[SCM] PostGIS branch master updated. 3.5.0alpha1-5-g8a73af4b3
Fri Jul 5 03:36:59 PDT 2024
the project "PostGIS".
       via  8a73af4b367a18db35213f65ded961daddb2c3fa (commit)
      from  74e0e52d2ab4a996a009965d84da30b941d46c2c (commit)
revisions in full, below.
commit 8a73af4b367a18db35213f65ded961daddb2c3fa
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 5 12:34:53 2024 +0200
    Do not check woodpecker configuration if not found
    It isn't found in distribution tarball.
    Closes #5759
diff --git a/utils/check_lang_enabled.sh b/utils/check_lang_enabled.sh
index 4d6afdd0e..fede59afb 100755
--- a/utils/check_lang_enabled.sh
+++ b/utils/check_lang_enabled.sh
@@ -21,9 +21,9 @@ while [ $# -gt 0 ]; do
 done
 if [ -z "${RD}" ]; then
-  RD=`dirname $0`/..
+  RD=$(cd $(dirname $0)/..; pwd)
 fi
-test ${RD}/doc/po || {
+test -d ${RD}/doc/po || {
   echo "ERROR: Source dir ${RD} does not contain a doc/po directory" >&2
   exit 1
@@ -32,6 +32,13 @@ ENABLED_TRANSLATIONS=$(grep ^translations ${RD}/doc/Makefile.in | cut -d= -f2)
 fail=0
 CORRECTLY_ENABLED=
+CHECK_WOODIE=no
+if test -d ${RD}/.woodpecker; then
+  CHECK_WOODIE=yes
+else
+  echo "SKIP: woodpecker config not checked as ${RD}/.woodpecker dir is not present"
+fi
 # Available languages are those for which we have at least a .po file
 for LANG in $(
@@ -54,11 +61,13 @@ do
   # Check that the language check is enabled for woodie
-  grep -qw "${LANG}" ${RD}/.woodpecker/docs.yml || {
-    echo "FAIL: ${LANG} is not enabled in ${RD}/.woodpecker/docs.yml"
-    fail=$((fail+1))
-    continue
+  if test "${CHECK_WOODIE}" = "yes"; then
+    grep -qw "${LANG}" ${RD}/.woodpecker/docs.yml || {
+      echo "FAIL: ${LANG} is not enabled in ${RD}/.woodpecker/docs.yml"
+      fail=$((fail+1))
+      continue
+  fi
   echo "PASS: ${LANG} is correctly enabled"
Summary of changes:
 utils/check_lang_enabled.sh | 23 ++++++++++++++++-------
 1 file changed, 16 insertions(+), 7 deletions(-)
hooks/post-receive
