[postgis-tickets] [PostGIS] #4541: ST_ConcaveHull returns a "geometrycollection" type instead of the expected "polygon"
trac at osgeo.org
Tue May 31 12:04:49 PDT 2022
"polygon"
Reporter: v89461 | Owner: robe
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 2.5.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by pramsey):
Tempted to close this out, as the new GEOS algorithm works on this just
fine, so the problem will disappear as versions roll out supporting the
new GEOS, starting with 3.3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4541#comment:13>
