[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-866-g9f074a348
Wed May 18 09:04:09 PDT 2022
the project "PostGIS".
       via  9f074a348926da7a66f5d5f7b01e8503c0079494 (commit)
       via  ffce6cd25eb70faa7abb0f7c29f228af2e1e3a04 (commit)
       via  79ca543cab60b75e2df56183699f47930183979a (commit)
      from  6febe57e76d2239ea9779c489eff376f3ed76e72 (commit)
revisions in full, below.
commit 9f074a348926da7a66f5d5f7b01e8503c0079494
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date:   Tue May 17 15:37:24 2022 +0000
    Translated using Weblate (German)
    Currently translated at 2.6% (4 of 151 strings)
    Translation: postgis/reference_overlay.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_overlayxml/de/
diff --git a/doc/po/de/reference_overlay.xml.po b/doc/po/de/reference_overlay.xml.po
index 0719bda0d..31f21c6d2 100644
--- a/doc/po/de/reference_overlay.xml.po
+++ b/doc/po/de/reference_overlay.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-02-06 07:55+0000\n"
-"PO-Revision-Date: 2022-05-12 13:42+0000\n"
+"PO-Revision-Date: 2022-05-18 16:04+0000\n"
 "Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "reference_overlayxml/de/>\n"
@@ -15,7 +15,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=n != 1;\n"
-"X-Generator: Weblate 4.11.2\n"
+"X-Generator: Weblate 4.12.2\n"
 #. Tag: para
 #: reference_overlay.xml:5
@@ -176,7 +176,7 @@ msgstr ""
 #: reference_overlay.xml:96 reference_overlay.xml:217 reference_overlay.xml:643
 #, no-c-format
 msgid "Performed by the GEOS module"
-msgstr ""
+msgstr "Wird durch das GEOS Modul ausgeführt"
 #. Tag: para
 #: reference_overlay.xml:97 reference_overlay.xml:219 reference_overlay.xml:645
commit ffce6cd25eb70faa7abb0f7c29f228af2e1e3a04
Date:   Tue May 17 15:32:01 2022 +0000
    Currently translated at 5.6% (16 of 282 strings)
    Translation: postgis/reference_relationship.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_relationshipxml/de/
diff --git a/doc/po/de/reference_relationship.xml.po b/doc/po/de/reference_relationship.xml.po
index b7e03a1d3..83da2ae2c 100644
--- a/doc/po/de/reference_relationship.xml.po
+++ b/doc/po/de/reference_relationship.xml.po
 "reference_relationshipxml/de/>\n"
 #. Tag: para
 #: reference_relationship.xml:5
@@ -247,6 +247,9 @@ msgid ""
 "and only if no points of B lie in the exterior of A, and at least one point "
 "of the interior of B lies in the interior of A."
 msgstr ""
+"Gibt TRUE zurück, wenn Geometrie B zur Gänze innerhalb von Geometrie A "
+"liegt. A beinhaltet B dann und nur dann, wenn kein Punkt von B außerhalb von "
+"A liegt und zumindest ein Punkt von B innerhalb von A liegt."
 #. Tag: para
 #: reference_relationship.xml:95
@@ -262,6 +265,15 @@ msgid ""
 "<xref linkend=\"ST_ContainsProperly\"/> predicate a geometry does "
 "<emphasis>not</emphasis> properly contain itself.)"
 msgstr ""
+"Eine Feinheit dieser Definition ist, dass eine Geometrie keine Teile seiner "
+"Begrenzung enthält. Deshalb enthalten Polygone und Linien <emphasis>keine</"
+"emphasis> Linien oder Punkte ihrer Begrenzung. Für weitere Einzelheiten "
+"siehe <ulink url=\"http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-"
+"of-ogc-covers-spatial.html\">Subtleties of OGC Covers, Contains, Within</"
+"ulink>. (Das <xref linkend=\"ST_Covers\"/> Prädikat bietet eine umfassendere "
+"Beziehung.) Allerdings beinhaltet eine Geometrie sich selbst. (Demgegenüber "
+"beinhaltet im <xref linkend=\"ST_ContainsProperly\"/> Prädikat eine "
+"Geometrie <emphasis>nicht</emphasis> genau sich selbst.)"
 #. Tag: para
 #: reference_relationship.xml:103
@@ -270,6 +282,8 @@ msgid ""
 "ST_Contains is the inverse of <xref linkend=\"ST_Within\"/>. So, "
 "<code>ST_Contains(A,B) = ST_Within(B,A)</code>."
 msgstr ""
+"ST_Contains ist das Gegenteil von <xref linkend=\"ST_Within\"/>. Daher, "
+"<code>ST_Contains(A,B) = ST_Within(B,A)</code>."
 #. Tag: para
 #: reference_relationship.xml:106
@@ -278,6 +292,8 @@ msgid ""
 "&index_aware; To avoid index use, use the function <function>_ST_Contains</"
 "function>."
 msgstr ""
+"&index_aware; Um die Verwendung eines Indices zu vermeiden, kann die "
+"Funktion <function>_ST_Contains</function> verwendet werden."
 #. Tag: para
 #: reference_relationship.xml:109 reference_relationship.xml:338
@@ -286,7 +302,7 @@ msgstr ""
 #: reference_relationship.xml:1243 reference_relationship.xml:1452
 #, no-c-format
-msgstr ""
 #. Tag: para
 #: reference_relationship.xml:110 reference_relationship.xml:758
commit 79ca543cab60b75e2df56183699f47930183979a
    Currently translated at 54.3% (194 of 357 strings)
    Translation: postgis/reference_processing.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_processingxml/de/
diff --git a/doc/po/de/reference_processing.xml.po b/doc/po/de/reference_processing.xml.po
index a3e6ca14a..e211d9ca3 100644
--- a/doc/po/de/reference_processing.xml.po
+++ b/doc/po/de/reference_processing.xml.po
@@ -1,14 +1,14 @@
 # SOME DESCRIPTIVE TITLE.
 # Translators:
-# Andreas Schild <andreas.schild at bfw.gv.at>, 2017,2019-2020
+# Andreas Schild <andreas.schild at bfw.gv.at>, 2017,2019-2020, 2022.
 # Jürgen E. Fischer <jef at norbit.de>, 2020
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2022-05-04 02:43+0000\n"
 "reference_processingxml/de/>\n"
@@ -17,7 +17,7 @@ msgstr ""
 #. Tag: para
 #: reference_processing.xml:5
@@ -1115,7 +1115,7 @@ msgstr ""
 #: reference_processing.xml:628
 #, no-c-format
-msgstr "Wird vom GEOS Modul ausgeführt"
 #. Tag: para
 #: reference_processing.xml:631
Summary of changes:
 doc/po/de/reference_overlay.xml.po      |  6 +++---
 doc/po/de/reference_processing.xml.po   |  8 ++++----
 doc/po/de/reference_relationship.xml.po | 22 +++++++++++++++++++---
 3 files changed, 26 insertions(+), 10 deletions(-)
hooks/post-receive
