[postgis-tickets] [PostGIS] #5161: Exposed GEOSLineMergeDirected
trac at osgeo.org
Tue May 24 16:12:01 PDT 2022
Reporter: mdavis | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Comment (by mdavis):
Regina says:
It won’t cause any problems if you overload it rather than add a default
arg.
The default arg is cleaner, since we won’t have an additional function to
contend with.
The main danger with adding a default arg is anybody who is using
ST_LineMerge in views will have some upgrade issues. Since adding a
default arg requires dropping the old version.
Though Sandro made some adjustments to partly resolve that.
https://trac.osgeo.org/postgis/ticket/5033
It renames the old function (assuming you put in the right availability
comments) and then if there are views dependent on the old (because views
references the oid of the function, and not the function name), then the
upgrade will be in an incomplete upgrade state (will just have those
dangling old names)
https://trac.osgeo.org/postgis/changeset/3d947448b9c939b321bc22b85c719845722ecc3d/git
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5161#comment:1>
