[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-359-gc22680adf
git at osgeo.org
git at osgeo.org
Mon Jan 24 22:49:07 PST 2022
the project "PostGIS".
via c22680adf6b4ac9be5203211d471c9d701b3fcf0 (commit)
via b0de6849b52e9ec4458ffee2f2bf18e552855966 (commit)
via b9e5da7c4d6fc4b77daedfcdff2e48a33bf10438 (commit)
from 28d3747b8ecc585780112e8fe54c3d5da99cba5f (commit)
revisions in full, below.
commit c22680adf6b4ac9be5203211d471c9d701b3fcf0
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jan 25 09:48:14 2022 +0300
Add news item for GH658
Closes #4912
diff --git a/NEWS b/NEWS
index ce7d8859a..fd7a7474d 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ PostGIS 3.3.0dev
- #5040, add postgis_sfcgal_full_version (Loïc Bartoletti)
- GH655, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)
- GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
+ - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
PostGIS 3.2.0 (Olivier Courtin Edition)
2021/12/17
commit b0de6849b52e9ec4458ffee2f2bf18e552855966
Merge: 28d3747b8 b9e5da7c4
Author: kalenikaliaksandr <kalenik.aliaksandr at gmail.com>
Date: Tue Jan 25 09:39:42 2022 +0300
Merge b9e5da7c4d6fc4b77daedfcdff2e48a33bf10438 into 28d3747b8ecc585780112e8fe54c3d5da99cba5f
commit b9e5da7c4d6fc4b77daedfcdff2e48a33bf10438
Author: Aliaksandr Kalenik <kalenik.aliaksandr at gmail.com>
Date: Sun Jan 23 19:18:42 2022 +0300
gidx is varlena so it should be detoasted. #Closes 4912
diff --git a/postgis/gserialized_gist_nd.c b/postgis/gserialized_gist_nd.c
index 2ea7a1c05..58c86e3d5 100644
--- a/postgis/gserialized_gist_nd.c
+++ b/postgis/gserialized_gist_nd.c
@@ -1123,12 +1123,12 @@ Datum gserialized_gist_consistent(PG_FUNCTION_ARGS)
if (GIST_LEAF(entry))
result =
- gserialized_gist_consistent_leaf((GIDX *)DatumGetPointer(entry->key), query_gbox_index, strategy);
+ gserialized_gist_consistent_leaf((GIDX *)PG_DETOAST_DATUM(entry->key), query_gbox_index, strategy);
else
result = gserialized_gist_consistent_internal(
- (GIDX *)DatumGetPointer(entry->key), query_gbox_index, strategy);
+ (GIDX *)PG_DETOAST_DATUM(entry->key), query_gbox_index, strategy);
PG_RETURN_BOOL(result);
@@ -1196,6 +1196,9 @@ Datum gserialized_gist_penalty(PG_FUNCTION_ARGS)
float size_orig = gidx_volume(gbox_index_orig);
float volume_extension = size_union - size_orig;
+ gbox_index_orig = (GIDX *)PG_DETOAST_DATUM(origentry->key);
+ gbox_index_new = (GIDX *)PG_DETOAST_DATUM(newentry->key);
/* REALM 1: Area extension is nonzero, return it */
if (volume_extension > FLT_EPSILON)
*result = pack_float(volume_extension, 1);
@@ -1227,13 +1230,13 @@ Datum gserialized_gist_union(PG_FUNCTION_ARGS)
numranges = entryvec->n;
- box_cur = (GIDX *)DatumGetPointer(entryvec->vector[0].key);
+ box_cur = (GIDX *)PG_DETOAST_DATUM(entryvec->vector[0].key);
box_union = gidx_copy(box_cur);
for (i = 1; i < numranges; i++)
- box_cur = (GIDX *)DatumGetPointer(entryvec->vector[i].key);
+ box_cur = (GIDX *)PG_DETOAST_DATUM(entryvec->vector[i].key);
gidx_merge(&box_union, box_cur);
@@ -1294,7 +1297,7 @@ Datum gserialized_gist_geog_distance(PG_FUNCTION_ARGS)
*recheck = true;
/* Get the entry box */
- entry_box = (GIDX *)DatumGetPointer(entry->key);
+ entry_box = (GIDX *)PG_DETOAST_DATUM(entry->key);
/* Return distances from key-based tests should always be */
/* the minimum possible distance, box-to-box */
@@ -1353,7 +1356,7 @@ Datum gserialized_gist_distance(PG_FUNCTION_ARGS)
/* Strategy 20 is |=| */
distance = gidx_distance(entry_box, query_box, strategy == 20);
@@ -1433,7 +1436,7 @@ gserialized_gist_picksplit_fallback(GistEntryVector *entryvec, GIST_SPLITVEC *v)
for (i = FirstOffsetNumber; i <= maxoff; i = OffsetNumberNext(i))
- GIDX *cur = (GIDX *)DatumGetPointer(entryvec->vector[i].key);
+ GIDX *cur = (GIDX *)PG_DETOAST_DATUM(entryvec->vector[i].key);
if (i <= (maxoff - FirstOffsetNumber + 1) / 2)
@@ -1456,12 +1459,12 @@ gserialized_gist_picksplit_fallback(GistEntryVector *entryvec, GIST_SPLITVEC *v)
if (v->spl_ldatum_exists)
- gidx_merge(&unionL, (GIDX *)DatumGetPointer(v->spl_ldatum));
+ gidx_merge(&unionL, (GIDX *)PG_DETOAST_DATUM(v->spl_ldatum));
v->spl_ldatum = PointerGetDatum(unionL);
if (v->spl_rdatum_exists)
- gidx_merge(&unionR, (GIDX *)DatumGetPointer(v->spl_rdatum));
+ gidx_merge(&unionR, (GIDX *)PG_DETOAST_DATUM(v->spl_rdatum));
v->spl_rdatum = PointerGetDatum(unionR);
v->spl_ldatum_exists = v->spl_rdatum_exists = false;
@@ -1490,10 +1493,10 @@ gserialized_gist_picksplit_constructsplit(GIST_SPLITVEC *v,
GIDX *RLr = gidx_copy(*union1);
double sizeLR, sizeRL;
- gidx_merge(&LRl, (GIDX *)DatumGetPointer(v->spl_ldatum));
- gidx_merge(&LRr, (GIDX *)DatumGetPointer(v->spl_rdatum));
- gidx_merge(&RLl, (GIDX *)DatumGetPointer(v->spl_ldatum));
- gidx_merge(&RLr, (GIDX *)DatumGetPointer(v->spl_rdatum));
+ gidx_merge(&LRl, (GIDX *)PG_DETOAST_DATUM(v->spl_ldatum));
+ gidx_merge(&LRr, (GIDX *)PG_DETOAST_DATUM(v->spl_rdatum));
+ gidx_merge(&RLl, (GIDX *)PG_DETOAST_DATUM(v->spl_ldatum));
+ gidx_merge(&RLr, (GIDX *)PG_DETOAST_DATUM(v->spl_rdatum));
sizeLR = gidx_inter_volume(LRl, LRr);
sizeRL = gidx_inter_volume(RLl, RLr);
@@ -1542,10 +1545,10 @@ gserialized_gist_picksplit_constructsplit(GIST_SPLITVEC *v,
v->spl_nleft = nlist1;
v->spl_nright = nlist2;
- gidx_merge(union1, (GIDX *)DatumGetPointer(v->spl_ldatum));
+ gidx_merge(union1, (GIDX *)PG_DETOAST_DATUM(v->spl_ldatum));
v->spl_ldatum = PointerGetDatum(*union1);
- gidx_merge(union2, (GIDX *)DatumGetPointer(v->spl_rdatum));
+ gidx_merge(union2, (GIDX *)PG_DETOAST_DATUM(v->spl_rdatum));
v->spl_rdatum = PointerGetDatum(*union2);
else
@@ -1555,10 +1558,10 @@ gserialized_gist_picksplit_constructsplit(GIST_SPLITVEC *v,
v->spl_nleft = nlist2;
v->spl_nright = nlist1;
- gidx_merge(union2, (GIDX *)DatumGetPointer(v->spl_ldatum));
+ gidx_merge(union2, (GIDX *)PG_DETOAST_DATUM(v->spl_ldatum));
v->spl_ldatum = PointerGetDatum(*union2);
- gidx_merge(union1, (GIDX *)DatumGetPointer(v->spl_rdatum));
+ gidx_merge(union1, (GIDX *)PG_DETOAST_DATUM(v->spl_rdatum));
v->spl_rdatum = PointerGetDatum(*union1);
@@ -1604,13 +1607,13 @@ Datum gserialized_gist_picksplit(PG_FUNCTION_ARGS)
max_offset = entryvec->n - 1;
- box_current = (GIDX *)DatumGetPointer(entryvec->vector[FirstOffsetNumber].key);
+ box_current = (GIDX *)PG_DETOAST_DATUM(entryvec->vector[FirstOffsetNumber].key);
box_pageunion = gidx_copy(box_current);
/* Calculate the containing box (box_pageunion) for the whole page we are going to split. */
for (i = OffsetNumberNext(FirstOffsetNumber); i <= max_offset; i = OffsetNumberNext(i))
- box_current = (GIDX *)DatumGetPointer(entryvec->vector[i].key);
+ box_current = (GIDX *)PG_DETOAST_DATUM(entryvec->vector[i].key);
if (all_entries_equal && !gidx_equals(box_pageunion, box_current))
all_entries_equal = false;
@@ -1653,7 +1656,7 @@ Datum gserialized_gist_picksplit(PG_FUNCTION_ARGS)
POSTGIS_DEBUG(4, "[GIST] 'picksplit' calculating best split axis");
for (i = FirstOffsetNumber; i <= max_offset; i = OffsetNumberNext(i))
for (d = 0; d < ndims_pageunion; d++)
@@ -1689,7 +1692,7 @@ Datum gserialized_gist_picksplit(PG_FUNCTION_ARGS)
avgCenter[d] += (GIDX_GET_MAX(box_current, d) + GIDX_GET_MIN(box_current, d)) / 2.0;
@@ -1704,7 +1707,7 @@ Datum gserialized_gist_picksplit(PG_FUNCTION_ARGS)
double center;
Summary of changes:
NEWS | 1 +
postgis/gserialized_gist_nd.c | 47 +++++++++++++++++++++++--------------------
2 files changed, 26 insertions(+), 22 deletions(-)
hooks/post-receive
