[SCM] PostGIS branch master updated. 3.5.0-161-g3ea7a1a2c
git at osgeo.org
git at osgeo.org
Tue Dec 17 02:47:39 PST 2024
the project "PostGIS".
via 3ea7a1a2cfd84097027145a762ed43fe3a71358e (commit)
from 460f9b8d4b91beadeee276bcbd582b63674b6f3e (commit)
revisions in full, below.
commit 3ea7a1a2cfd84097027145a762ed43fe3a71358e
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date: Tue Dec 17 09:35:39 2024 +0000
Translated PostGIS Manual using Weblate (German)
Currently translated at 51.1% (2944 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 9ed5f6886..7653f0b55 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
-"PO-Revision-Date: 2024-12-17 08:47+0000\n"
+"PO-Revision-Date: 2024-12-17 10:47+0000\n"
"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/de/>\n"
@@ -112,7 +112,7 @@ msgstr ""
"PostgreSQL-Version und main auf den Cluster bezieht."
#. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"On windows, if you are running as a service, you can set via System "
"variables which for Windows 7 you can get to by right-clicking on Computer-"
@@ -121,13 +121,12 @@ msgid ""
"clicking <emphasis>Advanced System Settings ->Advanced->Environment "
"Variables</emphasis> and adding new system variables."
msgstr ""
-"Unter Windows können Sie, wenn Sie als Dienst ausgeführt werden, "
-"Systemvariablen festlegen, die Sie unter Windows 7 mit einem Rechtsklick auf "
-"Computer->Eigenschaften Erweiterte Systemeinstellungen oder im Explorer "
-"unter <varname>Systemsteuerung\\Alle Systemsteuerungselemente\\System</"
-"varname> erreichen. Klicken Sie dann auf <emphasis>Erweiterte "
-"Systemeinstellungen ->Erweitert->Umgebungsvariablen</emphasis> und "
-"fügen Sie neue Systemvariablen hinzu."
+"Wenn Sie PostgreSQL unter Windows als Dienst ausführen, können sie die "
+"Systemvariablen unter Windows 7 mit einem Rechtsklick auf Computer->"
+"roperties Advanced System Settings oder im Explorer unter <varname>Control "
+"Panel\\All Control Panel Items\\System</varname>. setzen. Klicken Sie "
+"anschließend auf <emphasis>Advanced System Settings ->Advanced->"
+"Environment Variables</emphasis> um neue Systemvariablen hinzuzufügen."
#. Tag: para
#, no-c-format
@@ -179,10 +178,11 @@ msgstr ""
"folgende SQL Befehl ausgeführt:"
#. Tag: title
+#, no-c-format
msgid "Spatially enable database without using EXTENSION (discouraged)"
msgstr ""
-"Datenbank räumlich aktivieren, ohne EXTENSION zu verwenden (nicht empfohlen)"
+"Räumliche Aktivierung der Datenbank ohne Verwendung von EXTENSION (nicht "
+"empfohlen)"
#. Tag: para
#, no-c-format
@@ -196,19 +196,19 @@ msgstr ""
"(wie in einer Test-, Entwicklungs- oder eingeschränkten Umgebung)."
#. Tag: para
+#, no-c-format
msgid ""
"Adding PostGIS objects and function definitions into your database is done "
"by loading the various sql files located in <filename>[prefix]/share/"
"contrib</filename> as specified during the build phase."
msgstr ""
"Das Hinzufügen von PostGIS-Objekten und Funktionsdefinitionen in Ihre "
-"Datenbank erfolgt durch das Laden der verschiedenen sql-Dateien, die sich in "
-"<filename>[prefix]/share/contrib</filename> befinden, wie während der "
-"Erstellungsphase angegeben."
+"Datenbank erfolgt durch das Laden unterschiedlicher SQL-Dateien unter "
+"<filename>[prefix]/share/contrib</filename>, wie während der "
+"Erstellungsphase angezeigt."
#. Tag: para
+#, no-c-format
msgid ""
"The core PostGIS objects (geometry and geography types, and their support "
"functions) are in the <filename>postgis.sql</filename> script. Raster "
@@ -217,26 +217,24 @@ msgid ""
msgstr ""
"Die zentralen PostGIS-Objekte (Geometrie- und Geografietypen sowie deren "
"Unterstützungsfunktionen) befinden sich im Skript <filename>postgis.sql</"
-"filename>. Rasterobjekte befinden sich im Skript <filename>rtpostgis.sql</"
-"filename>. Topologieobjekte befinden sich im Skript <filename>topology.sql</"
-"filename>."
+"filename>. Rasterobjekte sind im Skript <filename>rtpostgis.sql</filename>. "
+"Topologieobjekte sind im Skript <filename>topology.sql</filename>."
#. Tag: para
+#, no-c-format
msgid ""
"For a complete set of EPSG coordinate system definition identifiers, you can "
"also load the <filename>spatial_ref_sys.sql</filename> definitions file and "
"populate the <varname>spatial_ref_sys</varname> table. This will permit you "
"to perform ST_Transform() operations on geometries."
msgstr ""
-"Für einen vollständigen Satz von EPSG-Koordinatensystem-"
-"Definitionsbezeichnern können Sie auch die Definitionsdatei "
-"<filename>spatial_ref_sys.sql</filename> laden und die Tabelle "
-"<varname>spatial_ref_sys</varname> befüllen. Damit können Sie ST_Transform()-"
-"Operationen an Geometrien durchführen."
+"Für einen vollständigen Satz an EPSG-Koordinatensystemdefinitionen können "
+"Sie auch die Definitionsdatei <filename>spatial_ref_sys.sql</filename> laden "
+"um die Tabelle <varname>spatial_ref_sys</varname> zu befüllen. Dies "
+"ermöglicht Ihnen ST_Transform()-Operationen an Geometrien durchzuführen."
#. Tag: para
+#, no-c-format
msgid ""
"If you wish to add comments to the PostGIS functions, you can find them in "
"the <filename>postgis_comments.sql</filename> script. Comments can be viewed "
@@ -244,17 +242,17 @@ msgid ""
"<command>psql</command> terminal window."
msgstr ""
"Wenn Sie Kommentare zu den PostGIS-Funktionen hinzufügen möchten, finden Sie "
-"diese im Skript <filename>postgis_comments.sql</filename>. Die Kommentare "
-"können einfach durch Eingabe von <command>\\dd [function_name]</command> in "
-"einem <command>psql</command> Terminalfenster angezeigt werden."
+"diese im Skript <filename>postgis_comments.sql</filename>. Kommentare können "
+"durch die Eingabe von <command>\\dd [function_name]</command> in einem "
+"<command>psql</command> Terminalfenster angezeigt werden."
#. Tag: para
+#, no-c-format
msgid "Run the following Shell commands in your terminal:"
msgstr "Führen Sie die folgenden Shell-Befehle in Ihrem Terminal aus:"
#. Tag: title
+#, no-c-format
msgid "Upgrading spatial databases"
msgstr "Aktualisierung von Geodatenbanken"
@@ -269,23 +267,22 @@ msgstr ""
"erfordert."
#. Tag: para
+#, no-c-format
msgid ""
"Unfortunately not all definitions can be easily replaced in a live database, "
"so sometimes your best bet is a dump/reload process."
msgstr ""
-"Leider können nicht alle Definitionen in einer aktiven Datenbank einfach "
-"ersetzt werden, so dass manchmal ein Dump/Reload-Prozess die beste Lösung "
-"ist."
+"Da leider nicht alle Definitionen in einer aktiven Datenbank einfach ersetzt "
+"werden können, ist manchmal ein Dump/Reload-Prozess die beste Lösung."
#. Tag: para
+#, no-c-format
msgid ""
"PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases, and "
"a HARD UPGRADE procedure for major releases."
msgstr ""
-"PostGIS bietet ein SOFT UPGRADE-Verfahren für Minor- oder Bugfix-Versionen "
-"und ein HARD UPGRADE-Verfahren für Major-Versionen."
+"PostGIS bietet ein SOFT UPGRADE-Verfahren für kleinere oder Bugfix-Releases "
+"sowie ein HARD-UPGRADE-Verfahren für Haupt-Releases."
#. Tag: para
#, no-c-format
@@ -304,17 +301,18 @@ msgid "Soft upgrade"
msgstr "Sanfte Aktualisierung"
#. Tag: para
+#, no-c-format
msgid ""
"If you installed your database using extensions, you'll need to upgrade "
"using the extension model as well. If you installed using the old sql script "
"way, you are advised to switch your install to extensions because the script "
"way is no longer supported."
msgstr ""
-"Wenn Sie Ihre Datenbank mithilfe von Erweiterungen installiert haben, müssen "
-"Sie das Upgrade auch mithilfe des Erweiterungsmodells durchführen. Wenn Sie "
-"mit dem alten SQL-Skript installiert haben, sollten Sie Ihre Installation "
-"auf Erweiterungen umstellen, da das Skript nicht mehr unterstützt wird."
+"Wenn Sie Ihre Datenbank mithilfe von EXTENSION installiert haben, müssen Sie "
+"das Upgrade ebenfalls über das EXTENSION Modell durchführen. Falls Sie die "
+"Installation über die alte SQL-Skript-Methode vorgenommen haben, wird "
+"empfohlen, auf die Nutzung von EXTENSION umzusteigen, da die Skript-Methode "
+"nicht länger unterstützt wird."
#. Tag: title
#, no-c-format
@@ -322,32 +320,33 @@ msgid "Soft Upgrade 9.1+ using extensions"
msgstr "Sanfte Aktualisierung 9.1+ mittels Erweiterungen"
#. Tag: para
+#, no-c-format
msgid ""
"If you originally installed PostGIS with extensions, then you need to "
"upgrade using extensions as well. Doing a minor upgrade with extensions, is "
"fairly painless."
msgstr ""
-"Wenn Sie PostGIS ursprünglich mit Erweiterungen installiert haben, dann "
-"müssen Sie das Upgrade auch mit Erweiterungen durchführen. Ein kleines "
-"Upgrade mit Erweiterungen ist ziemlich schmerzlos."
+"Wenn Sie PostGIS ursprünglich mithilfe von EXTENSION installiert haben, "
+"müssen Sie das Upgrade ebenfalls über EXTENSION durchführen. Ein kleines "
+"Upgrade mit Erweiterungen ist relativ unkompliziert."
#. Tag: para
+#, no-c-format
msgid ""
"If you are running PostGIS 3 or above, then you should use the <xref "
"linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade to the latest "
"version you have installed."
msgstr ""
-"Wenn Sie mit PostGIS 3 oder höher arbeiten, sollten Sie die Funktion <xref "
-"linkend=\"PostGIS_Extensions_Upgrade\"/> verwenden, um auf die neueste "
-"Version zu aktualisieren, die Sie installiert haben."
+"Wenn Sie PostGIS 3 oder höher verwenden, sollten Sie die Funktion <xref "
+"linkend=\"PostGIS_Extensions_Upgrade\"/> nutzen, um auf die neueste "
+"installierte Version zu aktualisieren."
#. Tag: para
+#, no-c-format
msgid "If you are running PostGIS 2.5 or lower, then do the following:"
msgstr ""
-"Wenn Sie PostGIS 2.5 oder niedriger verwenden, gehen Sie wie folgt vor:"
+"Falls Sie PostGIS 2.5 oder niedriger verwenden, gehen Sie bitte wie folgt "
+"vor:"
#. Tag: para
#, no-c-format
@@ -360,9 +359,9 @@ msgstr ""
"folgt explizit angeben:"
#. Tag: para
+#, no-c-format
msgid "If you get an error notice something like:"
-msgstr "Wenn Sie eine Fehlermeldung wie diese erhalten:"
+msgstr "Falls Sie eine Fehlermeldung erhalten, die in etwa wie folgt aussieht:"
#. Tag: para
#, no-c-format
@@ -377,9 +376,10 @@ msgstr ""
"wiederherstellen."
#. Tag: para
+#, no-c-format
msgid "If you get a notice message like:"
-msgstr "Wenn Sie eine Meldung wie diese erhalten:"
+msgstr ""
+"Falls Sie eine Hinweisnachricht erhalten, die in etwa wie folgt aussieht:"
#. Tag: para
#, no-c-format
@@ -398,17 +398,18 @@ msgstr ""
"\"next\" wieder weglassen:"
#. Tag: para
+#, no-c-format
msgid ""
"If you installed PostGIS originally without a version specified, you can "
"often skip the reinstallation of postgis extension before restoring since "
"the backup just has <code>CREATE EXTENSION postgis</code> and thus picks up "
"the newest latest version during restore."
msgstr ""
-"Wenn Sie PostGIS ursprünglich ohne Versionsangabe installiert haben, können "
-"Sie die Neuinstallation der postgis-Erweiterung vor der Wiederherstellung "
-"oft überspringen, da das Backup nur <code>CREATE EXTENSION postgis</code> "
-"hat und somit die neueste Version bei der Wiederherstellung übernimmt."
+"Wenn Sie PostGIS ursprünglich installiert haben ohne eine Version anzugeben "
+", können Sie die Neuinstallation der postgis-Erweiterung vor der "
+"Wiederherstellung oftmals überspringen, da im Backup nur <code>CREATE "
+"EXTENSION postgis</code> steht und daher die aktuellste Version für die "
+"Wiederherstellung herangezogen wird."
#. Tag: para
#, no-c-format
@@ -441,7 +442,7 @@ msgstr ""
"Ansatz versucht wird, erhalten Sie eine Meldungen wie:"
#. Tag: para
+#, no-c-format
msgid ""
"NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from PostGIS 2.* "
"prior to r7409, you cannot use this procedure but would rather need to do a "
@@ -452,7 +453,7 @@ msgstr ""
"ein <link linkend=\"hard_upgrade\">HARD UPGRADE</link> durchführen."
#. Tag: para
+#, no-c-format
msgid ""
"After compiling and installing (make install) you should find a set of "
"<filename>*_upgrade.sql</filename> files in the installation folders. You "
@@ -460,58 +461,58 @@ msgid ""
msgstr ""
"Nach dem Kompilieren und Installieren (make install) sollten Sie eine Reihe "
"von <filename>*_upgrade.sql</filename> Dateien in den Installationsordnern "
-"finden. Sie können sie alle mit auflisten:"
+"finden. Sie können alle wie folgt auflisten:"
#. Tag: para
+#, no-c-format
msgid ""
"Load them all in turn, starting from <filename>postgis_upgrade.sql</"
"filename>."
msgstr ""
-"Laden Sie sie alle nacheinander, beginnend mit <filename>postgis_upgrade."
+"Laden Sie diese alle nacheinander, beginnend mit <filename>postgis_upgrade."
"sql</filename>."
#. Tag: para
+#, no-c-format
msgid ""
"The same procedure applies to raster, topology and sfcgal extensions, with "
"upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
"<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
"filename> respectively. If you need them:"
msgstr ""
-"Das gleiche Verfahren gilt für Raster-, Topologie- und sfcgal-Erweiterungen, "
-"mit Upgrade-Dateien namens <filename>rtpostgis_upgrade.sql</filename>, "
-"<filename>topology_upgrade.sql</filename> und <filename>sfcgal_upgrade.sql</"
-"filename>. Falls Sie sie benötigen:"
+"Das gleiche Verfahren gilt auch für die Raster-, Topologie- und sfcgal-"
+"Erweiterungen, mit den Upgrade-Dateien <filename>rtpostgis_upgrade.sql</"
+"filename>, <filename>topology_upgrade.sql</filename> und "
+"<filename>sfcgal_upgrade.sql</filename>. Falls Sie diese benötigen:"
#. Tag: para
+#, no-c-format
msgid "You are advised to switch to an extension based install by running"
msgstr ""
-"Wir empfehlen Ihnen, zu einer erweiterungsbasierten Installation zu "
-"wechseln, indem Sie"
+"Wir empfehlen Ihnen, zu einer Installation mit EXTENSION zu wechseln, indem "
+"Sie folgendes ausführen"
#. Tag: para
+#, no-c-format
msgid ""
"If you can't find the <filename>postgis_upgrade.sql</filename> specific for "
"upgrading your version you are using a version too early for a soft upgrade "
"and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
msgstr ""
-"Wenn Sie die <filename>postgis_upgrade.sql</filename> speziell für das "
-"Upgrade Ihrer Version nicht finden können, verwenden Sie eine Version, die "
-"zu früh für ein Soft-Upgrade ist und müssen ein <link "
-"linkend=\"hard_upgrade\">HARD UPGRADE</link> durchführen."
+"Wenn Sie <filename>postgis_upgrade.sql</filename> für das Upgrade Ihrer "
+"Version nicht finden können, so liegt das daran, dass die Version für ein "
+"Soft-Upgrade zu niedrig ist und Sie daher ein <link linkend=\"hard_upgrade\""
+">HARD UPGRADE</link> durchführen müssen."
#. Tag: para
+#, no-c-format
msgid ""
"The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
"about the need to run this kind of upgrade using a \"procs need upgrade\" "
"message."
msgstr ""
-"Die Funktion <xref linkend=\"PostGIS_Full_Version\"/> sollte Sie mit der "
-"Meldung \"procs need upgrade\" über die Notwendigkeit eines solchen Upgrades "
+"Die Funktion <xref linkend=\"PostGIS_Full_Version\"/> sollte Sie über die "
+"Meldung \"procs need upgrade\" von der Notwendigkeit eines solchen Upgrades "
"informieren."
#. Tag: title
Summary of changes:
doc/po/de/postgis-manual.po | 167 ++++++++++++++++++++++----------------------
1 file changed, 84 insertions(+), 83 deletions(-)
hooks/post-receive
