[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-390-ga5a714fb4
git at osgeo.org
git at osgeo.org
Thu Jan 27 14:20:47 PST 2022
the project "PostGIS".
via a5a714fb4867355ea2f47c9f5facf88f85a94b31 (commit)
from e273c14312d8632a40b868586f31b1aae43abce4 (commit)
revisions in full, below.
commit a5a714fb4867355ea2f47c9f5facf88f85a94b31
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jan 19 14:43:58 2022 +0100
[dronie] Activate parallel steps, using out-of-tree builds
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index 7e4e6f3f0..7b7af5d69 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -14,21 +14,32 @@ kind: pipeline
clone: *clone
steps:
+ - name: autogen
+ image: *test-image
+ pull: always
+ commands:
+ - ./autogen.sh
+ depends_on: [ clone ]
- name: build-9.6
image: *test-image
pull: always
commands:
- PGVER=9.6 sh ci/dronie/postgis_regress.sh
+ depends_on: [ autogen ]
- name: build-10
image: *test-image
pull: always
commands:
- PGVER=10 sh ci/dronie/postgis_regress.sh
- name: build-11
image: *test-image
pull: always
commands:
- PGVER=11 sh ci/dronie/postgis_regress.sh
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 39af45e5b..001a6041b 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -7,17 +7,44 @@ service postgresql start $PGVER
export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
psql --version
-./autogen.sh
-./configure CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
-make clean
+# Out of tree build for given PostgreSQL version
+SRCDIR=$PWD
+BUILDDIR=/tmp/postgis-build/${PGVER}
+mkdir -p "${BUILDDIR}"
+cd "${BUILDDIR}"
+${SRCDIR}/configure CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
make -j
# we should maybe wait for postgresql service to startup here...
psql -c "select version()" template1
+# Pre-install tests
RUNTESTFLAGS=-v make check
+# Install
make install
+# Post-install tests
RUNTESTFLAGS=-v make installcheck
-CURRENTVERSION=`grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
-utils/check_all_upgrades.sh -s ${CURRENTVERSION}! | tee check.log
+# Upgrade tests
+CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
+${SRCDIR}/utils/check_all_upgrades.sh -s ${CURRENTVERSION}! | tee check.log
echo "-- Summary of upgrade tests --"
egrep '(PASS|FAIL)' check.log
Summary of changes:
.drone-1.0.yml | 11 +++++++++++
ci/dronie/postgis_regress.sh | 37 ++++++++++++++++++++++++++++++++-----
2 files changed, 43 insertions(+), 5 deletions(-)
hooks/post-receive
