[PostGIS] #5768: PostGIS_Extensions_Upgrade() with this code https://gitlab.com/larsop/postgis
PostGIS trac at osgeo.org
Fri Aug 9 02:59:59 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  closed
  Priority:  medium             |  Milestone:  PostGIS 3.5.0
 Component:  postgis            |    Version:  3.4.x
Resolution:  invalid            |   Keywords:
Changes (by Lars Aksel Opsahl):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Replying to [comment:1 strk]:
 > What does this return ?
 > nm `pg_config --pkglibdir`/postgis-3.so | grep Remove
 lop at cpu11:/pg_build_from_source/gitlab_com_larsop/postgis$ nm `pg_config
 00000000000329f0 T ST_RemoveRepeatedPoints
 00000000000329e0 T pg_finfo_ST_RemoveRepeatedPoints
 > The signature should be in the .so file since
 eeb490ce1d4a38f0f19da88aa0569692c8a31b34 -- did you re-run ./configure
 after update ? Did `make check` succeed ?
 Seems like I did not do that and when I did the upgrade worked ok.
 postgis_extensions_upgrade
  Upgrade to version 3.5.0dev completed, run SELECT postgis_full_version();
 for details
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5768#comment:2>
