[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-389-ge273c1431
Thu Jan 27 13:44:40 PST 2022
the project "PostGIS".
       via  e273c14312d8632a40b868586f31b1aae43abce4 (commit)
      from  be464e4bd76bd9691f0297bb09001ec671f141cc (commit)
revisions in full, below.
commit e273c14312d8632a40b868586f31b1aae43abce4
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 27 22:43:59 2022 +0100
    Drop most TODO files, either empty or completely outdated
    A couple of TODO files are still in the repo but I don't feel like
    reviewing them at the moment
diff --git a/liblwgeom/TODO b/liblwgeom/TODO
deleted file mode 100644
index fe68c6c56..000000000
--- a/liblwgeom/TODO
+++ /dev/null
@@ -1,31 +0,0 @@
-# Status of topology functions (X = done)
-lwt_CreateBackendIface X
-lwt_BackendIfaceRegisterCallbacks X
-lwt_FreeBackendIface  X
-lwt_LoadTopology      X
-lwt_FreeTopology      X
-lwt_AddIsoNode        X
-lwt_AddEdgeModFace    X
-lwt_AddEdgeNewFaces   X
-lwt_ModEdgeSplit      X
-lwt_NewEdgesSplit     X
-lwt_AddIsoEdge        X
-lwt_GetFaceGeometry   X
-lwt_GetFaceEdges      X
-lwt_ChangeEdgeGeom    X
-lwt_RemoveIsoNode     X
-lwt_RemoveIsoEdge     X
-lwt_MoveIsoNode       X
-lwt_RemEdgeModFace    X
-lwt_RemEdgeNewFace    X
-lwt_ModEdgeHeal       X
-lwt_NewEdgeHeal       X
-lwt_GetFaceByPoint    X
-lwt_GetNodeByPoint    X
-lwt_GetEdgeByPoint    X
-lwt_TopoGeo_AddPoint  X
-lwt_TopoGeo_AddLineString X
-lwt_TopoGeo_AddPolygon X
diff --git a/loader/TODO b/loader/TODO
index e69de29bb..000000000
diff --git a/postgis/TODO b/postgis/TODO
index 772e73d58..000000000
--- a/postgis/TODO
+++ /dev/null
@@ -1,24 +0,0 @@
-- copy bbox on deserializzation (for memory alignment constraints)
-- lwgeom_clone_deep / lwgeom_release_deep
-  (or maybe should both be always be deep.... )
-- LWGEOM editor (insert/append a geom, remove a geom, ....)
-- Flatten(geometry)
-- F linemerge(linestring, linestring)
-- A linemerge(linestring, linestring)
-- Check spheroid misure functions
-	o can't understand if 3d computation works since
-	  I get same result w/ 2d and 3d.
-	o check if distance can be computed in 3d space
-- Check semantic required by OGC functions working on "first geometry
-  of a given type". Is the first geometry be to be seeked inside
-  collection elements (currently it is not w/ LWGEOM) ?
-- proj support functions might need 3d sometimes.
diff --git a/raster/TODO b/raster/TODO
index c6de48c15..000000000
--- a/raster/TODO
+++ /dev/null
@@ -1,8 +0,0 @@
-This is the TODO list for PostGIS Raster.  Items in this TODO file should be
-kept brief and to the point.  TODO items should only be those items that have
-yet to be ticketed in PostGIS trac and lack specifics.
-== Simple Projects ==
-== Larger Projects ==
Summary of changes:
 liblwgeom/TODO | 31 -------------------------------
 loader/TODO    |  0
 postgis/TODO   | 24 ------------------------
 raster/TODO    |  8 --------
 4 files changed, 63 deletions(-)
 delete mode 100644 liblwgeom/TODO
 delete mode 100644 loader/TODO
 delete mode 100644 postgis/TODO
 delete mode 100644 raster/TODO
hooks/post-receive
