[PostGIS] #5763: Berrie64 PostgreSQL support not building with XML support
trac at osgeo.org
Fri Jul 12 07:19:24 PDT 2024
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: management | Version: 3.4.x
Keywords: |
Berrie64 is not building with XML support so failing on garden tests.
17:09:49 -------------- Dependencies --------------
17:09:49 GEOS config:
/home/jenkins/workspace/geos/rel-3.13.0/bin/geos-config
17:09:49 GEOS version: 3.13.0dev (31300)
17:09:49 GDAL config: /usr/bin/gdal-config
17:09:49 GDAL version: 3.2.2
17:09:49 PostgreSQL config:
/home/jenkins/workspace/pg/label/berrie64/rel/pg17w64/bin/pg_config
17:09:49 PostgreSQL version: PostgreSQL 18devel
17:09:49 PROJ version: 7.2.1 (70201)
17:09:49 Libxml2 config: /usr/bin/xml2-config
17:09:49 Libxml2 version: 2.9.10
17:09:49 JSON-C support: yes
17:09:49 protobuf support: yes
17:09:49 protobuf-c version: 1003003
17:09:49 PCRE support: Version 1
17:09:49 Perl: /usr/bin/perl
17:09:49
17:09:49 --------------- Extensions ---------------
17:09:49 PostgreSQL EXTENSION support: enabled
17:09:49 PostGIS Raster: enabled
17:09:49 PostGIS Topology: enabled
17:09:49 SFCGAL support: disabled
17:09:49 Address Standardizer support: enabled
17:09:49
17:09:49 -------- Documentation Generation --------
17:09:49 xsltproc: /usr/bin/xsltproc
17:09:49 docbook xsl base:
http://cdn.docbook.org/release/xsl/current
17:09:49 dblatex: /usr/bin/dblatex
17:09:49 convert: /usr/bin/convert
17:09:49
PostGIS garden tests in progress (it will take time)
17:52:55 -------------------------------------------------
17:52:55 psql -X -ad postgis_garden < \
17:52:55 ../doc/postgis_gardentest_35.sql \
17:52:55 > postgis_garden_result.txt 2>&1 || { \
17:52:55 tail -n 20 postgis_garden_result.txt; false; }
19:07:35 tail -n 20 postgis_garden_result.txt
19:07:42 FROM postgis_garden_log35
ORDER BY logid DESC LIMIT 1;UPDATE postgis_garden_log35 SET log_end =
clock_timestamp()
19:07:42 ERROR: unsupported XML feature
19:07:42 DETAIL: This functionality requires the server to be built with
libxml support.
19:07:42 FROM (SELECT logid FROM postgis_garden_log35 ORDER
BY logid DESC limit 1) As foo
19:07:42 WHERE postgis_garden_log35.logid = foo.logid AND
postgis_garden_log35.log_end IS NULL;
19:07:42 ERROR: current transaction is aborted, commands ignored until
end of transaction block
19:07:42 COMMIT;
19:07:42 ROLLBACK
I need to review this and while I'm at it will also change to build using
Meson.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5763>
