[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-863-g6febe57e7
Tue May 17 15:22:57 PDT 2022
the project "PostGIS".
       via  6febe57e76d2239ea9779c489eff376f3ed76e72 (commit)
      from  5cff5f7777e1562129799f4b479bbfdb218baa28 (commit)
revisions in full, below.
commit 6febe57e76d2239ea9779c489eff376f3ed76e72
Author: Regina Obe <lr at pcorp.us>
Date:   Tue May 17 18:19:46 2022 -0400
    Return error on ST_SetPoint emtpy linestring.
    References #5151 for PostGIS 3.3.0
    Have berrie stop on any error
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 88ccd964a..0573fd589 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -1,4 +1,5 @@
 #!/usr/bin/env bash
+set -e
 #bessie is a 32-bit Rasberry Pi managed by Bruce Rindahl
 ## BRANCH is passed in via jenkins which is set via gitea web hook
 #export BRANCH=618a67b1d6fc223dd5a4c0b02c824939f21dbd65
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 45265cee1..1bf6f0bc4 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2449,6 +2449,12 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS)
 		elog(ERROR, "First argument must be a LINESTRING");
 		PG_RETURN_NULL();
+	if ( line->points->npoints < 1 ) 	{
+		elog(ERROR, "Line has no points");
+		PG_RETURN_NULL();
 	if (which < 0)
 		/* Use backward indexing for negative values */
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 221a62ebf..89a817cb9 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1435,3 +1435,6 @@ SELECT
 -- https://trac.osgeo.org/postgis/ticket/5024
 --SELECT '#5024', 'spatial_ref_sys entries' AS table_name, count(*) FROM spatial_ref_sys;
+-- https://trac.osgeo.org/postgis/ticket/5151
+SELECT '#5151', ST_SetPoint(ST_GeomFromText('LINESTRING EMPTY',4326), 1, ST_GeomFromText('POINT(40 50)',4326)) As result;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index d1548b4bd..1dea7e91d 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -460,3 +460,4 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4770.c|MULTIPOINT((0 0),(1 1))|602
 #4799|{"type": "Feature", "geometry": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:25832"}},"coordinates":[359667,5651729]}, "properties": {"id": 1, "geom1": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:3035"}},"coordinates":[4110471,3103061]}}}
 #5008|f|f
+ERROR:  Line has no points
Summary of changes:
 ci/berrie/postgis_regress.sh     | 1 +
 postgis/lwgeom_functions_basic.c | 6 ++++++
 regress/core/tickets.sql         | 3 +++
 regress/core/tickets_expected    | 1 +
 4 files changed, 11 insertions(+)
hooks/post-receive
