[PostGIS] #5768: PostGIS_Extensions_Upgrade() with this code https://gitlab.com/larsop/postgis
trac at osgeo.org
Thu Aug 8 22:38:16 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: postgis | Version: 3.4.x
Keywords: |
After installing PostGIS_Full_Version reports this
SELECT PostGIS_Full_Version();
postgis_full_version
POSTGIS="3.5.0dev 3.4.0rc1-1272-g80806376a" [EXTENSION] PGSQL="140"
GEOS="3.12.1-CAPI-1.18.1" PROJ="9.3.0" LIBXML="2.9.13" LIBPROTOBUF="1.3.3"
WAGYU="0.5.0 (Internal)" (core procs from "3.5.0dev
3.4.0rc1-1109-g88f11a406" need upgrade) TOPOLOGY (topology procs from
"3.5.0dev 3.4.0rc1-1109-g88f11a406" need upgrade)
(1 row)
I then upgrade and I get this error
SELECT PostGIS_Extensions_Upgrade();
NOTICE: 00000: Updating extension postgis 3.5.0dev
ERROR: 42883: could not find function "ST_RemoveIrrelevantPointsForView"
in file "/usr/lib/postgresql/14/lib/postgis-3.so"
CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "ANY";ALTER
EXTENSION postgis UPDATE TO "3.5.0dev""
PL/pgSQL function postgis_extensions_upgrade(text) line 88 at EXECUTE
I found when testing [https://trac.osgeo.org/postgis/ticket/5766]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5768>
