[postgis-tickets] [SCM] PostGIS branch master-letters created. 3.2.0-391-gacb518adc
Fri Jan 28 13:41:15 PST 2022
the project "PostGIS".
The branch, master-letters has been created
        at  acb518adc1ae74f35ae0f2c26c92b1661b5642b8 (commit)
commit acb518adc1ae74f35ae0f2c26c92b1661b5642b8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jan 28 13:41:08 2022 -0800
    Uninstall functions in the reverse order they were defined
diff --git a/utils/create_undef.pl b/utils/create_undef.pl
index 4036801dc..fb22e6d31 100755
--- a/utils/create_undef.pl
+++ b/utils/create_undef.pl
@@ -250,6 +250,7 @@ foreach my $tr (@triggers)
 print "-- Drop all functions except " . (keys %type_funcs) . " needed for type definition.\n";
+ at funcs = reverse(@funcs);
 foreach my $fn (@funcs)
 	if ($fn =~ /.* function ([^(]+)\((.*)\)/is ) # can be multiline
commit e3a7d0f286eb1b06d81bbdb1745b465db27b69ef
Date:   Fri Jan 28 13:23:47 2022 -0800
    Add ST_Letters function and documentation
diff --git a/NEWS b/NEWS
index fd7a7474d..d49a15be8 100644
--- a/NEWS
+++ b/NEWS
@@ -11,10 +11,14 @@ PostGIS 3.3.0dev
   - GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
   - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
+ * New features*
+  - ST_Letters creates geometries that look like letters.
 PostGIS 3.2.0 (Olivier Courtin Edition)
 2021/12/17
-This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher
-, and Proj 4.9+.
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+.
 Additional features are enabled if you are running GEOS 3.9+
 (and ST_MakeValid enhancements with 3.10+),
 Proj 6.1+, and PostgreSQL 14+.
@@ -28,9 +32,11 @@ If you are running PG14+, you can reenable it by doing
 ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
      ADD FUNCTION 11 (geometry)
      geometry_gist_sortsupport_2d (internal);
 and then reindex your gist indexes.
 To revert back to the old index behavior:
    ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
      DROP FUNCTION 11 (geometry);
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index 2f535e01a..0d03a09fa 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -99,6 +99,7 @@ IMAGES= \
 	../images/st_isvalid07.png \
 	../images/st_isvalid08.png \
 	../images/st_isvalid09.png \
+	../images/st_letters01.png \
 	../images/st_linecrossingdirection01.png \
 	../images/st_linecrossingdirection02.png \
 	../images/st_linecrossingdirection03.png \
diff --git a/doc/html/image_src/st_letters01.wkt b/doc/html/image_src/st_letters01.wkt
new file mode 100644
index 000000000..f9e39c557
--- /dev/null
+++ b/doc/html/image_src/st_letters01.wkt
@@ -0,0 +1 @@
+Style1;MULTIPOLYGON(((74.3 173.3,113.5 173.3,111.7 171.5,75.5 82.7,75.5 26.8,77.3 25,41.2 25,43.2 26.8,43.2 82.7,6.8 171.5,5 173.3,44.2 173.3,42.4 171.5,51.2 148.8,59.3 120.3,67.5 149.4,76.1 171.5,74.3 173.3)),((143.4 141.6,145.6 141.6,147.8 141.4,150 141.2,152 141,154.3 140.6,156.3 140.2,158.1 139.7,160.1 139.1,161.9 138.5,163.7 137.7,165.5 136.9,167.1 136.1,168.7 135.1,170.3 134.1,171.7 132.9,173.1 131.7,174.6 130.5,175.8 129.1,177 127.7,178 126.1,179 124.5,180 122.9,181 121.3,181.8 119.5,182.6 117.6,183.2 115.6,183.8 113.6,184.2 111.6,184.6 109.6,184.8 107.4,185 105.2,185 102.8,185 63,185 60.6,184.8 58.4,184.6 56.1,184.2 54.1,183.8 52.1,183.4 50.1,182.8 48.1,182 46.3,181.2 44.5,180.4 42.9,179.4 41.3,178.4 39.7,177.2 38.3,176 36.9,174.8 35.4,173.3 34.2,171.9 33,170.3 32,168.9 30.8,167.3 30,165.5 29,163.9 28.2,162.1 27.4,160.3 26.6,158.5 26,156.5 25.4,154.5 25,152.4 24.6,150.2 24.2,148 24,145.8 24,143.6 24,141.4 24,139.2 24.2,137 24.4,134.8 24.6,132.8 25,130.7 25.4,128.7 26,126.7 2
 6.6,124.9 27.2,123.1 28,121.3 28.8,119.7 29.8,118.1 30.8,116.5 31.8,115.1 32.8,113.7 34,112.3 35.2,111 36.7,109.8 38.1,108.8 39.5,107.8 41.1,106.8 42.7,105.8 44.5,105 46.3,104.2 48.1,103.6 50.1,103 52.1,102.6 54.1,102.2 56.3,102 58.6,101.8 60.8,101.8 63,101.8 102.8,101.8 105.2,102 107.4,102.2 109.6,102.6 111.6,103 113.6,103.4 115.6,104 117.6,104.8 119.5,105.6 121.3,106.4 122.9,107.4 124.5,108.4 126.1,109.6 127.5,110.8 128.9,112.1 130.3,113.5 131.5,114.9 132.7,116.5 133.7,117.9 134.7,119.7 135.7,121.3 136.7,123.1 137.5,124.9 138.3,126.7 138.9,128.7 139.5,130.5 140.2,132.5 140.6,134.8 141,136.8 141.2,139 141.4,141.2 141.6,143.4 141.6),(153.2 103.2,150.2 108.6,143.6 110.6,136.8 108.8,133.8 103.2,133.8 63,136.6 57.6,143.2 55.5,149.8 57.4,153.2 63,153.2 103.2)))
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 36adb4366..5daa9d598 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1200,5 +1200,49 @@ FROM admin0 WHERE name = 'Canada'
+    <refentry id="ST_Letters">
+        <refnamediv>
+        <refname>ST_Letters</refname>
+        <refpurpose>Returns the input letters rendered as geometry with a default start position at the origin and default text height of 100.</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Letters</function></funcdef>
+            <paramdef><type>text</type> <parameter> letters</parameter></paramdef>
+            <paramdef choice="opt"><type>double precision</type> <parameter> text_height=100.0</parameter></paramdef>
+            <paramdef choice="opt"><type>geometry</type> <parameter> start_position=POINT(0 0)</parameter></paramdef>
+            <paramdef choice="opt"><type>json</type> <parameter> font</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <title>Description</title>
+            <para>Uses a built-in font to render out a string as a multipolygon geometry. The default text height is 100.0, the distance from the bottom of a descender to the top of a capital. The default start position places the start of the baseline at the origin. Over-riding the font involves passing in a json map, with a character as the key, and base64 encoded TWKB for the font shape, with the fonts having a height of 1000 units from the bottom of the descenders to the tops of the capitals.
+            </para>
+            <para>Availability: 3.3.0</para>
+        </refsection>
+        <refsection>
+            <title>Example: Generating the word 'Yo'</title>
+            <programlisting>SELECT ST_AsText(ST_Letters('Yo'), 1);</programlisting>
+            <informalfigure>
+            <mediaobject>
+              <imageobject>
+                <imagedata fileref="images/st_letters01.png" />
+              </imageobject>
+              <caption><para>Letters generated by ST_Letters</para></caption>
+            </mediaobject>
+            </informalfigure>
+        </refsection>
+        <refsection>
+            <title>See Also</title>
+            <para><xref linkend="ST_AsTWKB" /></para>
+        </refsection>
+    </refentry>
   </sect1>
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index f3d3c4861..8960b784b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6708,8 +6708,8 @@ CREATE OR REPLACE FUNCTION ST_3DLineInterpolatePoint(geometry, float8)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
--- moved to separate file cause its invovled
+-- moved to separate file cause its involved
 #include "postgis_spgist.sql.in"
+#include "postgis_letters.sql"
 COMMIT;
diff --git a/postgis/postgis_letters.sql b/postgis/postgis_letters.sql
index 000000000..7e4161002
--- /dev/null
+++ b/postgis/postgis_letters.sql
@@ -0,0 +1,148 @@
+CREATE OR REPLACE FUNCTION ST_Letters(letters text, text_height double precision DEFAULT 100, start_position geometry DEFAULT ST_Point(0,0), font json DEFAULT NULL)
+RETURNS geometry
+AS
+DECLARE
+  letterarray text[];
+  letter text;
+  geom geometry;
+  prevgeom geometry = NULL;
+  adjustment float8 = 0.0;
+  position float8 = 0.0;
+  width float8;
+  m_width float8;
+  spacing float8;
+  dist float8;
+  wordarr geometry[];
+  wordgeom geometry;
+  -- geometry has been run through replace(encode(st_astwkb(geom),'base64'), E'\n', '')
+  font_default_height float8 = 1000.0;
+  font_default json = '{
+  "!":"BgACAQhUrgsTFOQCABQAExELiwi5AgAJiggBYQmJCgAOAg4CDAIOBAoEDAYKBgoGCggICAgICAgGCgYKBgoGCgQMBAoECgQMAgoADAIKAAoADAEKAAwBCgMKAQwDCgMKAwoFCAUKBwgHBgcIBwYJBgkECwYJBAsCDQILAg0CDQANAQ0BCwELAwsDCwUJBQkFCQcHBwcHBwcFCQUJBQkFCQMLAwkDCQMLAQkACwEJAAkACwIJAAsCCQQJAgsECQQJBAkGBwYJCAcIBQgHCAUKBQoDDAUKAQwDDgEMAQ4BDg==",
+  "&":"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",
+  "\"":"BgACAQUmwguEAgAAkwSDAgAAlAQBBfACAIACAACTBP8BAACUBA==",
+  "''":"BgABAQUmwguEAgAAkwSDAgAAlAQ=",
+  "(":"BgABAUOQBNwLDScNKw0rCysLLwsxCTEJMwc1BzcHNwM7AzsDPwE/AEEANwI1AjMEMwIzBjEGLwYvCC0ILQgrCCkKKQonCicMJbkCAAkqCSoHLAksBywFLgcuBS4FMAMwAzADMgEwATQBMgA0ADwCOgI6BDoEOAY4BjYINgg2CjQKMgoyCjIMMAwwDi7AAgA=",
+  ")":"BgABAUMQ3Au6AgAOLQwvDC8KMQoxCjEKMwg1CDUGNQY3BDcEOQI5AjkAOwAzATEBMQExAy8DLwMvBS8FLQctBS0HKwktBykJKwkpswIADCYKKAooCioIKggsCC4ILgYwBjAGMgQ0AjQCNAI2ADgAQgFAAz4DPAM8BzgHOAc2CTQJMgsyCzALLg0sDSoNKg==",
+  "+":"BgABAQ3IBOwGALcBuAEAANUBtwEAALcB0wEAALgBtwEAANYBuAEAALgB1AEA",
+  "/":"BgABAQVCAoIDwAuyAgCFA78LrQIA",
+  "4":"BgABAhDkBr4EkgEAEREApwJ/AADxARIR5QIAEhIA9AHdAwAA7ALIA9AG6gIAEREA8QYFqwIAAIIDwwH/AgABxAEA",
+  "v":"BgABASDmA5AEPu4CROwBExb6AgAZFdMC0wgUFaECABIU0wLWCBcW+AIAExVE6wEEFQQXBBUEFwQVBBUEFwQVBBUEFwQVBBUEFwQXBBUEFwYA",
+  ",":"BgABAWMYpAEADgIOAgwCDgQMBAoGDAYKBgoICAgICAgICAoGCgYKBAoEDAQKBAoCDAIKAgwCCgAKAAwACgEMAQoBCgMMAwoDCgUKBQgFCgUIBwYJCAcGCQYJBAsGCQQLAg0CCwINAg0AAwABAAMAAwADAQMAAwADAAMBBQAFAQcBBwEHAwcBCQMJAQsDCwMLAw0FDQMNBQ8FDwURBxMFEwkTBxcJFwkXswEAIMgBCQYJBgkGBwYJCAcIBQgHCgUKBQoFDAEMAwwBDgEOABA=",
+  "-":"BgABAQUq0AMArALEBAAAqwLDBAA=",
+  ".":"BgABAWFOrAEADgIOAg4CDgQMBAoGDAYKBgoICAgKCAgIBgoGCgYKBgoEDAQKBAwECgIMAAwCDAAMAAwBCgAMAQoDDAMKAwoDCgUKBQgFCgUIBwgJBgcICQYJBgsGCQQLAg0CDQINAA0ADQENAQ0BCwMNAwkFCwUJBQkHBwcJBwUHBwkFCQUJBQkDCwMJAwsDCQELAAsBCwALAAsCCQALAgkECwQJBAkECQYJBgcGBwgJBgcKBQgHCgUKBQwFCgEOAwwBDgEOAA4=",
+  "0":"BgABAoMB+APaCxwAHAEaARoDFgMYBRYFFAcUBxIJEgkQCRALEAsOCwwNDA0MDQoPCg0IDwgPBhEGDwYRBA8EEQIRAhMCEQITABMA4QUAEQETAREBEQMRAxEFEQURBREHDwkPBw8JDwsNCw0LDQ0NDQsNCw8JEQkRCREJEwcTBxUFFQUVAxUDFwEXARkAGQAZAhcCFwQXBBUGEwYTCBMIEQoRCg8KDwoPDA0MDQ4NDgsOCQ4JEAkQBxAHEAUSBRIDEgMSAxIDEgESARQAEgDiBQASAhQCEgISBBIEEgYSBhIGEggQChAIEAoQDBAMDgwODg4ODA4MEgwQChIKEggUCBQIFgYWBBYGGAQYAhgCGgILZIcDHTZBEkMRHTUA4QUeOUITRBIePADiBQ==",
+  "2":"BgABAWpUwALUA44GAAoBCAEKAQgDBgMGBQYFBgUEBwQFBAUCBwIHAgUABwAHAAUBBwMFAQcFBQMHBQUHBQcFBwMJAwkBCQELAQsAC68CAAAUAhIAFAISBBQCEgQUBBIEEgYUCBIGEAgSChAKEAoQDBAMDg4ODgwQDBIMEgoSChQIFggWCBgGGAQaAhwCHAIWABQBFgEUARQDFAMSAxQFEgUSBxIHEAkQCRALDgsODQ4NDA8KDwwRCBMKEwgTBhUGFwQXBBcEGwAbABsAHQEftwPJBdIDAACpAhIPzwYAFBIArgI=",
+  "1":"BgABARCsBLALAJ0LEhERADcA2QEANwATABQSAOYIpwEAALgCERKEBAASABER",
+  "3":"BgABAZ0B/gbEC/sB0QQOAwwBDAMMAwwFCgMKBQoFCgUIBwoFCAcICQgJBgkICQYLCAsECwYLBA0GDwINBA8CDwQRAhECEQITABUCFQAVAH0AEQETAREBEQETAxEDEQURBREFDwcRBw8JDwkNCQ8LDQsNDQsNCw0LDwsPCREJEQcRBxMFFQUVBRUDFwEXARkAGQAZAhkCFwQVBBUEEwYTCBEIEQgRCg0MDwoNDA0OCw4LDgkQCRAHEAkQBRAFEgUSAxIDFAMSAxYBFAEWARYAFqQCAAALAgkCCQQHAgcGBwYHBgUIBQYDCAMIAwYDCAEIAQgACAAIAAgCCAIIAgYCCAQIBAgGBgYEBgQIBAoCCgAKAAwAvAEABgEIAAYBBgMGAwQDBgMEBQQDBAUCBQQFAgUABwIFAJkBAACmAaIB3ALbAgAREQDmAhIRggYA",
+  "5":"BgABAaAB0APgBxIAFAESABIBEgMSARADEgMQAxIFEAcOBRAHDgkOCQ4JDgsMCwwLCgsKDQoPCA0IDwgPBhEEEwYTAhMEFwIXABcAiQIAEwETABEBEQMTAxEDDwMRBQ8FDwUPBw8JDQcNCQ0LDQsLCwsNCw0JDwkPCREHEQcTBxMFEwMVAxcDGQEZARkAFwAVAhUCFQQTBBMGEwYRCBEIDwoPCg8KDQwNDA0MCw4LDgkOCRAJEAcOBxAHEgUQBRIDEAMSAxIBEgEUARIAFLgCAAAFAgUABQIFBAUCBQQDBAUEAwYDBgMIAwgBCAEIAQoACAAIAgYACAQGAgQEBgQEBAQGBAQCBgIGAgYCBgIIAAYA4AEABgEIAAYBBgMGAQQDBgMEAwQFBAMCBQQFAgUABwIFAPkBAG+OAQCCBRESAgAAAuYFABMRAK8CjQMAAJ8BNgA=",
+  "7":"BgABAQrQBsILhQOvCxQR7wIAEhK+AvYIiwMAAKgCERKwBgA=",
+  "6":"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",
+  "8":"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",
+  "9":"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",
+  ":":"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",
+  "x":"BgABARHmAoAJMIMBNLUBNrYBMIQB1AIA9QG/BI4CvwTVAgA5hgFBwAFFxwE1fdUCAI4CwATzAcAE1AIA",
+  ";":"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",
+  "=":"BgACAQUawAUA5gHEBAAA5QHDBAABBQC5AgDsAcQEAADrAcMEAA==",
+  "B":"BgABA2e2BMQLFgAUARQBFAEUAxIDEgUSBRIFEAcQBxAJDgkOCQ4LDgsMCwwNDA0KDQgNCg0IDwYPBg8GDwQRBBEEEQIRAhMAEwAHAAkABwEHAAkBCQAHAQkBCQEHAQkBCQMJAwcDCQMJAwkFBwUJAwkHCQUHBQkHCQcJBwcHBwkHBwcJBwsHCQUQBQ4FDgcOCQ4JDAkMCwoNCg0IDwgRBhMEFQQXAhcCGwDJAQEvAysFJwklDSMPHREbFRkXFRsTHw8fCyUJJwcrAy0B6wMAEhIAoAsREuYDAAiRAYEElgEAKioSSA1EOR6JAQAA0wEJkAGPBSwSEiwAzAETKikSjwEAAMUCkAEA",
+  "A":"BgABAg/KBfIBqQIAN98BEhHzAgAWEuwCngsREvwCABMR8gKdCxIR8QIAFBI54AEFlwGCBk3TA6ABAE3UAwMA",
+  "?":"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",
+  "C":"BgABAWmmA4ADAAUCBQAFAgUEBQIDBAUEAwQDBgMEAQYDBgEGAAgBBgDWAgAAwQLVAgATABMCEQITBBEEEQQRBhEIEQgPCA8KDwoNCg0MDQwNDAsOCw4LDgkOCxAHEAkQBxIHEgUSBRIDEgEUARIBFAAUAMIFABQCFAISBBQEEgQSBhIIEggSCBAKEAoQCg4MDgwODA4ODA4MDgwQDA4KEggQChIIEggSBhIGFAQSAhQCEgIUAMYCAADBAsUCAAUABwEFAAUBBQMDAQUDAwMDAwMFAQMDBQEFAAUBBwAFAMEF",
+  "L":"BgABAQmcBhISEdkFABIQALQLwgIAAIEJ9AIAAK8C",
+  "D":"BgABAkeyBMQLFAAUARIBFAESAxIDEgMSBRIFEAcQBxAHDgkOCQ4LDgsMCwwNDA0KDwoPCg8IDwgRCBEGEwQTBBMEEwIVAhUAFwDBBQAXARcBFwMTAxUDEwUTBxEHEQcPCQ8JDwkNCw0LCwsLDQsNCQ0JDQcPBw8HDwcRBREFEQMRAxEDEwERARMBEwDfAwASEgCgCxES4AMACT6BAxEuKxKLAQAAvwaMAQAsEhIsAMIF",
+  "F":"BgABARGABoIJ2QIAAIECsgIAEhIA4QIRErECAACvBBIR5QIAEhIAsgucBQASEgDlAhES",
+  "E":"BgABARRkxAuWBQAQEgDlAhES0QIAAP0BtgIAEhIA5wIRFLUCAAD/AfACABISAOUCERLDBQASEgCyCw==",
+  "G":"BgABAZsBjgeIAgMNBQ8FDQUNBQ0HCwcNBwsHCwkLCQsJCwsJCwsLCQsJDQkLBw0HDwcNBw8FDwUPAw8DEQMPAxEBEQERARMBEQAXABUCFwIVAhMEFQQTBhMGEwYRCBEIDwoRCg8KDwwNDA0MDQ4LDgkQCRAJEAcQBxIFEgUUBRQDFAMUARYBFgEYAMoFABQCFAASBBQCEgQSBBIEEgYSBhAGEAgQCBAKDgoOCg4MDgwMDgwOChAKEAoSCBIIFAgUBhQEGAYWAhgEGAIaAOoCAAC3AukCAAcABwEFAQUBBQMFAwMFAwUDBQEFAQcBBQEFAQUABwAFAMUFAAUCBwIFAgUCBQQFBAMGBQYDBgUGAwgDBgMIAQgDCAEIAQoBCAEIAAgACgAIAAgCCAIIAggECgQGBAgECAYIBgC6AnEAAJwCmAMAAJcF",
+  "H":"BgABARbSB7ILAQAAnwsSEeUCABISAOAE5QEAAN8EEhHlAgASEgCiCxEQ5gIAEREA/QPmAQAAgAQPEOYCABER",
+  "I":"BgABAQmuA7ILAJ8LFBHtAgAUEgCgCxMS7gIAExE=",
+  "J":"BgABAWuqB7ILALEIABEBEwERAREDEwMRAxEFEQURBw8HEQcPCQ0LDwsNCw0NDQ0LDwsPCxEJEQkTCRMJFQcVBxcFFwMZAxsBGwEbAB8AHQIbAhsEGQYXBhcGFQgTCBMKEwoRDA8KDwwNDA0OCw4LDgkQCRAJEAcQBRIFEgUSAxQDEgESARIBFAESABIAgAEREtoCABERAn8ACQIHBAcEBwYHBgUIBQoDCgMKAwoDDAEKAQwBCgEMAAwACgAMAgoCDAIKBAoECgYKBggGBgYGCAQGBAgCCgAIALIIERLmAgAREQ==",
+  "M":"BgACAQRm1gsUABMAAAABE5wIAQDBCxIR5QIAEhIA6gIK5gLVAe0B1wHuAQztAgDhAhIR5QIAEhIAxAsUAPoDtwT4A7YEFgA=",
+  "K":"BgABAVXMCRoLBQsDCQMLAwsDCwMLAwsBCwELAQsBCwELAQ0ACwELAAsADQALAg0ACwILAA0CCwILAgsCDQQLBAsECwYNBAsGCwYLCAsGCwgJCgsICQoJCgkMCQwJDAkOCRALEAkQCRKZAdICUQAAiwQSEecCABQSAKALExLoAgAREQC3BEIA+AG4BAEAERKCAwAREdkCzQXGAYUDCA0KDQgJCgkMBwoFDAUMAQwBDgAMAg4CDAQOBAwGDghmlQI=",
+  "O":"BgABAoMBsATaCxwAHAEaARoDGgMYBRYFFgcWBxQJEgkSCRILEAsODQ4NDg0MDwoNDA8KDwgPCBEIDwYRBg8GEQQRAhMCEQITABMA0QUAEQETAREBEQMTBREFEQURBxEHDwcRCQ8LDQsPCw0NDQ0NDwsPCw8LEQkTCRMJEwkVBxUHFwUXAxkDGQEbARsAGwAZAhkCGQQXBhcGFQYVCBUIEwoRChEMEQoRDA8MDQ4NDg0OCxAJEAsQCRAHEgcSBxIFFAMSAxIDEgEUARIAEgDSBQASAhQCEgISBBIEEgYSBhIIEggQCBAKEgwODBAMEA4ODg4QDhIMEAwSChQKFAgUCBYIFgYYBBoGGgQcAh4CHgILggGLAylCWxZbFSlBANEFKklcGVwYKkwA0gU=",
+  "N":"BgABAQ+YA/oEAOUEEhHVAgASEgC+CxQAwATnBQDIBRMS2AIAExEAzQsRAL8ElgU=",
+  "P":"BgABAkqoB5AGABcBFQEVAxMDEwMTBREHEQcRBw8JDwkNCQ0LDQsNCwsNCw0JDQkNCQ8HDwcPBxEFEQURAxEDEQMTAREBEwETAH8AAIMDEhHlAgASEgCgCxES1AMAFAAUARIAFAESAxIDEgMSAxIFEAUQBRAHDgkOCQ4JDgsMCwwNDA0KDQoNCg8IDwgRCBEGEwQTBBUEFQIXAhkAGQCzAgnBAsoCESwrEn8AANUDgAEALBISLgDYAg==",
+  "R":"BgABAj9msgsREvYDABQAFAESARQBEgESAxIDEgUSBRAFEAcQBw4JDgkOCQ4LDAsMDQwLCg0KDwoNCA8IDwgPBhEEEwYTAhMEFQIXABcAowIAEwEVARMDEwMTBRMFEQcTBxELEQsRDQ8PDREPEQ0VC8QB/QMSEfkCABQSiQGyA3EAALEDFBHnAgASEgCgCwnCAscFogEALhISLACqAhEsLRKhAQAApQM=",
+  "Q":"BgABA4YBvAniAbkB8wGZAYABBQUFAwUFBQUHBQUDBwUFBQcFBQMHBQcDBwUJAwcDCQMJAwkDCQMJAQsDCwMLAQsDCwENAw0BDQEPAA8BDwAPABsAGwIZAhcEGQQXBBUGFQgVCBMIEQoTChEKDwwPDA8ODQ4NDgsQCxAJEAkQBxIHEgUSBRQFFAMUARQDFAEWABYAxgUAEgIUAhICEgQSBBIGEgYSCBIIEAgQChIMDgwQDBAODg4OEA4SDBAMEgoUChQIFAgWCBYGGAQaBhoEHAIeAh4CHAAcARoBGgMaAxgFFgUWBxYHFAkSCRIJEgsQCw4NDg0ODQwPCg0MDwoPCA8IEQgPBhEGDwYRBBECEwIRAhMAEwC7BdgBrwEImQSyAwC6AylAWxZbFSk/AP0BjAK7AQeLAoMCGEc4J0wHVBbvAaYBAEM=",
+  "S":"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",
+  "V":"BgABARG2BM4DXrYEbKwDERL0AgAVEesCnQsSEfsCABQS8QKeCxES8gIAExFuqwNgtQQEAA==",
+  "T":"BgABAQskxAv0BgAAtQKVAgAA+wgSEeUCABISAPwImwIAALYC",
+  "U":"BgABAW76B7ALAKMIABcBFwMXARUFFQUTBxMHEwkRCREJEQsPDQ0LDw0NDwsPCw8LEQkPCRMJEQcTBxMFEwUVBRUDEwMXARUBFQEXABUAEwIVAhMCFQQTBBUEEwYTBhMIEwgRChEIEQwRDA8MDw4PDg0OCxANEAsSCRIJEgcUBxQHFAMWBRYBGAEYARgApggBAREU9AIAExMAAgClCAALAgkECQQHBAcIBwgHCAUKBQoDCgMKAwwBCgEMAQwADAAMAgoCDAIKAgoECgQKBggGCAYICAYKBAgCCgIMAgwApggAARMU9AIAExM=",
+  "X":"BgABARmsCBISEYkDABQSS54BWYICXYkCRZUBEhGJAwAUEtYCzgXVAtIFExKIAwATEVClAVj3AVb0AVKqAREShgMAERHXAtEF2ALNBQ==",
+  "W":"BgABARuODcQLERHpAp8LFBHlAgASEnW8A2+7AxIR6wIAFBKNA6ALERKSAwATEdQB7wZigARZ8AIREugCAA8RaKsDYsMDXsoDaqYDExLqAgA=",
+  "Y":"BgABARK4BcQLhgMAERHnAvMGAKsEEhHnAgAUEgCsBOkC9AYREoYDABERWOEBUJsCUqICVtwBERI=",
+  "Z":"BgABAQmAB8QLnwOBCaADAADBAusGAMgDggmhAwAAwgLGBgA=",
+  "`":"BgABAQfqAd4JkQHmAQAOlgJCiAGpAgALiwIA",
+  "c":"BgABAW3UA84GBQAFAQUABQEFAwMBBQMDAwMDAwUBAwMFAQUABQEHAAUAnQMABQIFAAUCBQQFAgMEBQQDBAMGAwQBBgMGAQYABgEGAPABABoMAMsCGw7tAQATABMCEwARAhMEEQIPBBEEDwQPBg8IDwYNCA0KDQoNCgsMCwwLDAkOCRAHDgcQBxIFEgUUBRQDFAEWAxgBGAAYAKQDABQCFAISBBQCEgYSBhAGEggQCBAIEAoQCg4MDAwODAwODAwKDgwQCg4IEAgQCBAIEAYSBhIGEgQSAhQCFAIUAOABABwOAM0CGQzbAQA=",
+  "a":"BgABApoB8AYCxwF+BwkHCQcJCQkHBwkHBwcJBQkFBwUJBQkFCQMHBQkDCQMJAwcDCQEHAQkBBwEJAQcABwAHAQcABQAHAAUBBQAFABMAEwITAhEEEwQPBBEGDwgPCA0IDwoLCg0KCwwLDAsMCQ4JDgkOBw4HEAcQBRAFEAUSAxADEgESAxIBFAESABQAFAISAhQCEgQSBBIEEgYSBhIIEAgQChAIDgwODA4MDg4MDgwODBAMEAoSCBIKEggUCBQGFgYWBBgEGAIaAhoAcgAADgEMAQoBCgEIAwgDBgUEBQQFBAcCBwIHAgkCCQAJAKsCABcPAMwCHAvCAgAUABYBEgAUARIDFAMQAxIDEAUSBQ4FEAcOCRAJDAkOCwwLDA0MCwoNCg8IDwgPCA8GEQYRBhMEEwIXAhUCFwAZAIMGFwAKmQLqA38ATxchQwgnGiMwD1AMUDYAdg==",
+  "b":"BgABAkqmBIIJGAAYARYBFgEUAxQDEgUSBRIFEAcQCQ4HDgkOCw4LDAsMDQoNCg0KDQgPBg8GDwYRBBEEEQQTBBECEwIVAhMAFQD/AgAZARcBFwEXAxUDEwUTBREFEQcPBw8JDwkNCQ0LDQsLCwsNCQ0JDQcPBw8HDwURAxEDEQMTAxMBEwMVARUAFQHPAwAUEgCWCxEY5gIAERkAowKCAQAJOvECESwrEn8AAJsEgAEALBISLgCeAw==",
+  "d":"BgABAkryBgDLAXAREQ8NEQ0PDREJDwkRBw8FDwURAw8DDwERAw8BEQEPACMCHwQfCB0MGw4bEhcUFxgVGhEeDSANJAkmBSgDKgEuAIADABYCFAIUAhQCFAQUBBIGEgYSBhAIEAgQCBAKDgoODAwMDAwMDgoOCg4KEAgQCBIGEgYSBhQEFgQWBBYCGAIYAHwAAKQCERrmAgARFwCnCxcADOsCugJGMgDmA3sAKxERLQCfAwolHBUmBSQKBAA=",
+  "e":"BgABAqMBigP+AgAJAgkCCQQHBAcGBwYFCAUIBQgDCgMIAQoDCAEKAQoACgAKAAoCCAIKAggECgQIBAgGCAYGBgQIBAoECAIKAAyiAgAAGQEXARcBFwMVBRMFEwURBxEHDwcPCQ8LDQkNCwsNCw0LDQkNBw8JDwcPBQ8FEQURAxEDEwMTAxMBFQAVARcALwIrBCkIJwwlDiESHxQbGBkaFR4TIA0iCyQJKAMqASwAggMAFAIUABIEFAISBBIEEgQSBhIGEAgQCBAIEAoODA4MDgwODgwQDBAKEAoSChIIFAgUCBYGGAQYBhoCGgQcAh4ALgEqAygFJgkkDSANHhEaFRgXFBsSHQ4fDCUIJwQpAi0AGQEXAxcDFQcTBRMJEQkPCw8LDQ0PDQsNDQ8LEQsRCxEJEwkTCRMJEwcTBxUHFQUVBRUHFQUVBRUHFwcVBRUHCs4BkAMfOEUURxEfMwBvbBhAGBwaBiA=",
+  "h":"BgABAUHYBJAGAAYBBgAGAQYDBgEEAwYDBAMEBQQDAgUEBQIFAAUCBQB1AAC5BhIT5wIAFhQAlAsRGOYCABEZAKMCeAAYABgBFgEWARQDFAMSBRIFEgUQBxAJDgcOCQ4LDgsMCwwNCg0KDQoNCA8GDwYPBhEEEQQRBBMEEQITAhUCEwAVAO0FFhPnAgAUEgD+BQ==",
+  "g":"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",
+  "f":"BgABAUH8A6QJBwAHAAUABwEFAQcBBQEFAwUDBQMDAwMDAwUDAwMFAQUAwQHCAQAWEgDZAhUUwQEAAOMEFhftAgAWFADKCQoSChIKEAoQCg4KDgwOCgwMDAoKDAwMCgwIDAgMCAwIDAYOCAwEDgYMBA4GDAIOBA4CDgQOAg4CDgAOAg4ADgC2AQAcDgDRAhkQowEA",
+  "i":"BgACAQlQABISALoIERLqAgAREQC5CBIR6QIAAWELyAoADgIOAgwEDgIKBgwGCgYKCAoGCAgICggIBggGCgYKBAoECgQMBAoCDAIMAgwCDAAMAAwADAEMAQoBDAMKAwoDCgUKBQgFCgUIBwgHCAcICQgJBgkECwQJBA0CCwANAA0ADQELAQ0BCwMJBQsFCQUJBwkFBwcHBwcJBQcFCQUJBQkDCQMLAwkBCwELAQsACwALAAsCCwILAgkCCwIJBAkECQQJBgcGCQYHCAcIBwgHCgUKBQwFCgMMAQwBDgEMAA4=",
+  "j":"BgACAWFKyAoADgIOAgwEDgIKBgwGCgYKCAoGCAgICggIBggGCgYKBAoECgQMBAoCDAIMAgwCDAAMAAwADAEMAQoBDAMKAwoDCgUKBQgFCgUIBwgHCAcICQgJBgkECwQJBA0CCwANAA0ADQELAQ0BCwMJBQsFCQUJBwkFBwcHBwcJBQcFCQUJBQkDCQMLAwkBCwELAQsACwALAAsCCwILAgkCCwIJBAkECQQJBgcGCQYHCAcIBwgHCgUKBQwFCgMMAQwBDgEMAA4BO+YCnwwJEQkRCQ8JDwsNCQ0LDQkLCwsJCQsLCQkLBwsHCwcLBwsFCwcNAwsFDQMLBQ0BDQMNAQ0DDQENAQ0ADQENAA0AVwAbDQDSAhoPQgAIAAgABgAIAgYCCAIGAgYEBgQGBAQEBAQEBgQEBAYCBgC4CRES6gIAEREAowo=",
+  "k":"BgABARKoA/QFIAC0AYoD5gIAjwK5BJICwwTfAgDDAbIDFwAAnwMSEeUCABISAJILERLmAgAREQCvBQ==",
+  "n":"BgABAW1yggmQAU8GBAgEBgQGBgYCCAQGBAYEBgQIAgYECAQGAggEBgIIBAgCCAQIAggCCAIIAgoACAIKAAgCCgAKAgoADAAKAgwAFgAWARQAFAEUAxQDFAMSAxIFEgUQBRIHEAkOBxAJDgsOCwwLDA0MDQoPCA8IEQgRBhEGEwYVBBUEFQIXAhkCGQDtBRQR5QIAFBAA/AUACAEIAQYBCAMGBQQFBgUEBwQFBAcCBwIHAgcCCQIHAAcACQAHAQcABwMHAQUDBwMFAwUFBQUDBQEFAwcBBwAHAPkFEhHjAgASEgDwCBAA",
+  "m":"BgABAZoBfoIJigFbDAwMCg4KDggOCA4IDgYQBhAGEAQQBBAEEAISAhACEgAmASQDJAciCyANHhEcFRwXDg4QDBAKEAwQCBAKEggSBhIGEgYSBBQEEgIUAhICFAAUABQBEgEUARIDEgMSAxIFEgUQBxAHEAcQBw4JDgkOCw4LDAsMDQoNCg8KDwgPCBEIEQYRBBMEEwQTAhMCFQAVAP0FEhHlAgASEgCCBgAIAQgBBgEGAwYFBgUEBQQHBAUEBwIHAgcCBwIJAAcABwAJAAcBBwEHAQUBBwMFAwUDBQMDBQMFAwUBBQEHAQcAgQYSEeUCABISAIIGAAgBCAEGAQYDBgUGBQQFBAcEBQQHAgcCBwIHAgkABwAHAAkABwEHAQcBBQEHAwUDBQMFAwMFAwUDBQEFAQcBBwCBBhIR5QIAEhIA8AgYAA==",
+  "l":"BgABAQnAAwDrAgASFgDWCxEa6gIAERkA0wsUFw==",
+  "y":"BgABAZ8BogeNAg8ZERkRFxEVExMVERUPFQ8XDRcLGQkZBxsFGwUdAR0BDQALAA0ADQINAAsCDQANAg0CDQILAg0EDQINBA0GDQQNBg0EDQYNCA0GDwgNCA0IDQgPCg0KDwwNDA8MDw4PDqIB7gEQDRALEAkQCQ4JEAcOBw4FDgUOAwwFDgMMAQwBDAEMAQwACgEKAAoACAIIAAgCCAIGAggCBgIGBAYCBgQEAgYEAqIBAQADAAEBAwADAAMABQADAAUAAwAFAAMABQAFAAMABQA3ABMAEwIRABECEwQRAg8EEQQPBBEGDwgNCA8IDQgNCg0MDQwLDAkOCw4JDgcQBxAHEgUSBRQFFAMWARgDGAEaABwA9AUTEuQCABEPAP8FAAUCBQAFAgUEBQIDBAUEAwQDBgMEAQYDBgEGAAgBBgCAAQAAvAYREuICABMPAP0K",
+  "q":"BgABAmj0A4YJFgAWARQAEgESAxADEAMOAw4FDgUMBQ4HDgcOBwwJDgmeAU4A2QwWGesCABYaAN4DAwADAAMBAwADAAUAAwADAAMABQAFAAUABwAHAQcACQAVABUCFQATAhUCEwQRAhMEEQQRBhEGDwgPCA8IDQoNDA0MCwwLDgkOCRAJEAkQBxIHEgUUBRYDFgMYARoBGgAcAP4CABYCFgIWBBYEFAQSBhQIEggSCBAKEgoQDA4MDgwODg4ODBAMDgwQChIIEAoSCBIGEgYUBhQEFAQWAhYCFgIWAApbkQYSKy4ReAAAjARTEjkRHykJMwDvAg==",
+  "p":"BgABAmiCBIYJFgAWARYBFAEWAxQDEgUUBRIFEgcSBxAJEAkQCQ4LDgsOCwwNDA0KDwoPCg8IEQgRCBEGEwQTBhMCFQQVAhUAFQD9AgAbARkBFwMXAxcDEwUTBxMHEQcRCQ8JDQsNCw0LCw0LDQkPCQ0JDwURBxEFEQURAxMDEQMTARUBEwEVARUBFQAJAAcABwAFAAcABQAFAAMAAwADAAUAAwIDAAMAAwIDAADdAxYZ6wIAFhoA2gyeAU0OCgwIDgoMCA4GDgYMBg4GDgQQBBAEEgQUAhQCFgIWAApcoQMJNB8qNxJVEQCLBHgALhISLADwAg==",
+  "o":"BgABAoMB8gOICRYAFgEWARQBFgMUAxIDFAUSBRIHEgcQBxAJEAkOCw4LDgsMDQwNCg8KDwoPCg8IEQgRBhMGEwQTBBMCFQIVABcAiwMAFwEVARUDEwMTAxMFEwcRBxEHDwkPCQ8LDQsNCw0NCw0LDwkNCw8HEQkPBxEHEQcRBRMFEwMTAxUDFQEVABUAFQAVAhUCFQITBBMEEwYTBhEGEQgRCA8KDwoPCg0KDQwNDAsOCw4JDgkQCRAJEgcSBxIFFAUUAxQDFgEWARYAFgCMAwAYAhYCFgQUBBQEFAYUCBIIEggQChAKEAwODA4MDg4MDgwQCg4KEgoQChIIEggSBhQGEgYUBBYEFAIWAhYCFgALYv0CHTZBFEMRHTcAjwMcNUITQhIiOACQAw==",
+  "r":"BgACAQRigAkQAA8AAAABShAAhAFXDAwODAwKDgoOCBAIDgYQBhAEEAQQBBAEEAISABACEAAQAA4BEAAQARADEAEQAxADEAUSBRIHFAcUCxQLFA0WDVJFsQHzAQsMDQwLCgkICwgLCAkGCQYJBAkGBwIJBAcCBwQHAAcCBwAFAgcABQAHAQUABQEFAQUBBQEDAQUBAwMDAQMDAwEAmwYSEeMCABISAO4IEAA=",
+  "u":"BgABAV2KBwGPAVANCQsHDQcNBw0FCwUNBQ0FDQMPAw8DEQMTARMBFQEVABUAFQITABMEEwITBBMEEQQRBhEGDwYRCA8KDQgPCg0MDQwLDAsOCRALDgcQBxIHEgUUBRQFFAMWAxgBGAEYARoA7gUTEuYCABMPAPsFAAcCBwIFBAcCBQYDBgUGAwgDBgMIAQgBCAEIAQoBCAAIAAoACAIIAggCCAIGBAgEBgQGBgYGBAYCBgQIAggACAD6BRES5AIAEREA7wgPAA==",
+  "s":"BgABAasC/gLwBQoDCgMMBQ4DDgUOBRAFEAUSBRAHEgcQCRIJEAkSCxALEAsQDRANDg0ODw4PDA8MDwoRChEIEwYTBBcCFQIXABkBGQEXAxcFFQUTBRMHEwcRCREJDwkNCQ8LDQ0LCwsNCw0JDQkPBw8HDwUPBREDEQMRAREDEQETABEBEwARABMADwIRABECEQIRBBMCEwQVBBUEFQYVBhMIFwgVChUKFQxgsAIIAwYDCAMKAQgDCAMKAQoDCgEKAwoBCgMKAQwDCgEKAwoBDAMKAQoBCgEMAQoACgEKAAoBCgAKAQgACgAIAQgABgoECAIKAgoCCgAMAQoBDAUEBwIHBAcEBwIHBAkECQQJBAkECQYLBAkGCwYJBgsGCwYJCAsGCwgJBgsICQgLCAkICwgJCgkKCQoJCgcKCQwHDAcMBwwFDAcMAw4FDAMOAw4BDgMQARAAEAESABIAEgIQAg4CDgIOBA4CDgQMBAwEDAQMBgoECgYKBgoGCgYIBggGCAgIBggGBgYIBgYGBgYGBgYGBAgGBgQIBAYECAQQChIIEggSBhIEEgQSBBQCFAISABQAEgASABIAEgESARIBEAEQAxIDDgMQAxADDgUOBQwDDAMMAwoDCAMIAQYBe6cCAwIDAgUAAwIFAgUCBwIFAgcCBQIHAgUCBwIHAAUCBwIHAgUABwIHAgcABQIHAAcCBwAFAgUABQIFAAUABQIDAAEAAQABAQEAAQEBAQEBAQEBAQEDAQEAAwEBAQMAAwEDAAMBAwADAQMAAwABAQMAAwADAAEAAwIBAAMCAQQDAgE=",
+  "t":"BgABAUe8BLACWAAaEADRAhsOaQANAA0ADwINAA0CDQANAg0CDQINBA0CCwYNBA0GCwYNBgsIDQgLCAsKCwgJDAsKCQwJDAkOCQ4HEAcSBxIHEgUUAOAEawAVEQDWAhYTbAAAygIVFOYCABUXAMUCogEAFhQA1QIVEqEBAADzAwIFBAMEBQQDBAMEAwYDBgMGAwYBCAEGAQgBBgEIAAgA",
+  "w":"BgABARz8BsAEINYCKNgBERLuAgARD+8B3QgSEc0CABQSW7YCV7UCFBHJAgASEpMC3AgREvACABERmAHxBDDaAVeYAxES7gIAEREo1QE81wIIAA==",
+  "z":"BgABAQ6cA9AGuQIAFw8AzAIaC9QFAAAr9wKjBuACABYQAMsCGQyZBgCaA9AG"
+BEGIN
+  IF font IS NULL THEN
+    font := font_default;
+  END IF;
+  -- For character spacing, use m as guide size
+  geom := ST_GeomFromTWKB(decode(font->>'m', 'base64'));
+  m_width := ST_XMax(geom) - ST_XMin(geom);
+  spacing := m_width / 12;
+  letterarray := regexp_split_to_array(replace(letters, ' ', E'\t'), E'');
+  FOREACH letter IN ARRAY letterarray
+  LOOP
+    geom := ST_GeomFromTWKB(decode(font->>(letter), 'base64'));
+    -- Chars are not already zeroed out, so do it now
+    geom := ST_Translate(geom, -1 * ST_XMin(geom), 0.0);
+    -- unknown characters are treated as spaces
+    IF geom IS NULL THEN
+      -- spaces are a "quarter m" in width
+      width := m_width / 3.5;
+    ELSE
+      width := (ST_XMax(geom) - ST_XMin(geom));
+    END IF;
+    geom := ST_Translate(geom, position, 0.0);
+    -- Tighten up spacing when characters have a large gap
+    -- between them like Yo or To
+    adjustment := 0.0;
+    IF prevgeom IS NOT NULL AND geom IS NOT NULL THEN
+      dist = ST_Distance(prevgeom, geom);
+      IF dist > spacing THEN
+        adjustment = spacing - dist;
+        geom := ST_Translate(geom, adjustment, 0.0);
+      END IF;
+    END IF;
+    prevgeom := geom;
+    position := position + width + spacing + adjustment;
+    wordarr := array_append(wordarr, geom);
+  END LOOP;
+  -- apply the start point and scaling options
+  wordgeom := ST_CollectionExtract(ST_Collect(wordarr));
+  wordgeom := ST_Translate(ST_Scale(wordgeom,
+                text_height/font_default_height, text_height/font_default_height),
+                ST_XMin(start_position), ST_YMin(start_position));
+  return wordgeom;
+END;
+LANGUAGE 'plpgsql'
+IMMUTABLE STRICT _COST_MEDIUM;
hooks/post-receive
