[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-399-ga7298c25a
git at osgeo.org
git at osgeo.org
Fri Jan 28 11:13:05 PST 2022
the project "PostGIS".
via a7298c25a7531f78fb4a8c8861c407da942667cc (commit)
from 4fa57df0b3bd726346e1fd272921a29ab888b55f (commit)
revisions in full, below.
commit a7298c25a7531f78fb4a8c8861c407da942667cc
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jan 28 11:12:30 2022 -0800
Replace references to 'travis' with references to 'github'
in the CI scripts and script locations.
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index f18f5ebba..657843170 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -50,7 +50,7 @@ jobs:
uname -a
echo "FROM postgis/postgis-build-env:${{ matrix.ci.tag }}" > Dockerfile
echo "ADD --chown=postgres:postgres . /src/postgis" >> Dockerfile
- echo "CMD bash ci/travis/run_${{ matrix.ci.mode }}.sh" >> Dockerfile
+ echo "CMD bash ci/github/run_${{ matrix.ci.mode }}.sh" >> Dockerfile
docker build -t pgtest .
- name: 'Build & Test'
diff --git a/README.md b/README.md
index 148fb3e0d..f68922026 100644
--- a/README.md
+++ b/README.md
@@ -1,12 +1,12 @@
-| **Debbie** | **Winnie** | **Dronie** ||
+| **Debbie** | **Winnie** | **Dronie** |
| [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_trunk/) | [](https://winnie.postgis.net/view/PostGIS/job/PostGIS_trunk/) | [](https://dronie.osgeo.org/postgis/postgis?branch=master) ||
-| **Bessie** | **Bessie32** | **Cirrus-ci** ||
-| [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/) | [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/) | [](http://cirrus-ci.com/github/postgis/postgis) ||
-| **Berrie** | **Berrie64** | ||
+| **Bessie** | **Bessie32** | **Cirrus-CI** |
+| [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/) | [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/) | [](http://cirrus-ci.com/github/postgis/postgis) |
+| **Berrie** | **Berrie64** |
| [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/) | [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/) | ||
-| **GitHub** | **GitLab** ||
+| **GitHub** | **GitLab** |
| [](https://github.com/postgis/postgis/actions?query=branch%3Amaster) | [](https://gitlab.com/postgis/postgis/commits/master) ||
This file is here to play nicely with modern code repository facilities.
diff --git a/README.postgis b/README.postgis
index 0b84fb92d..e50a5f6fc 100644
--- a/README.postgis
+++ b/README.postgis
@@ -180,7 +180,7 @@ flags throughout. A way to get such an environment is to use the same docker ima
as the PostGIS CI setup and that can be done on a *nix host by first running this
in a cloned postgis repository to later get core dump log output:
-> sudo bash ./ci/travis/logbt --setup
+> sudo bash ./ci/github/logbt --setup
Then you can run the following to get a docker container up and running with the
correct requirements already in place and the postgis repository (at `/postgis`)
@@ -192,7 +192,7 @@ postgis/postgis-build-env:pg13-geos39-gdal31-proj71 /bin/bash
And finally the following command inside the container will build and run all the
postgis tests:
-> bash ./ci/travis/run_usan_gcc.sh
+> bash ./ci/github/run_usan_gcc.sh
You can make customized versions of `run_usan_gcc.sh` to run only specific tests
and skip redundant steps.
diff --git a/ci/travis/logbt b/ci/github/logbt
similarity index 100%
rename from ci/travis/logbt
rename to ci/github/logbt
diff --git a/ci/travis/run_coverage.sh b/ci/github/run_coverage.sh
rename from ci/travis/run_coverage.sh
rename to ci/github/run_coverage.sh
diff --git a/ci/travis/run_debug.sh b/ci/github/run_debug.sh
rename from ci/travis/run_debug.sh
rename to ci/github/run_debug.sh
diff --git a/ci/travis/run_garden.sh b/ci/github/run_garden.sh
similarity index 91%
rename from ci/travis/run_garden.sh
rename to ci/github/run_garden.sh
index e922b5897..678802013 100644
--- a/ci/travis/run_garden.sh
+++ b/ci/github/run_garden.sh
@@ -9,5 +9,5 @@ LDFLAGS_STD="--coverage"
./autogen.sh
./configure CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}" --enable-debug
make -j
-bash ./ci/travis/logbt -- make garden
+bash ./ci/github/logbt -- make garden
(curl -S -f https://codecov.io/bash -o .github/codecov.bash && bash .github/codecov.bash) || echo "Coverage report failed"
diff --git a/ci/travis/run_tests.sh b/ci/github/run_tests.sh
similarity index 87%
rename from ci/travis/run_tests.sh
rename to ci/github/run_tests.sh
index 36a34ecf0..581985343 100644
--- a/ci/travis/run_tests.sh
+++ b/ci/github/run_tests.sh
@@ -16,5 +16,5 @@ export CUNIT_VALGRIND_FLAGS="--leak-check=full --error-exitcode=1"
# Standard build
-bash ./ci/travis/logbt -- make -j
-bash ./ci/travis/logbt -- make check RUNTESTFLAGS=--verbose
+bash ./ci/github/logbt -- make -j
+bash ./ci/github/logbt -- make check RUNTESTFLAGS=--verbose
diff --git a/ci/travis/run_usan_clang.sh b/ci/github/run_usan_clang.sh
similarity index 90%
rename from ci/travis/run_usan_clang.sh
rename to ci/github/run_usan_clang.sh
index ac03e409c..70652ba0b 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/github/run_usan_clang.sh
@@ -17,5 +17,5 @@ LD_PRELOAD=/usr/lib/clang/11/lib/linux/libclang_rt.asan-x86_64.so \
# Build with Clang and usan flags
./autogen.sh
./configure CC=clang CFLAGS="${CFLAGS_USAN}" LDFLAGS="${LDFLAGS_STD}"
diff --git a/ci/travis/run_usan_gcc.sh b/ci/github/run_usan_gcc.sh
similarity index 81%
rename from ci/travis/run_usan_gcc.sh
rename to ci/github/run_usan_gcc.sh
index 3fb7135c2..3a66c2882 100644
--- a/ci/travis/run_usan_gcc.sh
+++ b/ci/github/run_usan_gcc.sh
@@ -10,5 +10,5 @@ LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
# Build with GCC and usan flags
./configure CC=gcc CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}"
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 0889b1128..a83b1975a 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -53,7 +53,7 @@
<varlistentry>
<term>Darafei Praliaskouski</term>
<listitem>
- <para>Index improvements, bug fixing and geometry/geography function improvements, SFCGAL, raster, GitHub curation, and Travis bot maintenance.</para>
+ <para>Index improvements, bug fixing and geometry/geography function improvements, SFCGAL, raster, GitHub curation, and bot maintenance.</para>
</listitem>
</varlistentry>
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index e45db0c71..c0d6a4fb5 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -35,7 +35,6 @@ SET statement_timeout TO 100;
select ST_Buffer(g,100) from _inputs WHERE id = 1;
--( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
-- it may take some more to interrupt st_buffer, see
--- https://travis-ci.org/postgis/postgis/builds/40211116#L2222-L2223
SELECT _timecheck('buffer', '200ms');
-- Not affected by old timeout
Summary of changes:
.github/workflows/ci.yml | 2 +-
README.md | 12 ++++++------
README.postgis | 4 ++--
ci/{travis => github}/logbt | 0
ci/{travis => github}/run_coverage.sh | 0
ci/{travis => github}/run_debug.sh | 0
ci/{travis => github}/run_garden.sh | 2 +-
ci/{travis => github}/run_tests.sh | 4 ++--
ci/{travis => github}/run_usan_clang.sh | 4 ++--
ci/{travis => github}/run_usan_gcc.sh | 4 ++--
doc/introduction.xml | 2 +-
regress/core/interrupt_buffer.sql | 1 -
12 files changed, 17 insertions(+), 18 deletions(-)
rename ci/{travis => github}/logbt (100%)
rename ci/{travis => github}/run_coverage.sh (100%)
rename ci/{travis => github}/run_debug.sh (100%)
rename ci/{travis => github}/run_garden.sh (91%)
rename ci/{travis => github}/run_tests.sh (87%)
rename ci/{travis => github}/run_usan_clang.sh (90%)
rename ci/{travis => github}/run_usan_gcc.sh (81%)
hooks/post-receive
