[PostGIS] #5697: fix or document id escaping for ST_EstimatedExtent params
PostGIS trac at osgeo.org
Wed Aug 7 07:34:00 PDT 2024
  Reporter:  Yuri     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.3
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 @robe, I dunno what you think about this one, I don't know what to put in
 doco, and in a perfect world I would go back and just change the function
 so the arguments are directly regclass arguments, but doing so now *might*
 break existing users (of which there area a lot of important ones, as
 every postgis client calls estimated extent) and would also involve
 explicitly dropping the current signature (or it would interpose itself on
 the case where a user calls using text parameters, instead of allowing
 autocasting to work its magic and convert to regclass).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5697#comment:5>
