[postgis-tickets] [PostGIS] #5157: basic_test failure on i386
trac at osgeo.org
Sun May 22 02:09:53 PDT 2022
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: liblwgeom | Version: master
Keywords: |
The Debian package build for 3.3.0-alpha1 failed on i386 due to test
failures:
Suite: minimum_bounding_circle
Test: basic_test ...FAILED
1. cu_minimum_bounding_circle.c:35 - CU_ASSERT_TRUE(d <=
result->radius)
Test: test_empty ...passed
Full buildlogs:
* https://salsa.debian.org/debian-gis-team/postgis/-/jobs/2796297
https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=i386&ver=3.3.0~alpha1%2Bdfsg-1~exp1&stamp=1653204863&file=log
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5157>
