[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-15-gbded3b449
git at osgeo.org
git at osgeo.org
Mon May 30 09:23:38 PDT 2022
the project "PostGIS".
via bded3b4498cfc1ca35b74e16e25c571d97b1f132 (commit)
from b1e00a36a747be748fca827e02927721eb0226b5 (commit)
revisions in full, below.
commit bded3b4498cfc1ca35b74e16e25c571d97b1f132
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon May 30 09:23:33 2022 -0700
Capture and THEN ignore values for CI
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 2b73d2758..47146c980 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -534,32 +534,32 @@ static int
getMaxFieldSize(PGconn *conn, char *schema, char *table, char *fname)
int size;
- char *query;
+ stringbuffer_t query;
PGresult *res;
/*( this is ugly: don't forget counting the length */
/* when changing the fixed query strings ) */
+ stringbuffer_init(&query);
if ( schema )
- query = (char *)malloc(strlen(fname)+strlen(table)+
- strlen(schema)+46);
- sprintf(query,
- "select max(octet_length(\"%s\"::text)) from \"%s\".\"%s\"",
- fname, schema, table);
+ stringbuffer_aprintf(
+ &query,
+ "select max(octet_length(\"%s\"::text)) from \"%s\".\"%s\"",
+ fname, schema, table);
else
- query = (char *)malloc(strlen(fname)+strlen(table)+46);
- sprintf(query,
- "select max(octet_length(\"%s\"::text)) from \"%s\"",
- fname, table);
+ &query,
+ "select max(octet_length(\"%s\"::text)) from \"%s\"",
+ fname, table);
- LWDEBUGF(4, "maxFieldLenQuery: %s\n", query);
+ LWDEBUGF(4, "maxFieldLenQuery: %s\n", stringbuffer_getstring(&query));
- res = PQexec(conn, query);
- free(query);
+ res = PQexec(conn, stringbuffer_getstring(&query));
+ stringbuffer_release(&query);
if ( ! res || PQresultStatus(res) != PGRES_TUPLES_OK )
printf( _("Querying for maximum field length: %s"),
@@ -1182,54 +1182,28 @@ ShpDumperCreate(SHPDUMPERCONFIG *config)
char *
ShpDumperGetConnectionStringFromConn(SHPCONNECTIONCONFIG *conn)
- char *connstring;
- int connlen;
- connlen = 64 +
- (conn->host ? strlen(conn->host) : 0) + (conn->port ? strlen(conn->port) : 0) +
- (conn->username ? strlen(conn->username) : 0) + (conn->password ? strlen(conn->password) : 0) +
- (conn->database ? strlen(conn->database) : 0);
- connstring = malloc(connlen);
- memset(connstring, 0, connlen);
+ stringbuffer_t cs;
+ stringbuffer_init(&cs);
if (conn->host)
- strcat(connstring, " host=");
- strcat(connstring, conn->host);
+ stringbuffer_aprintf(&cs, " host=%s", conn->host);
if (conn->port)
- strcat(connstring, " port=");
- strcat(connstring, conn->port);
+ stringbuffer_aprintf(&cs, " port=%s", conn->port);
if (conn->username)
- strcat(connstring, " user=");
- strcat(connstring, conn->username);
+ stringbuffer_aprintf(&cs, " user=%s", conn->username);
if (conn->password)
- strcat(connstring, " password='");
- strcat(connstring, conn->password);
- strcat(connstring, "'");
+ stringbuffer_aprintf(&cs, " password='%s'", conn->password);
if (conn->database)
- strcat(connstring, " dbname=");
- strcat(connstring, conn->database);
+ stringbuffer_aprintf(&cs, " dbname=%s", conn->database);
if ( ! getenv("PGCLIENTENCODING") )
- strcat(connstring, " client_encoding=UTF8");
+ stringbuffer_append(&cs, " client_encoding=UTF8");
- return connstring;
+ return cs.str_start;
/* Connect to the database and identify the version of PostGIS (and any other
@@ -1238,11 +1212,10 @@ int
ShpDumperConnectDatabase(SHPDUMPERSTATE *state)
PGresult *res;
- char *connstring, *tmpvalue;
+ char *tmpvalue;
/* Generate the PostgreSQL connection string */
- connstring = ShpDumperGetConnectionStringFromConn(state->config->conn);
+ char *connstring = ShpDumperGetConnectionStringFromConn(state->config->conn);
/* Connect to the database */
state->conn = PQconnectdb(connstring);
@@ -1353,7 +1326,9 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
if (state->config->usrquery)
int r = asprintf(&(state->table), "__pgsql2shp%lu_tmp_table", (long)getpid());
+ (void)r;
r = asprintf(&query, "CREATE TEMP TABLE \"%s\" AS %s", state->table, state->config->usrquery);
+ (void)r;
res = PQexec(state->conn, query);
free(query);
@@ -1384,6 +1359,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
"n.oid = c.relnamespace AND "
"a.atttypid != 0 AND "
"a.attnum > 0 AND c.relname = '%s'", state->schema, state->table);
+ (void)r;
else
@@ -1394,6 +1370,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
"c.relname = '%s' AND "
"pg_catalog.pg_table_is_visible(c.oid)", state->table);
+ (void)r;
LWDEBUGF(3, "query is: %s\n", query);
Summary of changes:
loader/pgsql2shp-core.c | 79 ++++++++++++++++++-------------------------------
1 file changed, 28 insertions(+), 51 deletions(-)
hooks/post-receive
