[postgis-tickets] [PostGIS] #5066: Can't build under mingw64
PostGIS trac at osgeo.org
Thu Jan 27 10:22:39 PST 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 strk I usually do
 make install
 and then regess check with extensions.  I'll check what happens with make
 staged-install
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5066#comment:7>
