[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-408-g8fb375fb1
git at osgeo.org
git at osgeo.org
Sun Jan 30 15:12:48 PST 2022
the project "PostGIS".
via 8fb375fb18d96ff0c11ec9a1fd55a5cdc0fc220f (commit)
via 98c1ed850a1a4adb8d1f921e39ef41036fa58d23 (commit)
from ff06be517be9aecf566cd00a7ca52c8878a5fbd4 (commit)
revisions in full, below.
commit 8fb375fb18d96ff0c11ec9a1fd55a5cdc0fc220f
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Jan 29 13:35:49 2022 +0100
[drone] Build localized docs out-of-tree
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index e4c6b08cd..6e6f0ec4c 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -55,8 +55,9 @@ steps:
pull: never
commands:
- apt update -qq && apt install -y poxml libsfcgal-dev
- - mkdir /tmp/pgis-docs - && cp -a * /tmp/pgis-docs
- - cd /tmp/pgis-docs # out-of-build html-localized is broken...
- - ./configure
+ - mkdir -p /tmp/postgis-build/docs
+ - pwd > /tmp/postgis-build/docs/.srcdir
+ - cd /tmp/postgis-build/docs
+ - sh `cat .srcdir`/configure
- make docs-localized
depends_on: [ autogen ]
commit 98c1ed850a1a4adb8d1f921e39ef41036fa58d23
Date: Sat Jan 29 13:35:39 2022 +0100
Fix out-of-tree build of localized docs
Closes #5067
diff --git a/.gitignore b/.gitignore
index 2e1a65377..c69659617 100644
--- a/.gitignore
+++ b/.gitignore
@@ -31,6 +31,7 @@ doc/Makefile
doc/Makefile.comments
doc/po/*/*.xml
doc/po/*/html
+doc/po/*/Makefile
doc/po/*/xsl
doc/po/*/*_comments.sql
doc/postgis_aggs_mm.xml
diff --git a/configure.ac b/configure.ac
index 8764220de..07307a46f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1689,6 +1689,15 @@ dnl ===========================================================================
dnl Output the relevant files
+TRANSLATIONS_MAKEFILE_LIST=`grep 'translations = ' ${srcdir}/doc/Makefile.in \
+ | cut -d= -f2 \
+ | tr ' ' '\n' \
+ | grep -v '^ *$' \
+ | sed 's|^|doc/po/|;s|$|/Makefile|'
+dnl echo "TRANSLATIONS_MAKEFILE_LIST: ${TRANSLATIONS_MAKEFILE_LIST}"
AC_CONFIG_FILES([GNUmakefile
extensions/Makefile
extensions/postgis/Makefile
@@ -1717,6 +1726,7 @@ AC_CONFIG_FILES([GNUmakefile
regress/loader/Makefile
doc/Makefile
+ $TRANSLATIONS_MAKEFILE_LIST
doc/html/image_src/Makefile
utils/Makefile
$RT_MAKEFILE_LIST
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 7ce5fb714..a2f405aff 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -220,39 +220,39 @@ endif
ifeq ($(XSLTPROC),)
postgis_aggs_mm.xml: requirements_not_met_xsltproc
else
-postgis_aggs_mm.xml: ./xsl/postgis_aggs_mm.xml.xsl Makefile postgis-out.xml $(XML_SOURCES)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/postgis_aggs_mm.xml.xsl postgis-out.xml > $@
+postgis_aggs_mm.xml: xsl/postgis_aggs_mm.xml.xsl Makefile postgis-out.xml $(XML_SOURCES)
+ $(XSLTPROC) --novalid --path $(srcdir) $< postgis-out.xml > $@
endif
-postgis_comments.sql: ./xsl/postgis_comments.sql.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/postgis_comments.sql.xsl postgis-out.xml > $@
+postgis_comments.sql: xsl/postgis_comments.sql.xsl $(XML_INPUTS)
-postgis_cheatsheet.html: ./xsl/postgis_cheatsheet.html.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/postgis_cheatsheet.html.xsl postgis-out.xml > $@
+postgis_cheatsheet.html: xsl/postgis_cheatsheet.html.xsl $(XML_INPUTS)
-raster_comments.sql: ./xsl/raster_comments.sql.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/raster_comments.sql.xsl postgis-out.xml > $@
+raster_comments.sql: xsl/raster_comments.sql.xsl $(XML_INPUTS)
raster_cheatsheet.html: ./xsl/raster_cheatsheet.html.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/raster_cheatsheet.html.xsl postgis-out.xml > $@
-topology_comments.sql: ./xsl/topology_comments.sql.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/topology_comments.sql.xsl postgis-out.xml > $@
+topology_comments.sql: xsl/topology_comments.sql.xsl $(XML_INPUTS)
-topology_cheatsheet.html: ./xsl/topology_cheatsheet.html.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/topology_cheatsheet.html.xsl postgis-out.xml > $@
+topology_cheatsheet.html: xsl/topology_cheatsheet.html.xsl $(XML_INPUTS)
-sfcgal_comments.sql: ./xsl/sfcgal_comments.sql.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/sfcgal_comments.sql.xsl postgis-out.xml > $@
+sfcgal_comments.sql: xsl/sfcgal_comments.sql.xsl $(XML_INPUTS)
-sfcgal_cheatsheet.html: ./xsl/sfcgal_cheatsheet.html.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/sfcgal_cheatsheet.html.xsl postgis-out.xml > $@
+sfcgal_cheatsheet.html: xsl/sfcgal_cheatsheet.html.xsl $(XML_INPUTS)
-tiger_geocoder_comments.sql: ./xsl/tiger_geocoder_comments.sql.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/tiger_geocoder_comments.sql.xsl postgis-out.xml > $@
+tiger_geocoder_comments.sql: xsl/tiger_geocoder_comments.sql.xsl $(XML_INPUTS)
-tiger_geocoder_cheatsheet.html: ./xsl/tiger_geocoder_cheatsheet.html.xsl $(XML_INPUTS)
- $(XSLTPROC) --novalid --path $(srcdir) $(srcdir)/xsl/tiger_geocoder_cheatsheet.html.xsl postgis-out.xml > $@
+tiger_geocoder_cheatsheet.html: xsl/tiger_geocoder_cheatsheet.html.xsl $(XML_INPUTS)
postgis-out.xml: postgis.xml Makefile
$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
@@ -280,7 +280,6 @@ chunked-html-web-mobile: postgis-out.xml Makefile images $(XML_INPUTS)
$(PERL) -pi -e 's/<head>/<head><meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">/g' $(HTML_BITS)
html: html/postgis$(DOCSUFFIX).html
html-localized:
@@ -360,6 +359,9 @@ clean:
distclean: clean
$(MAKE) -C html/image_src distclean
rm -f Makefile Makefile.comments html/image_src/Makefile
+ for lang in $(translations); do \
+ rm -f po/$$lang/Makefile; \
+ done
maintainer-clean: clean images-clean
rm -f postgis_comments.sql raster_comments.sql topology_comments.sql tiger_geocoder_comments.sql sfcgal_comments.sql
@@ -438,7 +440,7 @@ endif
check-localized:
@for lang in $(translations); do \
echo "Creating html for language $$lang..."; \
- $(MAKE) -C po/$$lang local-check; \
+ $(MAKE) -C po/$$lang local-check || exit 1; \
done
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 971fd4ddc..6c146bb50 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -1,5 +1,5 @@
-# This file should be included by the Makefile
-# in each language directory
+# This file should be installed in each
+# language directory
local-all: local-html comments
@@ -14,7 +14,7 @@ local-check: symlinks
symlinks:
rm -f html; ln -s ../../html html
- rm -f xsl; ln -s ../../xsl xsl
+ rm -f xsl; ln -s $(srcdir)/../../xsl xsl
# for XML_SOURCES
include ../../Makefile
@@ -23,5 +23,5 @@ include ../../Makefile
PO2XML=po2xml
$(XML_SOURCES): %.xml: %.xml.po
- $(PO2XML) ../../$@ $< > $@
+ $(PO2XML) $(srcdir)/../../$@ $< > $@
diff --git a/doc/po/de/Makefile b/doc/po/de/Makefile
deleted file mode 100644
index 6fe645ad4..000000000
--- a/doc/po/de/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-de
-include ../Makefile.local
diff --git a/doc/po/de/Makefile.in b/doc/po/de/Makefile.in
new file mode 100644
index 000000000..31b255023
--- /dev/null
+++ b/doc/po/de/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-de
+include @srcdir@/../Makefile.local
+srcdir=@srcdir@
diff --git a/doc/po/es/Makefile b/doc/po/es/Makefile
index 654f17bcb..000000000
--- a/doc/po/es/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-es
diff --git a/doc/po/es/Makefile.in b/doc/po/es/Makefile.in
index 000000000..8aeaeb7ca
--- /dev/null
+++ b/doc/po/es/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-es
+srcdir=@srcdir@
diff --git a/doc/po/fr/Makefile b/doc/po/fr/Makefile
index ad05643a1..000000000
--- a/doc/po/fr/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-fr
diff --git a/doc/po/fr/Makefile.in b/doc/po/fr/Makefile.in
index 000000000..71cba94cf
--- /dev/null
+++ b/doc/po/fr/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-fr
+srcdir=@srcdir@
diff --git a/doc/po/it_IT/Makefile b/doc/po/it_IT/Makefile
index 8e7df5460..000000000
--- a/doc/po/it_IT/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-it
diff --git a/doc/po/it_IT/Makefile.in b/doc/po/it_IT/Makefile.in
index 000000000..39baedf11
--- /dev/null
+++ b/doc/po/it_IT/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-it
+srcdir=@srcdir@
diff --git a/doc/po/ja/Makefile b/doc/po/ja/Makefile
index 8070cb1e0..000000000
--- a/doc/po/ja/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-ja
diff --git a/doc/po/ja/Makefile.in b/doc/po/ja/Makefile.in
index 000000000..7d732fb41
--- /dev/null
+++ b/doc/po/ja/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-ja
+srcdir=@srcdir@
diff --git a/doc/po/ko_KR/Makefile b/doc/po/ko_KR/Makefile
index 1f181bcf1..000000000
--- a/doc/po/ko_KR/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-ko_KR
diff --git a/doc/po/ko_KR/Makefile.in b/doc/po/ko_KR/Makefile.in
index 000000000..aedfe8c8e
--- /dev/null
+++ b/doc/po/ko_KR/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-ko_KR
+srcdir=@srcdir@
diff --git a/doc/po/pl/Makefile b/doc/po/pl/Makefile
index 0693327df..000000000
--- a/doc/po/pl/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-pl
diff --git a/doc/po/pl/Makefile.in b/doc/po/pl/Makefile.in
index 000000000..82370f7e3
--- /dev/null
+++ b/doc/po/pl/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-pl
+srcdir=@srcdir@
diff --git a/doc/po/pt_BR/Makefile b/doc/po/pt_BR/Makefile
index b47258197..000000000
--- a/doc/po/pt_BR/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-br
diff --git a/doc/po/pt_BR/Makefile.in b/doc/po/pt_BR/Makefile.in
index 000000000..078a0c4f7
--- /dev/null
+++ b/doc/po/pt_BR/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-br
+srcdir=@srcdir@
diff --git a/doc/po/ru/Makefile b/doc/po/ru/Makefile
index 51ec828d0..000000000
--- a/doc/po/ru/Makefile
+++ /dev/null
@@ -1,2 +0,0 @@
-DOCSUFFIX=-ru
diff --git a/doc/po/ru/Makefile.in b/doc/po/ru/Makefile.in
index 000000000..f771bc430
--- /dev/null
+++ b/doc/po/ru/Makefile.in
@@ -0,0 +1,3 @@
+DOCSUFFIX=-ru
+srcdir=@srcdir@
Summary of changes:
.drone-1.0.yml | 7 ++++---
.gitignore | 1 +
configure.ac | 10 ++++++++++
doc/Makefile.in | 48 +++++++++++++++++++++++++-----------------------
doc/po/Makefile.local | 8 ++++----
doc/po/de/Makefile | 2 --
doc/po/de/Makefile.in | 3 +++
doc/po/es/Makefile | 2 --
doc/po/es/Makefile.in | 3 +++
doc/po/fr/Makefile | 2 --
doc/po/fr/Makefile.in | 3 +++
doc/po/it_IT/Makefile | 2 --
doc/po/it_IT/Makefile.in | 3 +++
doc/po/ja/Makefile | 2 --
doc/po/ja/Makefile.in | 3 +++
doc/po/ko_KR/Makefile | 2 --
doc/po/ko_KR/Makefile.in | 3 +++
doc/po/pl/Makefile | 2 --
doc/po/pl/Makefile.in | 3 +++
doc/po/pt_BR/Makefile | 2 --
doc/po/pt_BR/Makefile.in | 3 +++
doc/po/ru/Makefile | 2 --
doc/po/ru/Makefile.in | 3 +++
23 files changed, 71 insertions(+), 48 deletions(-)
delete mode 100644 doc/po/de/Makefile
create mode 100644 doc/po/de/Makefile.in
delete mode 100644 doc/po/es/Makefile
create mode 100644 doc/po/es/Makefile.in
delete mode 100644 doc/po/fr/Makefile
create mode 100644 doc/po/fr/Makefile.in
delete mode 100644 doc/po/it_IT/Makefile
create mode 100644 doc/po/it_IT/Makefile.in
delete mode 100644 doc/po/ja/Makefile
create mode 100644 doc/po/ja/Makefile.in
delete mode 100644 doc/po/ko_KR/Makefile
create mode 100644 doc/po/ko_KR/Makefile.in
delete mode 100644 doc/po/pl/Makefile
create mode 100644 doc/po/pl/Makefile.in
delete mode 100644 doc/po/pt_BR/Makefile
create mode 100644 doc/po/pt_BR/Makefile.in
delete mode 100644 doc/po/ru/Makefile
create mode 100644 doc/po/ru/Makefile.in
hooks/post-receive
