[postgis-tickets] [PostGIS] #5133: ST_IsValid gives false positives for some "nested shells" geometries
trac at osgeo.org
Fri May 20 11:35:28 PDT 2022
Reporter: pegautreau | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.2.2
Component: postgis | Version: 3.2.x
Resolution: | Keywords: st_isvalid
Old description:
> SELECT ST_IsValid('MULTIPOLYGON(((3.1159647327776
> 45.8945466579793,3.11592656973335 45.8945439935178,3.1159138351383
> 45.8945878526115,3.11589617446883 45.894648677432,3.11600330801231
> 45.8946565084663,3.11603320098284 45.8946586935046,3.11603527270572
> 45.8946587702646,3.11609428533829 45.8946608396878,3.11610373994251
> 45.8946138820922,3.11611597473274 45.8945572172376,3.116021407765
> 45.8945506148806,3.1159647327776 45.8945466579793),(3.11598841113043
> 45.8945526196915,3.11598348641025 45.8945522352619,3.11597871955898
> 45.8945518631556,3.11598841113043 45.8945526196915),(3.11597871955898
> 45.8945518631556,3.11597826359897 45.8945518275627,3.11597770228232
> 45.8945517837456,3.11597871955898 45.8945518631556),(3.11597770228232
> 45.8945517837456,3.11597253456926 45.8945513803472,3.11596794047477
> 45.894551021726,3.11596362983417 45.8945506852314,3.11597770228232
> 45.8945517837456),(3.11596216348313 45.8945560394174,3.11601944954132
> 45.8945611821445,3.11604532510409 45.8945635050552,3.11603525837852
> 45.8945986795711,3.11602781011054 45.8945979166658,3.11595429350387
> 45.8945903865383,3.11596216348313 45.8945560394174)),((3.11600928183286
> 45.8945542488812,3.1160078379169 45.8945541361677,3.11600858297084
> 45.8945541943273,3.11600928183286 45.8945542488812)))');
> The function returns true with postgis3 but returns false with postgis2.
> It seems that a lot of invalid geometries of type "nested shells" are no
> more recognized as it should be by postgis3.
New description:
Comment (by pramsey):
I cannot replicate this, and I'm testing on postgis 3.3 and geos 3.11, so
the latest of everything.
=# SELECT ST_IsValid('MULTIPOLYGON(((3.1159647327776
NOTICE: Nested shells at or near point 3.1160092818328602
45.894554248881199
st_isvalid
f
(1 row)
pramsey=# select postgis_full_version();
POSTGIS="3.3.0dev 3.2.0-867-g216aca648" [EXTENSION] PGSQL="140"
GEOS="3.11.0dev-CAPI-1.16.0" PROJ="9.1.0" LIBXML="2.9.4" LIBJSON="0.15"
LIBPROTOBUF="1.4.0" WAGYU="0.5.0 (Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5133#comment:1>
