[PostGIS] #5768: PostGIS_Extensions_Upgrade() with this code https://gitlab.com/larsop/postgis
PostGIS trac at osgeo.org
Tue Aug 13 00:33:48 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  closed
  Priority:  medium             |  Milestone:  PostGIS 3.5.0
 Component:  postgis            |    Version:  3.4.x
Resolution:  invalid            |   Keywords:
Comment (by Lars Aksel Opsahl):
 Tested on another database with the same postgis version but postgresql 12
 and where have also installed postgis_sfcgal. I have different databases
 on this server the database where postgis_sfcgal was not installed the
 upgrade wen OK.
 When postgis_sfcgal is installed I see this problem
 SELECT PostGIS_Extensions_Upgrade();
 NOTICE:  00000: Updating extension postgis 3.4.0
 NOTICE:  00000: Updating extension postgis_sfcgal ANY
 NOTICE:  00000: version "ANY" of extension "postgis_sfcgal" is already
 installed
 ERROR:  22023: extension "postgis_sfcgal" has no update path from version
 "ANY" to version "3.5.0dev"
 CONTEXT:  SQL statement "ALTER EXTENSION postgis_sfcgal UPDATE TO
 "ANY";ALTER EXTENSION postgis_sfcgal UPDATE TO "3.5.0dev""
 PL/pgSQL function postgis_extensions_upgrade(text) line 88 at EXECUTE
 vroom5.int.nibio.no postgres at sl=# SELECT PostGIS_Full_Version();
 postgis_full_version
  POSTGIS="3.5.0dev 3.4.0rc1-1272-g80806376a" [EXTENSION] PGSQL="120"
 GEOS="3.12.1-CAPI-1.18.1" SFCGAL="1.3.7" PROJ="8.2.0" GDAL="GDAL 3.4.3,
 released 2022/04/22" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)" (core procs from "3.4.0 0874ea3" need upgrade)
 TOPOLOGY (topology procs from "3.4.0 0874ea3" need upgrade) RASTER (raster
 procs from "3.4.0 0874ea3" need upgrade) (sfcgal procs from "3.4.0
 (1 row)
 I also tested
 ALTER EXTENSION postgis_sfcgal UPDATE TO "ANY";
 ALTER EXTENSION postgis_sfcgal UPDATE TO "3.5.0dev";
 Then I got a new error
 installed
 ALTER EXTENSION
 A new error to report or a user error ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5768#comment:3>
