[SCM] PostGIS branch master updated. 3.5.0alpha1-4-g74e0e52d2
git at osgeo.org
git at osgeo.org
Fri Jul 5 03:35:56 PDT 2024
the project "PostGIS".
via 74e0e52d2ab4a996a009965d84da30b941d46c2c (commit)
from bbbe6bb436483f7eb16e6a57fea12bcdf63cf5bc (commit)
revisions in full, below.
commit 74e0e52d2ab4a996a009965d84da30b941d46c2c
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jul 5 06:29:24 2024 -0400
Fix spelling errors (Bas Couwenberg)
Closes #5760 for PostGIS 3.5.0
diff --git a/NEWS b/NEWS
index bc17e50ff..f437a45e5 100644
--- a/NEWS
+++ b/NEWS
@@ -1,7 +1,12 @@
-PostGIS 3.5.0
+PostGIS 3.5.0alpha2
2024/xx/xx
+Changes since alpha1
+#5760, postgis_topology: Fix spelling errors (Bas Couwenberg)
To take advantage of all SFCGAL features, SFCGAL 1.5.0+ is needed.
+PostgreSQL 12-17 supported
Many thanks to our translation teams, in particular:
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 3f48f8e29..72c1baa87 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -2301,8 +2301,8 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
* @param modFace can be
- * 0 - have two new faces replace a splitted face
- * 1 - modify a splitted face, adding a new one
+ * 0 - have two new faces replace a spli face
+ * 1 - modify a split face, adding a new one
* -1 - do not check at all for face splitting
@@ -5231,7 +5231,7 @@ _lwt_SnapEdgeToExistingNode(
ret = _lwt_FindAdjacentEdges( topo, node->node_id, &(splitNodeEdgeEnds[n]), NULL, -1 );
if ( ! ret ) {
lwerror("Unexpected backend return: _lwt_FindAdjacentEdges(%"
- LWTFMT_ELEMID ") found no edges when we previously splitted edge %"
+ LWTFMT_ELEMID ") found no edges when we previously split edge %"
LWTFMT_ELEMID "d on it",
node->node_id, edge->edge_id);
return -1;
@@ -5639,7 +5639,7 @@ _lwt_SnapEdgeToExistingNode(
- * Update the splitted edge
+ * Update the split edge
diff --git a/regress/run_test.pl b/regress/run_test.pl
index a3724bf82..e5d12239d 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1915,7 +1915,7 @@ sub upgrade_spatial_extensions
# Handle raster split if coming from pre-split extension
- # and going to splitted raster
+ # and going to split raster
if ( $OPT_UPGRADE_FROM &&
( not $OPT_UPGRADE_FROM =~ /^unpackaged/ ) &&
has_split_raster_ext($OPT_UPGRADE_TO) &&
Summary of changes:
NEWS | 7 ++++++-
liblwgeom/topo/lwgeom_topo.c | 8 ++++----
regress/run_test.pl | 2 +-
3 files changed, 11 insertions(+), 6 deletions(-)
hooks/post-receive
