[postgis-tickets] [PostGIS] #5136: failures on raster tests - some ci bots running GDAL 3.2
trac at osgeo.org
Mon May 2 15:50:08 PDT 2022
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: raster | Version: master
Resolution: | Keywords:
Comment (by robe):
Okay I tested locally on GDAL 3.2.3 and also get this error:
./raster/test/regress/rt_polygon .. failed (diff expected obtained:
/projects/postgis/tmp/3.3.0dev_pg11_geos3.8_gdal3.2.3w64/test_259_diff)
--- ./raster/test/regress/rt_polygon_expected 2022-04-20
11:07:12.099094700 -0400
+++ /projects/postgis/tmp/3.3.0dev_pg11_geos3.8_gdal3.2.3w64/test_259_out
2022-05-02 17:15:21.809989200 -0400
@@ -1,7 +1,7 @@
t
t
t
-t
-t
+ERROR: GEOSEquals: TopologyException: side location conflict at 2 -2
t
t
I feel like since we said it may not be valid maybe just run a valid check
on these. I still need to run GDAL 3.1, but I suspect that passes fine
since GHA is not complaining and is running GDAL 3.1 for some runs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5136#comment:7>
