[postgis-tickets] [PostGIS] #5150: postgis_extension_AddToSearchPath should take input as text instead of varchar, helpers should use CREATE FUNCTION
PostGIS trac at osgeo.org
Thu May 19 19:58:27 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 2.5.7
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"b175c26eee538e472aaf1a22afd2099b14d60481/git" b175c26/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b175c26eee538e472aaf1a22afd2099b14d60481"
 Numerous fixes to helper functions.
 References #5150
 References #5125
 References #5155  for PostGIS 3.1.6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5150#comment:3>
