[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-416-g4db89f260
git at osgeo.org
git at osgeo.org
Mon Jan 31 03:04:24 PST 2022
the project "PostGIS".
via 4db89f26011de35f4dd7f2feadd3510154d7305e (commit)
from bcdedddfd25cbb473c9d8a7ae8f09b098c4836f2 (commit)
revisions in full, below.
commit 4db89f26011de35f4dd7f2feadd3510154d7305e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 12:02:28 2022 +0100
Some verbatim translations
Fix japanese translation structure
References #5073
diff --git a/doc/po/ja/reference_constructor.xml.po b/doc/po/ja/reference_constructor.xml.po
index 4fb1c967a..7783be123 100644
--- a/doc/po/ja/reference_constructor.xml.po
+++ b/doc/po/ja/reference_constructor.xml.po
@@ -2250,7 +2250,7 @@ msgstr ", <xref linkend=\"ST_MakeLine\"/>, <xref linkend=\"ST_MakePolygon\"/>"
#: reference_constructor.xml:970
#, no-c-format
msgid "ST_Letters"
-msgstr ""
+msgstr "ST_Letters"
#. Tag: refpurpose
#: reference_constructor.xml:971
@@ -2272,11 +2272,13 @@ msgid ""
"paramdef> <paramdef choice=\"opt\"><type>json</type> <parameter> font</"
"parameter></paramdef>"
msgstr ""
-"<funcdef>geometry <function>ST_MakePoint</function></funcdef> "
-"<paramdef><type>double precision</type> <parameter>x</parameter></paramdef> "
-"<paramdef><type>double precision</type> <parameter>y</parameter></paramdef> "
-"<paramdef><type>double precision</type> <parameter>z</parameter></paramdef> "
-"<paramdef><type>double precision</type> <parameter>m</parameter></paramdef>"
+"<funcdef>geometry <function>ST_Letters</function></funcdef> "
+"<paramdef><type>text</type> <parameter> letters</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>double precision</type> <parameter> "
+"text_height=100.0</parameter></paramdef> <paramdef choice=\"opt"
+"\"><type>geometry</type> <parameter> start_position=POINT(0 0)</parameter></"
+"paramdef> <paramdef choice=\"opt\"><type>json</type> <parameter> font</"
+"parameter></paramdef>"
#. Tag: para
#: reference_constructor.xml:988
diff --git a/doc/po/ja/reference_management.xml.po b/doc/po/ja/reference_management.xml.po
index e25e4eea3..e315b25e9 100644
--- a/doc/po/ja/reference_management.xml.po
+++ b/doc/po/ja/reference_management.xml.po
@@ -589,13 +589,11 @@ msgid ""
"parameter></paramdef> <paramdef><type>varchar </type> "
"<parameter>a_geomfield_name</parameter></paramdef>"
msgstr ""
-"<funcprototype> <funcdef>text <function>Populate_Geometry_Columns</"
-"function></funcdef> <paramdef><type>boolean </type> "
-"<parameter>use_typmod=true</parameter></paramdef> </funcprototype> "
-"<funcprototype> <funcdef>int <function>Populate_Geometry_Columns</function></"
-"funcdef> <paramdef><type>oid</type> <parameter>relation_oid</parameter></"
-"paramdef> <paramdef><type>boolean </type> <parameter>use_typmod=true</"
-"parameter></paramdef> </funcprototype>"
+"<funcdef>integer <function>Find_SRID</function></funcdef> "
+"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> <parameter>a_table_name</"
+"parameter></paramdef> <paramdef><type>varchar </type> "
+"<parameter>a_geomfield_name</parameter></paramdef>"
#. Tag: para
#: reference_management.xml:304
Summary of changes:
doc/po/ja/reference_constructor.xml.po | 14 ++++++++------
doc/po/ja/reference_management.xml.po | 12 +++++-------
2 files changed, 13 insertions(+), 13 deletions(-)
hooks/post-receive
