[postgis-tickets] [PostGIS] #4541: ST_ConcaveHull returns a "geometrycollection" type instead of the expected "polygon"
trac at osgeo.org
Mon May 23 14:56:15 PDT 2022
"polygon"
Reporter: v89461 | Owner: robe
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 2.5.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
@kszafran
Which platform are you running on? Wondering if by chance you are able to
test the new ST_ConcaveHull. If you are on windows I have precompiled
builds in experimental section - https://postgis.net/windows_downloads/ -
the 3.3.0alpha1 builds.
The new ST_ConcaveHull will use the new native GEOS support introduced in
GEOS 3.11 (not yet released). At anyrate I'll try with your example later
this week to make sure it solves your issue -
https://postgis.net/docs//manual-3.3/ST_ConcaveHull.html
on a related topic, there is also support for alphashapes introduced in
PostGSI 3.3.0 SFCGAL 1.4.1
https://postgis.net/docs//manual-3.3/ST_OptimalAlphaShape.html
https://postgis.net/docs//manual-3.3/ST_AlphaShape.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4541#comment:11>
