[postgis-tickets] [PostGIS] #5158: pgtopo_import / pgtopo_export need manpagers
trac at osgeo.org
Sun May 22 09:22:55 PDT 2022
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: topology | Version: master
Keywords: |
As noted by Bas
Would you consider adding manpages for pgtopo_import/pgtopo_export?
https://lists.osgeo.org/pipermail/postgis-devel/2022-May/029638.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5158>
