[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-388-gbe464e4bd
Thu Jan 27 13:16:51 PST 2022
the project "PostGIS".
       via  be464e4bd76bd9691f0297bb09001ec671f141cc (commit)
       via  d5a9b1b5b1e0a036bafa01882c5cbe26b1f32f58 (commit)
      from  1090436f14fa3641834df6540fa2a4f35dbb8c3f (commit)
revisions in full, below.
commit be464e4bd76bd9691f0297bb09001ec671f141cc
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 27 20:16:59 2022 +0100
    [gitlab-ci] Really make source tree immutable
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index 69a6b525b..b91e1b9fa 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -19,7 +19,7 @@
     - ./configure
     - make maintainer-clean
     - ./autogen.sh
-    - chmod -R a-w .
+    - chattr -R +i . # mark source tree as immutable
     - export SRCDIR="${PWD}"
     - echo "SRCDIR is ${SRCDIR}"
     - mkdir /tmp/build && cd /tmp/build
commit d5a9b1b5b1e0a036bafa01882c5cbe26b1f32f58
Date:   Thu Jan 27 21:33:44 2022 +0100
    Another pre/post machinery replaced with .tif.ref files
    References #5068
diff --git a/raster/test/regress/load_outdb-post.pl b/raster/test/regress/load_outdb-post.pl
deleted file mode 100755
index 4d6facb8a..000000000
--- a/raster/test/regress/load_outdb-post.pl
+++ /dev/null
@@ -1,2 +0,0 @@
-unlink $TEST . "-pre.sql";
-#unlink $TEST . "-post.sql";
diff --git a/raster/test/regress/load_outdb-pre.pl b/raster/test/regress/load_outdb-pre.pl
index ec6782aab..000000000
--- a/raster/test/regress/load_outdb-pre.pl
+++ /dev/null
@@ -1,69 +0,0 @@
-use File::Basename;
-use Cwd 'abs_path';
-my $REGDIR = abs_path(dirname($0));
-my $RASTERDIR = abs_path($REGDIR . "/../raster/test/regress");
-my $FILERASTER = $RASTERDIR . "/loader/testraster.tif";
-# special handling for msys
-if (lc($^O) eq "msys") {
-	$FILERASTER = `cmd //c echo "$FILERASTER"`;
-	$FILERASTER =~ s/^\s+//;
-	$FILERASTER =~ s/\s+$//;
-my $sql = <<"END";
-WITH foo AS (
-	SELECT postgis_raster_lib_version()
-SELECT NULL FROM foo;
-SET postgis.gdal_enabled_drivers = 'GTiff';
-DROP TABLE IF EXISTS raster_outdb_template;
-CREATE TABLE raster_outdb_template AS
-SELECT
-	1 AS rid,
-	ST_AddBand( -- insert all three bands of out-db raster at index 1
-		ST_MakeEmptyRaster(90, 50, 0., 0., 1, -1, 0, 0, 0),
-		1, '$FILERASTER'::text, NULL::int[]
-	) AS rast
-UNION ALL
-SELECT
-	2 AS rid,
-	ST_AddBand( -- append all three bands of out-db raster
-		'$FILERASTER'::text, NULL::int[]
-	) AS rast
-UNION ALL
-SELECT
-	3 AS rid,
-	ST_AddBand( -- append out-db band 2
-		ST_AddBand( -- in-db band
-			1, '8BUI', 1, 0
-		'$FILERASTER'::text, ARRAY[2]::int[]
-	) AS rast
-UNION ALL
-SELECT
-	4 AS rid,
-			1, '8BUI', 1, 0
-		'$FILERASTER'::text, ARRAY[2]::int[],
-		1,
-		255
-	) AS rast
-END
-my $PREFNAME = $TEST . '-pre.sql';
-open(PRESQL, '>', $PREFNAME) || die ('Cannot open ' . $PREFNAME . ": $!");
-print PRESQL $sql;
-close(PRESQL);
-# no longer needed as the "clean" test takes care of it
-#my $POSTFNAME = $TEST . '-post.sql';
-#open(POSTSQL, '>', $POSTFNAME) || die ('Cannot open ' . $POSTFNAME .  ": $!");;
-#print POSTSQL "DROP TABLE IF EXISTS raster_outdb_template;\n";
-#close(POSTSQL);
diff --git a/raster/test/regress/loader/load_outdb-pre.sql b/raster/test/regress/loader/load_outdb-pre.sql
new file mode 100644
index 000000000..ddc631895
--- /dev/null
+++ b/raster/test/regress/loader/load_outdb-pre.sql
@@ -0,0 +1,43 @@
+WITH foo AS (
+	SELECT postgis_raster_lib_version()
+SELECT NULL FROM foo;
+SET postgis.gdal_enabled_drivers = 'GTiff';
+DROP TABLE IF EXISTS raster_outdb_template;
+CREATE TABLE raster_outdb_template AS
+SELECT
+	1 AS rid,
+	ST_AddBand( -- insert all three bands of out-db raster at index 1
+		ST_MakeEmptyRaster(90, 50, 0., 0., 1, -1, 0, 0, 0),
+		1, (:'regdir' || '/../raster/test/regress/loader/testraster.tif')::text, NULL::int[]
+	) AS rast
+UNION ALL
+SELECT
+	2 AS rid,
+	ST_AddBand( -- append all three bands of out-db raster
+		(:'regdir' || '/../raster/test/regress/loader/testraster.tif')::text, NULL::int[]
+	) AS rast
+UNION ALL
+SELECT
+	3 AS rid,
+	ST_AddBand( -- append out-db band 2
+		ST_AddBand( -- in-db band
+			1, '8BUI', 1, 0
+		(:'regdir' || '/../raster/test/regress/loader/testraster.tif')::text, ARRAY[2]::int[]
+	) AS rast
+UNION ALL
+SELECT
+	4 AS rid,
+			1, '8BUI', 1, 0
+		(:'regdir' || '/../raster/test/regress/loader/testraster.tif')::text, ARRAY[2]::int[],
+		1,
+		255
+	) AS rast
diff --git a/raster/test/regress/load_outdb.sql b/raster/test/regress/loader/load_outdb.sql
similarity index 100%
rename from raster/test/regress/load_outdb.sql
rename to raster/test/regress/loader/load_outdb.sql
diff --git a/raster/test/regress/loader/load_outdb.tif.ref b/raster/test/regress/loader/load_outdb.tif.ref
index 000000000..1e1cc0fc8
--- /dev/null
+++ b/raster/test/regress/loader/load_outdb.tif.ref
@@ -0,0 +1 @@
+testraster.tif
diff --git a/raster/test/regress/load_outdb_expected b/raster/test/regress/loader/load_outdb_expected
rename from raster/test/regress/load_outdb_expected
rename to raster/test/regress/loader/load_outdb_expected
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 50d0c11ea..7dccaeb45 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -19,7 +19,7 @@ override RUNTESTFLAGS_INTERNAL := \
 RASTER_TEST_FIRST = \
 	$(topsrcdir)/raster/test/regress/check_gdal \
-	$(topsrcdir)/raster/test/regress/load_outdb
+	$(topsrcdir)/raster/test/regress/loader/load_outdb
 RASTER_TEST_LAST = \
 	$(topsrcdir)/raster/test/regress/clean
Summary of changes:
 .gitlab-ci.yml                                     |  2 +-
 raster/test/regress/load_outdb-post.pl             |  2 -
 raster/test/regress/load_outdb-pre.pl              | 69 ----------------------
 raster/test/regress/loader/load_outdb-pre.sql      | 43 ++++++++++++++
 raster/test/regress/{ => loader}/load_outdb.sql    |  0
 .../loader/{Basic.tif.ref => load_outdb.tif.ref}   |  0
 .../test/regress/{ => loader}/load_outdb_expected  |  0
 raster/test/regress/tests.mk                       |  2 +-
 8 files changed, 45 insertions(+), 73 deletions(-)
 delete mode 100755 raster/test/regress/load_outdb-post.pl
 delete mode 100755 raster/test/regress/load_outdb-pre.pl
 create mode 100644 raster/test/regress/loader/load_outdb-pre.sql
 rename raster/test/regress/{ => loader}/load_outdb.sql (100%)
 copy raster/test/regress/loader/{Basic.tif.ref => load_outdb.tif.ref} (100%)
 rename raster/test/regress/{ => loader}/load_outdb_expected (100%)
hooks/post-receive
