[postgis-tickets] [PostGIS] #5163: ST_OrientedEnvelope goes into infinite loop when giving a straight line
trac at osgeo.org
Wed May 25 10:04:59 PDT 2022
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS GEOS
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Changes (by robe):
* milestone: PostGIS 2.5.7 => PostGIS GEOS
Old description:
> SELECT ST_OrientedEnvelope(st_geomfromtext('LINESTRING(-99.48710639268086
> 34.79029839231914,-99.48370699999998 34.78689899963806,-99.48152167568102
> 34.784713675318976)',4326));
> However this one works:
> SELECT ST_OrientedEnvelope('LINESTRING(1 2,1.5 2,2 2)'::geometry);
> Tested against latest released GEOS and PostGIS develop branch.
> and also
> POSTGIS="3.1.4 ded6c34" [EXTENSION] PGSQL="140" GEOS="3.9.1-CAPI-1.14.2"
> PROJ="8.0.1" GDAL="GDAL 3.3.0, released 2021/04/26" LIBXML="2.9.1"
> LIBJSON="0.15" LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)" RASTER
> PostgreSQL 14.1 on aarch64-unknown-linux-gnu, compiled by gcc (GCC) 7.3.1
> 20180712 (Red Hat 7.3.1-6), 64-bit
New description:
and also
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5163#comment:1>
