[postgis-tickets] [PostGIS] #5066: Can't build under mingw64
trac at osgeo.org
Thu Jan 27 10:21:22 PST 2022
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:4 strk]:
> My builds do have regress/00-regress-install/lib/postgis-3.so installed
in build dir.
> I see your script looks for postgis-3.3.so which makes me think this
*could* be related to --with-library-minor-version -- is jenkins the only
CI using that switch ?
I thought I had changed the dronie bots to use --with-library-minor-
version as well so they could properly test upgrades from 3, 3.1, 3.2 etc.
anyway I think debbie has that too and she isn't having issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5066#comment:6>
