[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-853-gefdedcd74
git at osgeo.org
git at osgeo.org
Sun May 15 12:00:00 PDT 2022
the project "PostGIS".
via efdedcd74e9a2a04d0998c7e4151dfbb67016c23 (commit)
via 6513d90afece81eb1d82254780a13f271f53055c (commit)
via b2c345aad953d877b618ad170a4ab7d89193be11 (commit)
via 7bff735e8197136aad954ce0cae8b23df3ec980e (commit)
from 368aeeccd07735249a81cf0b9657768fd87d4f7a (commit)
revisions in full, below.
commit efdedcd74e9a2a04d0998c7e4151dfbb67016c23
Merge: 6513d90af b2c345aad
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun May 15 21:59:47 2022 +0300
Merge remote-tracking branch 'gh/pr/686/merge'
commit 6513d90afece81eb1d82254780a13f271f53055c
Date: Sun May 15 21:55:49 2022 +0300
Revert "Read spatial_ref_sys data directly out from proj (WIP)"
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 1154f4eb3..758e7996c 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -26,7 +26,6 @@
#include "postgres.h"
#include "fmgr.h"
#include "utils/builtins.h"
-#include "funcapi.h"
#include "../postgis_config.h"
#include "liblwgeom.h"
@@ -226,290 +225,3 @@ Datum LWGEOM_asKML(PG_FUNCTION_ARGS)
PG_RETURN_TEXT_P(kml);
PG_RETURN_NULL();
- * PROJ database reading functions
-#if POSTGIS_PROJ_VERSION >= 61
-struct srs_entry {
- text* auth_name;
- text* auth_code;
-struct srs_data {
- struct srs_entry* entries;
- uint32_t num_entries;
- uint32_t capacity;
- uint32_t current_entry;
-static Datum
-srs_tuple_from_entry(const struct srs_entry* entry, TupleDesc tuple_desc)
- HeapTuple tuple;
- Datum tuple_data[4] = {0, 0, 0, 0};
- bool tuple_null[4] = {false, false, false, false};
- PJ_CONTEXT *ctx = NULL;
- const char* const empty_options[2] = {NULL};
- const char* const wkt_options[2] = {"MULTILINE=NO", NULL};
- const char *srtext;
- const char *proj4text;
- PJ *obj = proj_create_from_database(ctx,
- text_to_cstring(entry->auth_name),
- text_to_cstring(entry->auth_code),
- PJ_CATEGORY_CRS, 0, empty_options);
- if (!obj)
- return (Datum) 0;
- srtext = proj_as_wkt(ctx, obj, PJ_WKT1_GDAL, wkt_options);
- proj4text = proj_as_proj_string(ctx, obj, PJ_PROJ_4, empty_options);
- if (entry->auth_name)
- tuple_data[0] = PointerGetDatum(entry->auth_name);
- else
- tuple_null[0] = true;
- if (entry->auth_code)
- tuple_data[1] = PointerGetDatum(entry->auth_code);
- else
- tuple_null[1] = true;
- if (srtext)
- tuple_data[2] = PointerGetDatum(cstring_to_text(srtext));
- else
- tuple_null[2] = true;
- if (proj4text)
- tuple_data[3] = PointerGetDatum(cstring_to_text(proj4text));
- else
- tuple_null[3] = true;
- tuple = heap_form_tuple(tuple_desc, tuple_data, tuple_null);
- proj_destroy(obj);
- return HeapTupleGetDatum(tuple);
-static struct srs_data *
-srs_state_init()
- struct srs_data *state = palloc0(sizeof(*state));
- state->capacity = 8192;
- state->num_entries = 0;
- state->entries = palloc0(state->capacity * sizeof(*(state->entries)));
- return state;
-static void
-srs_state_memcheck(struct srs_data *state)
- if (state->num_entries == state->capacity) {
- state->capacity *= 2;
- state->entries = repalloc(state->entries, state->capacity * sizeof(*(state->entries)));
- return;
-static void
-srs_state_codes(const char* auth_name, struct srs_data *state)
- * Only a subset of supported proj types actually
- * show up in spatial_ref_sys
- #define ntypes 3
- PJ_TYPE types[ntypes] = {PJ_TYPE_PROJECTED_CRS, PJ_TYPE_GEOGRAPHIC_CRS, PJ_TYPE_COMPOUND_CRS};
- uint32_t j;
- for (j = 0; j < ntypes; j++) {
- int allow_deprecated = 0;
- PJ_TYPE type = types[j];
- PROJ_STRING_LIST codes_ptr = proj_get_codes_from_database(ctx, auth_name, type, allow_deprecated);
- PROJ_STRING_LIST codes = codes_ptr;
- const char *code;
- while(codes && *codes) {
- /* Read current code and move forward one entry */
- code = *codes++;
- /* Ensure there is space in the entry list */
- srs_state_memcheck(state);
- /* Write the entry into the entry list and increment */
- state->entries[state->num_entries].auth_name = cstring_to_text(auth_name);
- state->entries[state->num_entries].auth_code = cstring_to_text(code);
- state->num_entries++;
- /* Clean up system allocated memory */
- proj_string_list_destroy(codes_ptr);
-#endif
- * Search for srtext and proj4text given auth_name and auth_srid,
- * returns TABLE(auth_name text, auth_srid text, srtext text, proj4text text)
-Datum postgis_srs_entry(PG_FUNCTION_ARGS);
-PG_FUNCTION_INFO_V1(postgis_srs_entry);
-#if POSTGIS_PROJ_VERSION < 60
- elog(ERROR, "%s is not supported with Proj < 6.0", __func__);
-#else
- Datum result;
- struct srs_entry entry;
- text* auth_name = PG_GETARG_TEXT_P(0);
- text* auth_code = PG_GETARG_TEXT_P(1);
- TupleDesc tuple_desc;
- if (get_call_result_type(fcinfo, 0, &tuple_desc) != TYPEFUNC_COMPOSITE) {
- ereport(ERROR, (errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
- errmsg("%s called with incompatible return type", __func__)));
- BlessTupleDesc(tuple_desc);
- entry.auth_name = auth_name;
- entry.auth_code = auth_code;
- result = srs_tuple_from_entry(&entry, tuple_desc);
- if (result)
- PG_RETURN_DATUM(srs_tuple_from_entry(&entry, tuple_desc));
- else
- PG_RETURN_NULL();
-#endif
-Datum postgis_srs_entry_all(PG_FUNCTION_ARGS);
-PG_FUNCTION_INFO_V1(postgis_srs_entry_all);
-#else
- FuncCallContext *funcctx;
- MemoryContext oldcontext;
- struct srs_data *state;
- Datum result;
- * On the first call, fill in the state with all
- * of the auth_name/auth_srid pairings in the
- * proj database. Then the per-call routine is just
- * one isolated call per pair.
- if (SRF_IS_FIRSTCALL()) {
- funcctx = SRF_FIRSTCALL_INIT();
- oldcontext = MemoryContextSwitchTo(funcctx->multi_call_memory_ctx);
- * Could read all authorities from database, but includes
- * authorities (IGN, OGC) that use non-integral values in
- * auth_srid. So hand-coded list for now.
- state = srs_state_init();
- srs_state_codes("EPSG", state);
- srs_state_codes("ESRI", state);
- srs_state_codes("IAU_2015", state);
- * Read the TupleDesc from the FunctionCallInfo. The SQL definition
- * of the function must have the right number of fields and types
- * to match up to this C code.
- if (get_call_result_type(fcinfo, 0, &funcctx->tuple_desc) != TYPEFUNC_COMPOSITE) {
- BlessTupleDesc(funcctx->tuple_desc);
- funcctx->user_fctx = state;
- MemoryContextSwitchTo(oldcontext);
- /* Stuff done on every call of the function */
- funcctx = SRF_PERCALL_SETUP();
- state = funcctx->user_fctx;
- /* Exit when we've read all entries */
- if (!state->num_entries || state->current_entry == state->num_entries) {
- SRF_RETURN_DONE(funcctx);
- /* Lookup the srtext/proj4text for this entry */
- state->entries + state->current_entry++,
- funcctx->tuple_desc);
- if (result)
- SRF_RETURN_NEXT(funcctx, result);
- /* Stop if lookup fails drastically */
-#endif
-Datum postgis_srs_codes(PG_FUNCTION_ARGS);
-PG_FUNCTION_INFO_V1(postgis_srs_codes);
-#else
- Datum result;
- text* auth_code;
- srs_state_codes(text_to_cstring(auth_name), state);
- /* Read the code for this entry */
- auth_code = state->entries[state->current_entry++].auth_code;
- result = PointerGetDatum(auth_code);
- /* We are returning setof(text) */
- if (result)
-#endif
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 152f0c913..05fb550b3 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2862,24 +2862,6 @@ CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_srid i
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
_COST_HIGH;
-CREATE OR REPLACE FUNCTION postgis_spatial_ref_sys(auth_name text)
- RETURNS SETOF TEXT
- AS 'MODULE_PATHNAME', 'postgis_srs_codes'
- LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
- _COST_MEDIUM;
-CREATE OR REPLACE FUNCTION postgis_spatial_ref_sys(auth_name text, auth_srid text)
- RETURNS TABLE(auth_name text, auth_srid TEXT, srtext TEXT, proj4text TEXT)
- AS 'MODULE_PATHNAME', 'postgis_srs_entry'
- _COST_MEDIUM;
-CREATE OR REPLACE FUNCTION postgis_spatial_ref_sys()
- AS 'MODULE_PATHNAME', 'postgis_srs_entry_all'
- _COST_HIGH;
-- POSTGIS_VERSION()
commit b2c345aad953d877b618ad170a4ab7d89193be11
Merge: 368aeeccd 7bff735e8
Author: Sergei <managerzf168 at gmail.com>
Date: Sun May 15 20:26:14 2022 +0300
Merge 7bff735e8197136aad954ce0cae8b23df3ec980e into 368aeeccd07735249a81cf0b9657768fd87d4f7a
commit 7bff735e8197136aad954ce0cae8b23df3ec980e
Author: sergei sh <sshoulbakov at kontur.io>
Date: Fri May 6 21:02:37 2022 +0300
raster alignment check fix, #5148
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index 5e0908381..b5c7956e4 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -3072,7 +3072,7 @@ rt_raster_gdal_rasterize(
double _w[2] = {0};
/* raster is already aligned */
- if (FLT_EQ(*grid_xw, extent.UpperLeftX) && FLT_EQ(*grid_yw, extent.UpperLeftY)) {
+ if (DBL_EQ(*grid_xw, extent.UpperLeftX) && DBL_EQ(*grid_yw, extent.UpperLeftY)) {
RASTER_DEBUG(3, "Skipping raster alignment as it is already aligned to grid");
break;
diff --git a/raster/test/regress/rt_clip.sql b/raster/test/regress/rt_clip.sql
index bae2cb394..9963e21da 100644
--- a/raster/test/regress/rt_clip.sql
+++ b/raster/test/regress/rt_clip.sql
@@ -158,3 +158,17 @@ ORDER BY 1, 2, 3, 4, 5, 6, 8;
DROP TABLE IF EXISTS geom_clip;
DROP TABLE IF EXISTS raster_clip;
DROP TABLE IF EXISTS raster_clip_out;
+-- #5148 mask raster not aligned to input raster
+SELECT
+ ST_UpperLeftX(rast) AS x,
+ ST_UpperLeftY(rast) AS y,
+ ST_Width(rast) AS w,
+ ST_Height(rast) AS h
+FROM ST_Clip(
+ ST_AddBand(
+ ST_MakeEmptyRaster(100, 100, 0, 0.001, 1e-5, -1e-5, 0, 0, 0),
+ 1, '8BUI', 1, 0
+ ST_GeomFromText('POLYGON((0 0.0009999, 0.0001 0.0009999, 0.0001 0.0009, 0 0.0009, 0 0.0009999))')
+) AS rast;
diff --git a/raster/test/regress/rt_clip_expected b/raster/test/regress/rt_clip_expected
index a6deb45c6..4495b3271 100644
--- a/raster/test/regress/rt_clip_expected
+++ b/raster/test/regress/rt_clip_expected
@@ -524,3 +524,4 @@
4|2|5|3|4|2|3|POLYGON((3 -1,4 -1,4 -2,3 -2,3 -1))
4|2|5|3|4|3|3|POLYGON((3 -2,4 -2,4 -3,3 -3,3 -2))
4|2|5|3|4|4|3|POLYGON((3 -3,4 -3,4 -4,3 -4,3 -3))
+0|0.001|10|10
Summary of changes:
postgis/lwgeom_transform.c | 288 -----------------------------------
postgis/postgis.sql.in | 18 ---
raster/rt_core/rt_raster.c | 2 +-
raster/test/regress/rt_clip.sql | 14 ++
raster/test/regress/rt_clip_expected | 1 +
5 files changed, 16 insertions(+), 307 deletions(-)
hooks/post-receive
