[SCM] PostGIS branch master updated. 3.5.0alpha2-51-gf2edd6896
git at osgeo.org
git at osgeo.org
Fri Aug 30 03:36:13 PDT 2024
the project "PostGIS".
via f2edd689602cb18c7a7268142838b68ce41ddab0 (commit)
from 254ae9929367ffc7e0f7d6e972aedc34960dbbb4 (commit)
revisions in full, below.
commit f2edd689602cb18c7a7268142838b68ce41ddab0
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Aug 30 11:29:48 2024 +0200
Enable sfgal extension upgrade testing
Closes #5773
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index d6820618e..587ea3eff 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -195,6 +195,9 @@ fi
if test -f postgis_raster--${to_version}.sql; then
INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_raster"
fi
+if test -f postgis_sfcgal--${to_version}.sql; then
+ INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_sfcgal"
+fi
echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
@@ -216,7 +219,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
elif test "${EXT}" = "postgis_raster"; then
REGDIR=${BUILDDIR}/raster/test/regress
elif test "${EXT}" = "postgis_sfcgal"; then
- REGDIR=${BUILDDIR}/sfcgal/test/regress
+ REGDIR=${BUILDDIR}/sfcgal/regress
else
echo "SKIP: don't know where to find regress tests for extension ${EXT}"
fi
Summary of changes:
utils/check_all_upgrades.sh | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
