[SCM] PostGIS branch stable-3.3 updated. 3.3.6-26-gf09a1793b
    git at osgeo.org
    git at osgeo.org
    Fri Jul  5 02:23:04 PDT 2024
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  f09a1793b9b088cde7203a4a2b90f88faa1c990d (commit)
       via  0b286e91bea0b177d51fec4f844ef982a052e595 (commit)
      from  825755c43b0b53d69bce4bf2ecc57ebcc238bcaf (commit)
revisions in full, below.
commit f09a1793b9b088cde7203a4a2b90f88faa1c990d
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 5 05:17:46 2024 -0400
    Fix regression failures against PG17
    Closes #5687 for PostGIS 3.3.7
    Closes #5756 for PostGIS 3.3.7
diff --git a/NEWS b/NEWS
index 9f7808021..7f05ebb97 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,11 @@
 PostGIS 3.3.7
 xxxx/xx/xx
+This version requires PostgreSQL 11-17, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+(and ST_MakeValid enhancements with 3.10+), Proj 6.1+,
+and PostgreSQL 15+.
 * Bug Fixes and Enhancements *
  - #5709, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
@@ -16,6 +21,8 @@ xxxx/xx/xx
  - #5686, ST_NumInteriorRings and Triangle crash (Paul Ramsey)
  - #5671, Bug in ST_Area function with use_spheroid=false
           (Paul Ramsey, Regina Obe)
+ - #5687, #5756 Support for PostgreSQL 17, revise postgis_get_full_version_schema()
+          to not rely on search_path
 PostGIS 3.3.6
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index 6af4bea39..7c0bff482 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -114,22 +114,51 @@ postgis_get_extension_schema(Oid ext_oid)
 static Oid
-	const char* proname = "postgis_full_version";
-	#if POSTGIS_PGSQL_VERSION < 160
-	List* names = stringToQualifiedNameList(proname);
-	#else
-	List* names = stringToQualifiedNameList(proname, NULL);
-	#endif
-	#if POSTGIS_PGSQL_VERSION < 140
-	FuncCandidateList clist = FuncnameGetCandidates(names, -1, NIL, false, false, false);
-	#else
-	FuncCandidateList clist = FuncnameGetCandidates(names, -1, NIL, false, false, false, false);
-	#endif
-	if (!clist)
+	const char* query =  "SELECT pronamespace "
+		" FROM pg_catalog.pg_proc "
+		" WHERE proname = 'postgis_full_version'";
+	int spi_result;
+	Oid funcNameSpaceOid;
+	if (SPI_OK_CONNECT != SPI_connect())
+		elog(ERROR, "%s: could not connect to SPI manager", __func__);
 		return InvalidOid;
-	return get_func_namespace(clist->oid);
+	/* Execute the query, noting the readonly status of this SQL */
+	spi_result = SPI_execute(query, true, 0);
+	if (spi_result != SPI_OK_SELECT || SPI_tuptable == NULL){
+		elog(ERROR, "%s: error executing query %d", __func__, spi_result);
+		SPI_finish();
+		return InvalidOid;
+	/* Read back the OID of the function namespace, only if one result returned
+	  If more than one, then this install is f..cked.
+		If 0 then postgis is not installed at all */
+	if (SPI_processed == 1)
+		TupleDesc tupdesc;
+		SPITupleTable *tuptable = SPI_tuptable;
+		HeapTuple tuple;
+		tupdesc = SPI_tuptable->tupdesc;
+		tuptable = SPI_tuptable;
+		tuple = tuptable->vals[0];
+		funcNameSpaceOid = atoi(SPI_getvalue(tuple, tupdesc, 1));
+		if (SPI_tuptable) SPI_freetuptable(tuptable);
+		SPI_finish();
+	else
+		elog(ERROR, "Cannot determine install schema of postgis_full_version function.");
+		SPI_finish();
+	return funcNameSpaceOid;
commit 0b286e91bea0b177d51fec4f844ef982a052e595
Date:   Fri Jul 5 05:16:44 2024 -0400
    Streamline winnie build, and update to GEOS 3.12.2
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index f7e2d63ee..24efa2044 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,79 +1,6 @@
 #!/usr/bin/env bash
-set -e
-if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.10.2
-	export GDAL_VER=3.4.2
-	export PROJ_VER=7.2.1
-	export SFCGAL_VER=1.4.1
-	export CGAL_VER=5.3
-	export ICON_VER=1.16
-	export ZLIB_VER=1.2.11
-  export PROTOBUF_VER=3.2.0
-	export PROTOBUFC_VER=1.2.1
-	export JSON_VER=0.12
-	export PROJSO=libproj-19.dll
-fi;
-export PROTOBUF_VER=3.2.0
-export PROTOBUFC_VER=1.2.1
-if  [[ "${JSON_VER}" == '' ]] ; then
-fi;
-export PCRE_VER=8.33
-if  [[ "${ICON_VER}" == '' ]] ; then
-  export ICON_VER=1.17
-fi;
-echo "ICON_VER ${ICON_VER}"
-#set to something even if override is on but not set
-if  [[ "${ZLIB_VER}" == '' ]] ; then
-  export ZLIB_VER=1.2.13
-fi;
-if  [[ "${LIBXML_VER}" == '' ]] ; then
-  export LIBXML_VER=2.7.8
-fi;
-if  [[ "${CGAL_VER}" == '' ]] ; then
-fi;
-#export GDAL_VER=2.4.0
-#export PROJ_VER=5.2.0
-echo "ZLIB_VER $ZLIB_VER"
-echo "PROJ_VER $PROJ_VER"
-echo "LIBXML_VER $LIBXML_VER"
-echo "CGAL_VER $CGAL_VER"
-export PROJECTS=/projects
-export MINGPROJECTS=/projects
-export PATHOLD=$PATH
-if [ "$OS_BUILD" == "64" ] ; then
-	export MINGHOST=x86_64-w64-mingw32
-else
-	export MINGHOST=i686-w64-mingw32
-fi;
-echo PATH AFTER: $PATH
-#export PG_VER=9.2beta2
-export PGWINVER=${PG_VER}edb
-export WORKSPACE=`pwd`
-echo PATH BEFORE: $PATH
-#export PGHOST=localhost
-#export PGPORT=8442
-export PGUSER=postgres
-#export GEOS_VER=3.4.0dev
-#export GDAL_VER=1.9.1
-export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
-export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
+. $(dirname $0)/winnie_common.sh
 if [ -n "$SOURCE_FOLDER" ]; then
   export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
@@ -84,6 +11,7 @@ else
   else
     #tagged version -- official release
     export POSTGIS_SRC=${PROJECTS}/postgis/tags/${POSTGIS_VER}.${POSTGIS_MICRO_VERSION}
+    INCLUDE_MINOR_LIB=0
   fi;
 fi;
@@ -92,18 +20,8 @@ export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POS
 #export POSTGIS_SRC=${PROJECTS}/postgis/trunk
-export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
-export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
-#add protobuf
-export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -124,29 +42,23 @@ cd ${POSTGIS_SRC}
 # 	make distclean
 # fi
+git clean -dxf # ensure we start fresh
+git describe --long --all --tags # Report where we are at
 sh autogen.sh
 if [ -n "$PCRE_VER" ]; then
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 fi
-if [ -n "$SFCGAL_VER" ]; then
-	##hard code versions of cgal etc. for now
-	export CGAL_VER=4.11
-	BOOST_VER=1.53.0
-	#BOOST_VER_WU=1_49_0
-	export BOOST_VER_WU=1_53_0
-	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+if [$INCLUDE_MINOR_LIB == "1"]; then
 #CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 #CFLAGS="-Wall -fno-omit-frame-pointer"
 #LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
-LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
   --with-pgconfig=${PGPATH}/bin/pg_config \
@@ -155,21 +67,18 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
   --with-gui --with-gettext=no \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
-  --without-interrupt-tests \
-  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
+  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
   #exit
 else
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
-CFLAGS="-Wall -fno-omit-frame-pointer" \
-LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
-  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
+./configure \
+  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
-  --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-gui --with-gettext=no \
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
+  --with-gui --with-gettext=no \
+  --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
 fi;
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index b3e2f7ef3..168e68bb3 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -3,93 +3,14 @@
 ## PostgreSQL, OS_BUILD denote the last build to be packaged
 ## and are passed in by the jenkins job process
-#export OS_BUILD=64
-#export OS_BUILD=32
-#export GCC_TYPE=
-#if no override is set - use these values
-#otherwise use the ones jenkins passes thru
-#!/usr/bin/env bash
-	export GEOS_VER=3.10.3
-	export CURL_VER=8.0.1
-fi;
-fi;
-  export ICON_VER=1.15
-fi;
-if  [[ "${CURL_VER}" == '' ]] ; then
-fi;
-echo "CURL_VER ${CURL_VER}"
-fi;
-  export LIBXML_VER=2.9.14
-fi;
-fi;
-export PGHOST=localhost
 WEB=/home/www/postgis/htdocs
 DWN=${WEB}/download
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
-export PGPATHEDB=${PGPATH}edb
-#export PROJSO=libproj-13.dll
 	cd $POSTGIS_SRC
@@ -115,14 +36,13 @@ export REL_PGVER=${PG_VER//./} #strip the period
 export RELDIR=${PROJECTS}/postgis/builds/${POSTGIS_MINOR_VER}
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}${GCC_TYPE}
 #PATH="${PGPATH}/bin:${PGPATH}/lib:${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #echo PATH AFTER: $PATH
 outdir="${RELDIR}/${RELVERDIR}"
 package="${RELDIR}/${RELVERDIR}.zip"
 verfile="${RELDIR}/${RELVERDIR}/version.txt"
 rm -rf $outdir
-rm $package
+rm -f $package
 mkdir -p $outdir
 mkdir -p $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}
 mkdir -p $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
@@ -161,22 +81,13 @@ cp -r ${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/gtk-2.0 $outdir/bin/postgisgui/
 cp -r ${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin/postgisgui/lib
 cp -r ${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/gdk-pixbuf-2.0 $outdir/bin/postgisgui/lib
-# old proj < 8
-cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj/* $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
-cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
-# new proj >= 8 folder prefixed with proj
-cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj/* $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
-cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
-#for some reason shp2pgsql-gui has a dependency on proj, so annoying
-cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
-#start shipping the projsync
-cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/projsync.exe $outdir/bin
+# proj
+cp ${PROJ_LIB}/* $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
+cp ${PROJ_PATH}/bin/*.dll $outdir/bin
+cp ${PROJ_PATH}/bin/*.dll $outdir/bin/postgisgui
+# geos
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
-cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 #for protobuf
@@ -205,7 +116,7 @@ if [ -n "$SFCGAL_VER"  ]; then
 	echo "GMP VERSION: ${GMP_VER} https://gmplib.org" >> $verfile
 	echo "MPFR VERSION: ${MPFR_VER} http://www.mpfr.org" >> $verfile
-	cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
+	#cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
 	cp -p ${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin
 	# cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 	# cp -p ${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin/postgisgui
@@ -221,7 +132,7 @@ cd ${POSTGIS_SRC}
 strip postgis/*.dll
 strip sfcgal/*.dll
 strip raster/rt_pg/*.dll
-strip liblwgeom/.libs/*.dll
+#strip liblwgeom/.libs/*.dll
 cp postgis/*.dll ${RELDIR}/${RELVERDIR}/lib
 cp sfcgal/*.dll ${RELDIR}/${RELVERDIR}/lib
@@ -233,9 +144,12 @@ cp raster/rt_pg/*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MIN
 cp utils/*.pl ${RELDIR}/${RELVERDIR}/utils
 cp raster/loader/.libs/raster2pgsql.exe ${RELDIR}/${RELVERDIR}/bin
-cp liblwgeom/.libs/*.dll ${RELDIR}/${RELVERDIR}/bin
+#cp liblwgeom/.libs/*.dll ${RELDIR}/${RELVERDIR}/bin
+cp loader/shp2pgsql.exe ${RELDIR}/${RELVERDIR}/bin
 cp loader/.libs/shp2pgsql.exe ${RELDIR}/${RELVERDIR}/bin
+cp loader/pgsql2shp.exe ${RELDIR}/${RELVERDIR}/bin
 cp loader/.libs/pgsql2shp.exe ${RELDIR}/${RELVERDIR}/bin
+cp loader/shp2pgsql-gui.exe ${RELDIR}/${RELVERDIR}/bin/postgisgui
 cp loader/.libs/shp2pgsql-gui.exe ${RELDIR}/${RELVERDIR}/bin/postgisgui
 cp topology/loader/* ${RELDIR}/${RELVERDIR}/bin
@@ -245,12 +159,12 @@ cp topology/loader/* ${RELDIR}/${RELVERDIR}/bin
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll ${RELDIR}/${RELVERDIR}/bin/postgisgui
 cp spatial_ref_sys.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp topology/topology.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
-cp topology/topology_upgrade_*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
+#cp topology/topology_upgrade_*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 #cp topology/README* ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 #cp utils/* ${RELDIR}/${RELVERDIR}/utils
 #cp extras/* ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}/extras
 # in case we ever do MAX ship all the max scripts
-export POSTGIS_MINOR_MAX_VER=${POSTGIS_MINOR_VER}.UPGRADEME
+export POSTGIS_MINOR_MAX_VER="ANY"
 #export UPGRADE_VER_FILE="extensions/upgradeable_versions.mk"
 value=$(<extensions/upgradeable_versions.mk)
@@ -261,31 +175,21 @@ export UPGRADEABLE_VERSIONS=$value
 #echo "Versions are:  $UPGRADEABLE_VERSIONS"
 export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
 for EXTNAME in postgis postgis_raster postgis_topology postgis_sfcgal postgis_tiger_geocoder address_standardizer; do
-	cp extensions/$EXTNAME/sql/$EXTNAME--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
-	cp extensions/$EXTNAME/sql/*unpackaged*.sql ${RELDIR}/${RELVERDIR}/share/extension
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}--${POSTGIS_MICRO_VER}next.sql
+	cp extensions/$EXTNAME/sql/*  ${RELDIR}/${RELVERDIR}/share/extension
+	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-	# special cases of ANY and next
-	echo "--placeholder" > ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--ANY--${POSTGIS_MINOR_MAX_VER}.sql
 	if test "$EXTNAME" = "address_standardizer"; then #repeat for address_standardizer_data_us
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
-		cp extensions/postgis/sql/postgis--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/${EXTNAME}_data_us--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
-		echo "--placeholder" > ${RELDIR}/${RELVERDIR}/share/extension//${EXTNAME}_data_us--ANY--${POSTGIS_MINOR_MAX_VER}.sql
-		echo "--placeholder" > ${RELDIR}/${RELVERDIR}/share/extension//${EXTNAME}_data_us--${POSTGIS_MICRO_VER}--${POSTGIS_MINOR_MAX_VER}.sql
-		echo "--placeholder" > ${RELDIR}/${RELVERDIR}/share/extension//${EXTNAME}_data_us--${POSTGIS_MICRO_VER}next--${POSTGIS_MINOR_MAX_VER}.sql
+		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
+		cp extensions//$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
 	fi
 	for OLD_VERSION in $UPGRADEABLE_VERSIONS; do \
 		if [ "$OLD_VERSION" > "2.5" ] || [ "$OLD_VERSION" in $WIN_RELEASED_VERSIONS ]; then
-			echo "--placeholder" > ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+			cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
-				echo "--placeholder" > ${RELDIR}/${RELVERDIR}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+				cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql ${RELDIR}/${RELVERDIR}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
 			fi
 		fi
 	done
@@ -301,7 +205,7 @@ cp -r extensions/*/*.dll ${RELDIR}/${RELVERDIR}/lib #only address_standardizer i
 cp -r ${RELDIR}/packaging_notes/* ${RELDIR}/${RELVERDIR}/
-echo "GEOS VERSION: ${GEOS_VER} https://trac.osgeo.org/geos" >> $verfile
+echo "GEOS VERSION: ${GEOS_VER} https://github.com/libgeos/geos" >> $verfile
 echo "GDAL VERSION: ${GDAL_VER} https://gdal.org/download.html#current-releases" >> $verfile
 echo "PROJ VERSION: ${PROJ_VER} https://proj.org/download.html#current-release" >> $verfile
@@ -310,13 +214,13 @@ echo "LIBICONV VERSION: ${ICON_VER} http://ftp.gnu.org/gnu/libiconv/libiconv-${I
     echo "CGAL VERSION: ${CGAL_VER} http://www.cgal.org" >> $verfile
     echo "BOOST VERSION: ${BOOST_VER} http://www.boost.org" >> $verfile
-    echo "SFCGAL VERSION: ${SFCGAL_VER} http://www.sfcgal.org https://github.com/sfcgal/SFCGAL" >> $verfile
+    echo "SFCGAL VERSION: ${SFCGAL_VER} http://www.sfcgal.org https://gitlab.com/sfcgal/SFCGAL" >> $verfile
 fi;
 if [ -f ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt ]; then
 	cat $verfile ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt > $verfile
 fi
-#echo "PAGC ADDRESS STANDARDIZER: http://sourceforge.net/p/pagc/code/HEAD/tree/branches/sew-refactor/postgresql " >> $verfile
 cd ${RELDIR}
 zip -r $package ${RELVERDIR}
 md5sum $package > ${package}.md5
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 0ef160335..9906d5659 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,78 +1,14 @@
 #!/usr/bin/env bash
-set -e
-	export GEOS_VER=3.11.2
-fi;
-fi;
-fi;
-fi;
-fi;
-fi;
-else
-fi;
+echo "MSYS2_ARG_CONV_EXCL=$MSYS2_ARG_CONV_EXCL"
@@ -101,21 +37,6 @@ export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
-#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
-if [ -d "${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj" ]; then
-export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
-else
-export PROJ_LIB=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
-fi
-#add protobuf
@@ -144,21 +65,15 @@ fi
-	#export CGAL_VER=4.11
-	BOOST_VER=1.78.0
-	export BOOST_VER_WU=1_78_0
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 ./configure \
@@ -167,18 +82,18 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   #exit
 else
+./configure \
 fi;
@@ -206,7 +121,8 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
  cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
 export POSTGIS_MINOR_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
@@ -214,32 +130,23 @@ export value=${value//\\/}
 value=${value//UPGRADEABLE_VERSIONS = /}
 #echo $value
+export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
-	cp extensions/$EXTNAME/sql/$EXTNAME--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/$EXTNAME--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}--${POSTGIS_MICRO_VER}next.sql
-	echo "--placeholder" >  ${PGPATHEDB}/share/extension/$EXTNAME--ANY--${POSTGIS_MINOR_MAX_VER}.sql
+	cp extensions/$EXTNAME/sql/*  ${PGPATHEDB}/share/extension
+	cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$POSTGIS_MICRO_VER--${POSTGIS_MINOR_MAX_VER}.sql;
-		cp extensions/postgis/sql/postgis--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
-		echo "--placeholder" >  ${PGPATHEDB}/share/extension//${EXTNAME}_data_us--ANY--${POSTGIS_MINOR_MAX_VER}.sql
-		echo "--placeholder" >  ${PGPATHEDB}/share/extension//${EXTNAME}_data_us--${POSTGIS_MICRO_VER}--${POSTGIS_MINOR_MAX_VER}.sql
-		echo "--placeholder" >  ${PGPATHEDB}/share/extension//${EXTNAME}_data_us--${POSTGIS_MICRO_VER}next--${POSTGIS_MINOR_MAX_VER}.sql
+		cp extensions/$EXTNAME/sql/${EXTNAME}--TEMPLATED--TO--ANY.sql ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$POSTGIS_MICRO_VER--ANY.sql;
 	fi
-		if [ "$OLD_VERSION" > "2.5" ] ; then
-			echo "--placeholder" >  ${PGPATHEDB}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+		if [ "$OLD_VERSION" > "2.5" ] || [ "$OLD_VERSION" in $WIN_RELEASED_VERSIONS ]; then
+			cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
-				echo "--placeholder" >  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+				cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
 			fi
 		fi
 	done
@@ -252,12 +159,12 @@ done
  make check RUNTESTFLAGS="--extension -v"
- ##test address standardizer
+ #test address standardizer
  cd ${POSTGIS_SRC}
  cd extensions/address_standardizer
  make installcheck
- ##test tiger geocoder
+ #test tiger geocoder
  cd ${POSTGIS_SRC}
  cd extensions/postgis_tiger_geocoder
  make installcheck
@@ -267,7 +174,7 @@ done
 fi
 if [ "$DUMP_RESTORE" == "1" ]; then
- echo "Dum restore test"
+ echo "Dump restore test"
  make install
  make check RUNTESTFLAGS="-v --dumprestore"
  if [ "$?" != "0" ]; then
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
new file mode 100644
index 000000000..296712046
--- /dev/null
+++ b/ci/winnie/winnie_common.sh
@@ -0,0 +1,143 @@
+# Common code for all winnie scripts
+# TODO: add more shared code, I guess
+set -e
+export PROJECTS=/projects
+# Don't convert paths
+# See https://trac.osgeo.org/postgis/ticket/5436#comment:5
+export MSYS2_ARG_CONV_EXCL=/config/tags
+if  [[ "${OVERRIDE}" == '' ]] ; then
+	export GEOS_VER=3.12.2
+	export GDAL_VER=3.8.5
+	export PROJ_VER=8.2.1
+	export SFCGAL_VER=1.5.1
+	export CGAL_VER=5.6
+	export ICON_VER=1.17
+	export ZLIB_VER=1.2.13
+	export PROTOBUF_VER=3.2.0
+	export PROTOBUFC_VER=1.2.1
+	export JSON_VER=0.12
+	export PROJSO=libproj_8_2.dll
+	export LZ4_VER=1.9.3
+fi;
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export JSON_VER=0.12
+export PCRE_VER=8.33
+#export OS_BUILD=64
+#export PGPORT=8442
+#export OS_BUILD=32
+#export GCC_TYPE=
+#if no override is set - use these values
+#otherwise use the ones jenkins passes thru
+if  [[ "${ICON_VER}" == '' ]] ; then
+fi;
+echo "ICON_VER ${ICON_VER}"
+#set to something even if override is on but not set
+if  [[ "${ZLIB_VER}" == '' ]] ; then
+fi;
+if  [[ "${LIBXML_VER}" == '' ]] ; then
+  export LIBXML_VER=2.9.14
+fi;
+if  [[ "${CGAL_VER}" == '' ]] ; then
+fi;
+##hard code versions of cgal etc. for now
+export CGAL_VER=5.6
+BOOST_VER=1.84.0
+export BOOST_VER_WU=1_84_0
+export LZ4_PATH=${PROJECTS}/lz4/rel-lz4-${LZ4_VER}w${OS_BUILD}${GCC_TYPE}
+export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+#export GDAL_VER=2.4.0
+#export PROJ_VER=5.2.0
+echo "ZLIB_VER $ZLIB_VER"
+echo "PROJ_VER $PROJ_VER"
+echo "LIBXML_VER $LIBXML_VER"
+echo "CGAL_VER $CGAL_VER"
+export MINGPROJECTS=/projects
+export PATHOLD=$PATH
+if [ "$OS_BUILD" == "64" ] ; then
+	export MINGHOST=x86_64-w64-mingw32
+else
+	export MINGHOST=i686-w64-mingw32
+fi;
+#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
+if [ -d "${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj" ]; then
+export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export PROJ_PATH=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+else
+export PROJ_LIB=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export PROJ_PATH=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+fi
+#export PG_VER=9.2beta2
+export PGWINVER=${PG_VER}edb
+export WORKSPACE=`pwd`
+echo PATH BEFORE: $PATH
+#export PGHOST=localhost
+export PGUSER=postgres
+#export GEOS_VER=3.4.0dev
+#export GDAL_VER=1.9.1
+export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
+export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
+export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+#add lz4
+export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+echo $PATH
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
+#add protobuf
+echo "PATH AFTER: $PATH"
+if  [[ "${INCLUDE_MINOR_LIB}" == "" ]] ; then
+	export INCLUDE_MINOR_LIB=1
+fi;
Summary of changes:
 NEWS                         |   7 +++
 ci/winnie/build_postgis.sh   | 117 ++++------------------------------
 ci/winnie/package_postgis.sh | 146 ++++++++-----------------------------------
 ci/winnie/regress_postgis.sh | 141 +++++++----------------------------------
 ci/winnie/winnie_common.sh   | 143 ++++++++++++++++++++++++++++++++++++++++++
 libpgcommon/lwgeom_pg.c      |  57 ++++++++++++-----
 6 files changed, 255 insertions(+), 356 deletions(-)
 create mode 100644 ci/winnie/winnie_common.sh
hooks/post-receive
