[postgis-tickets] [PostGIS] #5073: Localized docs are broken structurally
trac at osgeo.org
Sun Jan 30 15:16:31 PST 2022
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: l18n | Version: master
Keywords: |
Running `make -C doc check-localized` shows many errors in multiple
languages.
Example:
make[2]: Entering directory '/home/src/postgis/postgis/doc/po/pt_BR'
/usr/bin/perl -lpe
"s'@@LAST_RELEASE_VERSION@@'3.3.0dev'g;s'@@POSTGIS_DOWNLOAD_URL@@'http://postgis.net/stuff'g;"
postgis.xml > postgis-out.xml
/usr/bin/xsltproc --novalid --path . xsl/postgis_aggs_mm.xml.xsl postgis-
out.xml > postgis_aggs_mm.xml
/usr/bin/xmllint --loaddtd --path . --xinclude --valid postgis-out.xml >
/dev/null
reference_management.xml:557: element funcprototype: validity error :
Element funcprototype content does not follow the DTD, expecting
(modifier* , funcdef , (void | varargs | (paramdef+ , varargs?)) ,
modifier*), got (funcprototype funcprototype )
> </funcprototype>
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5073>
