[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-792-g78308862c
git at osgeo.org
git at osgeo.org
Wed May 4 11:45:51 PDT 2022
the project "PostGIS".
via 78308862c638980171558732b2c9c94c651a32fe (commit)
from befb35508018f4e860139d9fba5ef63d575c86f6 (commit)
revisions in full, below.
commit 78308862c638980171558732b2c9c94c651a32fe
Author: Regina Obe <lr at pcorp.us>
Date: Wed May 4 14:45:47 2022 -0400
Put back mising tag. More sort fixing
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 8eb6c478d..255878aba 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -536,7 +536,7 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
(75 84),(75 77),(81 29),(77 73),(41 42),(83 72),(23 36),(89 53),(27 57),(57 97),(27 77),(39 88),(60 81),
(80 72),(54 32),(55 26),(62 22),(70 20),(76 27),(84 35),(87 42),(82 54),(83 64),(69 86),(60 90),(50 86),(43 80),(36 73),
(36 68),(40 75),(24 67),(23 60),(26 44),(28 33),(40 32),(43 19),(65 16),(73 16),(38 46),(31 59),(34 86),(45 90),(64 97))'::geometry, 100.1,true))</programlisting>
- <screen>POLYGON((89 53,91 50,87 42,90 30,84 19,78 16,73 16,65 16,53 18,43 19,30 22,28 33,23 36,26 44,27 54,23 60,24 67,27 77,24 82,26 85,34 86,39 88,45 90,49 95,52 98,57 97,64 97,72 95,76 88,75 84,83 72,85 71,88 58,89 53),(36 61,36 68,40 75,43 80,60 81,68 73,77 67,81 60,82 54,81 47,78 43,76 27,62 22,54 32,44 42,38 46,36 61))/screen>
+ <screen>POLYGON((89 53,91 50,87 42,90 30,84 19,78 16,73 16,65 16,53 18,43 19,30 22,28 33,23 36,26 44,27 54,23 60,24 67,27 77,24 82,26 85,34 86,39 88,45 90,49 95,52 98,57 97,64 97,72 95,76 88,75 84,83 72,85 71,88 58,89 53),(36 61,36 68,40 75,43 80,60 81,68 73,77 67,81 60,82 54,81 47,78 43,76 27,62 22,54 32,44 42,38 46,36 61))</screen>
</para>
<para>
@@ -1150,6 +1150,66 @@ MULTIPOLYGON(
</refentry>
+ <refentry id="ST_StraightSkeleton">
+ <refnamediv>
+ <refname>ST_StraightSkeleton</refname>
+ <refpurpose>Compute a straight skeleton from a geometry</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_StraightSkeleton</function></funcdef>
+ <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Availability: 2.1.0</para>
+ <para>&sfcgal_required;</para>
+ <para>&Z_support;</para>
+ <para>&P_support;</para>
+ <para>&T_support;</para>
+ </refsection>
+ <refsection><title>Examples</title>
+ <programlisting>SELECT ST_StraightSkeleton(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))'));</programlisting>
+ <informaltable>
+ <tgroup cols="2">
+ <tbody>
+ <row>
+ <entry><para><informalfigure>
+ <mediaobject>
+ <imageobject>
+ <imagedata fileref="images/st_straightskeleton01.png" />
+ </imageobject>
+ <caption><para>Original polygon</para></caption>
+ </mediaobject>
+ </informalfigure></para>
+ </entry>
+ <mediaobject>
+ <imageobject>
+ <imagedata fileref="images/st_straightskeleton02.png" />
+ </imageobject>
+ <caption><para>Straight Skeleton of polygon</para></caption>
+ </mediaobject>
+ </entry>
+ </row>
+ </tbody>
+ </tgroup>
+ </informaltable>
+ </refsection>
+ </refentry>
<refentry id="ST_Tesselate">
<refnamediv>
<refname>ST_Tesselate</refname>
@@ -1316,63 +1376,5 @@ MULTIPOLYGON(
</refentry>
- <refentry id="ST_StraightSkeleton">
- <refnamediv>
- <refname>ST_StraightSkeleton</refname>
- <refpurpose>Compute a straight skeleton from a geometry</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>geometry <function>ST_StraightSkeleton</function></funcdef>
- <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <title>Description</title>
- <para>Availability: 2.1.0</para>
- <para>&sfcgal_required;</para>
- <para>&Z_support;</para>
- <para>&P_support;</para>
- <para>&T_support;</para>
- </refsection>
- <refsection><title>Examples</title>
- <programlisting>SELECT ST_StraightSkeleton(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))'));</programlisting>
- <informaltable>
- <tgroup cols="2">
- <tbody>
- <row>
- <entry><para><informalfigure>
- <mediaobject>
- <imageobject>
- <imagedata fileref="images/st_straightskeleton01.png" />
- </imageobject>
- <caption><para>Original polygon</para></caption>
- </mediaobject>
- </informalfigure></para>
- </entry>
- <mediaobject>
- <imageobject>
- <imagedata fileref="images/st_straightskeleton02.png" />
- </imageobject>
- <caption><para>Straight Skeleton of polygon</para></caption>
- </mediaobject>
- </entry>
- </row>
- </tbody>
- </tgroup>
- </informaltable>
- </refsection>
- </refentry>
</sect1>
Summary of changes:
doc/reference_sfcgal.xml | 120 ++++++++++++++++++++++++-----------------------
1 file changed, 61 insertions(+), 59 deletions(-)
hooks/post-receive
