topology/test/regress/topogeometry_srid_expected
index 28ba36ec5..57336f103 100644
--- a/topology/test/regress/topogeometry_srid_expected
+++ b/topology/test/regress/topogeometry_srid_expected
@@ -1,19 +1,7 @@
-t
-9
-22
-26
-1
-2
-3
-4
-features.big_parcels.the_geom SRID:0 TYPE:MULTIPOLYGON DIMS:2
-5
-6
-features.big_signs.the_geom SRID:0 TYPE:MULTIPOINT DIMS:2
-ST_Srid(traffic_signs)|MULTIPOINT
-ST_Srid(city_streets)|MULTILINESTRING
-ST_Srid(land_parcels)|MULTIPOLYGON
-ST_Srid(big_signs)|MULTIPOINT
-ST_Srid(big_streets)|MULTILINESTRING
-ST_Srid(big_parcels)|MULTIPOLYGON
+ST_Srid(traffic_signs)|0
+ST_Srid(city_streets)|0
+ST_Srid(land_parcels)|0
+ST_Srid(big_signs)|0
+ST_Srid(big_streets)|0
+ST_Srid(big_parcels)|0
 Topology 'city_data' dropped
Summary of changes:
 NEWS                                             |  1 +
 regress/core/tests.mk.in                         |  1 +
 topology/sql/topogeometry/srid.sql.in            |  4 ++--
 topology/test/regress/topogeometry_srid.sql      | 18 +++++++++---------
 topology/test/regress/topogeometry_srid_expected | 24 ++++++------------------
 topology/test/tests.mk                           | 12 +++++++-----
 6 files changed, 26 insertions(+), 34 deletions(-)
hooks/post-receive
