[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.1-14-gff3d4b65b
git at osgeo.org
git at osgeo.org
Tue May 17 13:28:12 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
via ff3d4b65b49481505b341b0250e3d6811d0e1ebc (commit)
from 26c6f24d9a362cca5dd5f257598112eb1aa8df20 (commit)
revisions in full, below.
commit ff3d4b65b49481505b341b0250e3d6811d0e1ebc
Author: Sandro Santilli <strk at kbt.io>
Date: Tue May 17 12:19:12 2022 +0200
Fix infinite loop in lwline_split_by_point_to
References #5152 in 3.2 branch (3.2.2dev)
Includes unit and regress test
diff --git a/NEWS b/NEWS
index fd39ee799..8a0684710 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,7 @@ PostGIS 3.2.2dev
2022/MM/DD
* Bug Fixes *
+ - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
- #5124, GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
- #5120, Fix not-null result from ST_EstimatedExtent against
truncated tables with spatial index (Sandro Santilli)
diff --git a/liblwgeom/cunit/cu_split.c b/liblwgeom/cunit/cu_split.c
index b7bcb1e5d..edbf00aa4 100644
--- a/liblwgeom/cunit/cu_split.c
+++ b/liblwgeom/cunit/cu_split.c
@@ -74,8 +74,20 @@ static void test_lwline_split_by_point_to(void)
CU_ASSERT_EQUAL(coll->ngeoms, 4);
lwpoint_free(point);
- lwcollection_free((LWCOLLECTION*)coll);
lwline_free(line);
+ line = lwgeom_as_lwline(lwgeom_from_wkt("LINESTRING EMPTY",
+ LW_PARSER_CHECK_NONE));
+ CU_ASSERT(line != NULL);
+ point = lwgeom_as_lwpoint(lwgeom_from_wkt(
+ "POINT(0 0)", LW_PARSER_CHECK_NONE));
+ CU_ASSERT(point != NULL);
+ ret = lwline_split_by_point_to(line, point, coll);
+ CU_ASSERT_EQUAL(ret, 0); /* the point is not on the line */
+ lwpoint_free(point);
+ lwline_free(line);
+ lwcollection_free((LWCOLLECTION*)coll);
static void test_lwgeom_split(void)
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index efc9348d1..83038a485 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -233,6 +233,7 @@ lwline_split_by_point_to(const LWLINE* lwline_in, const LWPOINT* blade_in,
getPoint4d_p(blade_in->point, 0, &pt);
/* Find closest segment */
+ if ( ipa->npoints < 1 ) return 0; /* empty input line */
getPoint4d_p(ipa, 0, &p1);
nsegs = ipa->npoints - 1;
for ( i = 0; i < nsegs; i++ )
diff --git a/regress/core/split.sql b/regress/core/split.sql
index 7a2eaf9f0..2374026cc 100644
--- a/regress/core/split.sql
+++ b/regress/core/split.sql
@@ -102,4 +102,9 @@ select '86', ST_AsEWKT(ST_Split(
'SRID=3;MULTIPOINT(2 6,5 0,5 20,2 20,8 20,8 0,5 -2,0 0, 5 -5, 10 20)'
+-- Split empty line by point
+-- See http://trac.osgeo.org/postgis/ticket/5152
+select '87', ST_AsEWKT(ST_Split('SRID=4326;LINESTRING EMPTY', 'SRID=4326;POINT(0 1)'));
-- TODO: split line by collapsed line
diff --git a/regress/core/split_expected b/regress/core/split_expected
index dab2da4cb..b8a5287e9 100644
--- a/regress/core/split_expected
+++ b/regress/core/split_expected
@@ -28,3 +28,4 @@ ERROR: Splitter line has linear intersection with input
84|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -1,1 0),LINESTRING(1 0,1 1))
85|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -2,1 -1),LINESTRING(1 -1,1 1,3 1),LINESTRING(3 1,4 1))
86|SRID=3;GEOMETRYCOLLECTION(LINESTRING(8 0,10 0),LINESTRING(0 0,5 0),LINESTRING(5 0,8 0),LINESTRING(5 0,5 5),LINESTRING(5 -2,5 0),LINESTRING(5 -5,5 -2),LINESTRING(8 20,10 20),LINESTRING(2 20,5 20),LINESTRING(0 20,2 20),LINESTRING(5 20,8 20))
+87|SRID=4326;GEOMETRYCOLLECTION(LINESTRING EMPTY)
Summary of changes:
NEWS | 1 +
liblwgeom/cunit/cu_split.c | 14 +++++++++++++-
liblwgeom/lwgeom_geos_split.c | 1 +
regress/core/split.sql | 5 +++++
regress/core/split_expected | 1 +
5 files changed, 21 insertions(+), 1 deletion(-)
hooks/post-receive
