[SCM] PostGIS branch master updated. 3.5.0alpha2-50-g254ae9929
Fri Aug 30 03:22:34 PDT 2024
the project "PostGIS".
       via  254ae9929367ffc7e0f7d6e972aedc34960dbbb4 (commit)
      from  aef3e41ab10e2f80cdbdf58f623faa92e52b0b10 (commit)
revisions in full, below.
commit 254ae9929367ffc7e0f7d6e972aedc34960dbbb4
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 30 12:21:46 2024 +0200
    Restore 3.4 signature for deprecated sfcgal 3d functions
    References #5700, #5773
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 278ee8972..eb018ad7e 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -93,7 +93,7 @@ CREATE OR REPLACE FUNCTION CG_3DDifference(geom1 geometry, geom2 geometry)
 -- Availability: 2.2
 -- Deprecation in 3.5.0
-CREATE OR REPLACE FUNCTION ST_3DDifference(geometry, geometry)
+CREATE OR REPLACE FUNCTION ST_3DDifference(geom1 geometry, geom2 geometry)
 RETURNS geometry AS $$
 	SELECT @extschema at ._postgis_deprecate(
 		'ST_3DDifference', 'CG_3DDifference', '3.5.0');
@@ -132,7 +132,7 @@ CREATE AGGREGATE ST_3DUnion(geometry) (
-CREATE OR REPLACE FUNCTION ST_3DUnion(geometry, geometry)
+CREATE OR REPLACE FUNCTION ST_3DUnion(geom1 geometry, geom2 geometry)
 		'ST_3DUnion', 'CG_3DUnion', '3.5.0');
Summary of changes:
 sfcgal/sfcgal.sql.in | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
