[PostGIS] #5547: postgis 3.4 not using gist index when concatinating string in st_geomfromtext
trac at osgeo.org
Tue Aug 6 16:04:13 PDT 2024
st_geomfromtext
Reporter: tomwlane | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.3.6
Component: postgis | Version: 3.4.x
Resolution: worksforme | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => worksforme
Comment:
# explain select count(*) from ldb_000b21a_e where
st_intersects(st_geomfromtext(concat('POINT(' || 8978052 || ' ' || 2146588
|| ')')), geom);
QUERY PLAN
Aggregate (cost=22.06..22.07 rows=1 width=8)
-> Index Scan using geom_x on ldb_000b21a_e (cost=0.91..22.06 rows=1
width=0)
Index Cond: (geom && st_geomfromtext(concat('POINT(8978052
2146588)'::text)))
Filter: st_intersects(st_geomfromtext(concat('POINT(8978052
2146588)'::text)), geom)
(4 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5547#comment:8>
