[PostGIS] #5768: PostGIS_Extensions_Upgrade() with this code https://gitlab.com/larsop/postgis
trac at osgeo.org
Fri Aug 9 02:48:27 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Old description:
> After installing PostGIS_Full_Version reports this
> SELECT PostGIS_Full_Version();
> postgis_full_version
> POSTGIS="3.5.0dev 3.4.0rc1-1272-g80806376a" [EXTENSION] PGSQL="140"
> GEOS="3.12.1-CAPI-1.18.1" PROJ="9.3.0" LIBXML="2.9.13"
> LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" (core procs from "3.5.0dev
> 3.4.0rc1-1109-g88f11a406" need upgrade) TOPOLOGY (topology procs from
> "3.5.0dev 3.4.0rc1-1109-g88f11a406" need upgrade)
> (1 row)
> I then upgrade and I get this error
> SELECT PostGIS_Extensions_Upgrade();
> NOTICE: 00000: Updating extension postgis 3.5.0dev
> LOCATION: exec_stmt_raise, pl_exec.c:3869
> ERROR: 42883: could not find function "ST_RemoveIrrelevantPointsForView"
> in file "/usr/lib/postgresql/14/lib/postgis-3.so"
> CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "ANY";ALTER
> EXTENSION postgis UPDATE TO "3.5.0dev""
> PL/pgSQL function postgis_extensions_upgrade(text) line 88 at EXECUTE
> LOCATION: load_external_function, dfmgr.c:129
> I found when testing [https://trac.osgeo.org/postgis/ticket/5766]
New description:
GEOS="3.12.1-CAPI-1.18.1" PROJ="9.3.0" LIBXML="2.9.13" LIBPROTOBUF="1.3.3"
(1 row)
Comment (by strk):
What does this return ?
nm `pg_config --pkglibdir`/postgis-3.so | grep Remove
The signature should be in the .so file since
eeb490ce1d4a38f0f19da88aa0569692c8a31b34 -- did you re-run ./configure
after update ? Did `make check` succeed ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5768#comment:1>
